fugedaboutit
![]() Join Date: Mar 2005
Advice needed
Ive run out of time and money...again and I promised myself Id be on the track this year. I want to run for points in the street bracket but need advice on traction. Im running a 406/th400 into a peglegger w/3.07.. the later is what makes me sick. Im thinking of buying a mini spool and slicks and calling it good (until I can afford more) Im guessing I can run low 14s with these gears but what size slicks? Do I need cclip eliminators to run the spool? This is a track and back driver- will the spool be ok or am I going to pop I know you will need more info so shoot away..
Currently truckless ![]() |
Re: Advice needed
I think it will work. I'd run a 28 x 10 slick and be looking for a 9 inch for later!
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
Daily Driver
Re: Advice needed
thats an awesome tire. im lovin it. but i have 4.10s spooled.every1 used to laugh at my little slicks and say i had pizza cutters on the back, but i ran 26 x 8"s from mickey thompson and with a good burnout they would dead hook 1.7x 60'.and with the 4.10s i ran outta gear just short of the line.but with your gear you would be cool. why waste the money on a big tire when you can get away with a small one. peg legged might give you some trouble. just do a cheap mini spool. this is all budget so you can save cash and throw a nice built rear in it. but this is just what i got away with. Good luck
nitrous...the equal opportunity destroyer. |
fugedaboutit
Re: Advice needed
thanks guys ..I am going to start shopping this week
Re: Advice needed
i believe if you go into the rearend with the spool i'd change the gears to 373's You'll like it a lot better than the 307's. If you keep the 307's and buy slicks and a spool, i don't believe that you will have any traction issues.
Re: Advice needed
you maybe able to pick up a set cheap on here or Ebay!
ran out of money
Re: Advice needed
im going the mini spool route for a while and i have a built big block th400 and 3.73 gears and drag radials.... i looked into the eliminators and it looks like you need custom shafts to run them. i figure see how long a mini spooled stock axle will last while saving for a 9 inch...... run it and run it hard untill it breaks them worry!!
Modify everything, leave nothing alone!~ ![]() ![]() |
Re: Advice needed
some one told me one time I can't believe you run your truck that hard and I said if it breaks I need new $hit anyway!
ran out of money
Re: Advice needed
djracer thats the right set of mind!!! i tell people when they say it has a warrenty or is "unbreakable" if they will stand behind it when i break it because you telling me its unbreakable makes me want to try even harder to break it. just have to ask my snap-on or matco guys, some of my co-workers think its my goal to break everything.
run the hell out of it and just keep in mind if it breaks its another cool story you'll have to tell your kids one day or brag about next week!!!
fugedaboutit
Re: Advice needed
Im lookin at a few 28x10 slicks that say they can be mounted on an 8" wheel (ralley) .. they should fit a stock stance truck right?
Re: Advice needed
shouldn't be a problem!
fugedaboutit
Re: Advice needed
hey now! cool cover shot on the home page! bout time you got some!
Im going to order them up.. mini spool and slicks and run it as is till i get my feet wet then I will try to go faster. Thanks for the input all eric
Re: Advice needed
Do it. A spool will help alot but change the gear and watch out for wheelhop it will kill your 12 bolt with slicks if it hooks.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
fugedaboutit
Re: Advice needed
Isnt getting it to hook the idea
![]() eric
Currently truckless ![]() Last edited by redhead69; 03-08-2008 at 10:15 AM. |
#15 | |
fugedaboutit
Re: Advice needed
All of the mini spools that summit has list for passenger car 8.875 12 bolt, didnt see one specifically listed for a truck..is there a difference?? Also is there a 3.73 r&p that I can use with my existing carrier? These questions may sound dumb to some but I am rearend retarded ![]()
Currently truckless ![]() Last edited by redhead69; 03-08-2008 at 10:22 AM. |
#16 |
ran out of money
Re: Advice needed
the 3.73's will help you get out of the hole a lot quicker, but would hurt your highway cruising fuel economy.
I havent looked in summit for a mini spool but i know jegs has them listed for a truck 12 bolt. im not even sure there is a difference, i thought the differences came in the size of the pinion shaft and cover between car and truck 12 bolts. and yes they will make a ring and pinion for your carrier, just have to look for the correct series, i belive you want a series 3 carrier
#17 |
Re: Advice needed
Wheel hop is more of a leaf spring problem most of the time! I don't think I have ever had wheel hop on a trailing arm truck!
#18 |
Re: Advice needed
There is a difference in a 12 bolt car and a 12 bolt truck rear,pinion in the car rear is 1.6x while in the truck it is 1.4x,car rear is supposed to be stronger because of the larger pinion gear.Hope that helps
#19 |
fugedaboutit
Re: Advice needed
ok ordered the mini spool... part # for anyone else interested is Auburn Gear 544801.. Its just about the only one I found listed for a truck 12 bolt.
Any input on the mickey thompson et street radials? Im looking at the 325/50/15's . I do want slicks but these are about the same price and if needed I could drive on the streets with em. I guess Im asking again do you think I can hook (if I stay out of the water) with the mickeys and a mini spool? kind of guessing huh.. ![]() Im throwing the ring and pinion swap out of the equation for now just because of my budget right now and the fact Ive never done one, besides it will give me something to look forward to later when Im trying to figure out how to lower my time slips.
Currently truckless ![]() Last edited by redhead69; 03-09-2008 at 12:00 PM. |
#20 |
ran out of money
Re: Advice needed
i would run the m/t et's if it wasnt a 100% track vehicle. a lot of people talk highly of them. and they are radials so driving on the road wouldnt be bad. i got a set of bfg drag radials on my truck now (havent driven it though) only reason i got them because i got one hell of a deal on them.
#21 |
Re: Advice needed
if you go that size make sure they aren't too tall! You need a short tire with that gear!
#22 |
Daily Driver
Re: Advice needed
i just ordered the exact size you listed. thats alot of tire for your gear. its only 28" tall but your gonna bog outta the hole. traction will be no problem.im factory 4.10's, mini spool and those and on engine alone i cant even get em to squak.but they also dont handle bottle outta the hole for me. so i spray like 10 ft. out for now , until i get my progressive nitrous controller.
back to the topic though. thats an awesome tire. from what every1 says they dont get many miles outta them on street use. they are pretty much a cheater slick. the main thing is cops cant get you cause theyre DOT approved and you can run in the street tire class at the track
#23 |
Re: Advice needed
can a guy run a mini spool and still drive on the street ? i was asking some local guy about it and they said "no way" because you would be breaking axles all the time when you turned
1986 chevy c10 in the "build" process as we speak 358 flat tops, vortec heads, .500 lift cam, NOS power shot plate system, yada yada yada ![]() MMA PIX http://www.clgpix.com/MMA/Fighters/F...C/CoteTony.htm MMA RECORD 24-5 Last edited by ton*loc; 03-10-2008 at 10:49 AM. |
#24 |
Daily Driver
Re: Advice needed
im daily on a spool and i broke 1 stock axle replaced both with superiors outta summit and have had no problems since and its been some time.
#25 |
Hay Team!!
![]() Join Date: Jun 2003
Re: Advice needed
How much were those superior axles from summit?
1972 Chevrolet Cheyenne LWB "Orange and White" 8) |
