Old 03-20-2008, 12:08 AM   #1
Inklover17
Valve Cover LBS of Torque
I'm changing my valve cover gaskets tomorow and am wondering how many lbs of torque to torque them down and also the little metal pieces do they go on the inside or the outside I mean the little bracket things that go on top of the covers but under the bolts you torque thanks.
Inklover17 is offline   Reply With Quote
Old 03-20-2008, 12:57 AM   #2
cdowns
cdowns's Avatar
Re: Valve Cover LBS of Torque
less than 10ft lbs of torque//most important is to check with a straight edge and see if the holes are dimpled down from being overtightened as that is a major cause of valve cover leaks
Old 03-20-2008, 02:13 AM   #3
Premium72
Premium72's Avatar
not all that tight at all. ive never heard anyone ask ft lbs of torque on VC's. like he said make sure the gaskets on there nice an skraight, the other parts your talkn about go on top of the covers under the bolts. thier to spread out the tension on the edges of the covers to keep a good seal . good luck. dont over think it!
Premium72 is offline   Reply With Quote
Old 03-20-2008, 05:06 AM   #4
Musclerodz
INCHES NOT POUNDS! number one reason why old school covers leak. Overtighten and they distort. I would snug them and go another half turn. Check for leaks.
Mike Redpath
Musclerodz is offline   Reply With Quote
Old 03-20-2008, 05:19 AM   #5
Sinister
Between Trucks...
Sinister's Avatar
5 lb/ft. I usually just use a 1/4 drive ratchet and snug them down, not too much though...
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 03-20-2008, 05:21 AM   #6
corn
Id say 3-4 ft lbs...
corn is offline   Reply With Quote
Old 03-20-2008, 06:06 AM   #7
piecesparts
Parts and more parts
piecesparts's Avatar
I use a nutdriver or a socket on the end of hand drive and tighten to a good SNUG.
Old 03-20-2008, 06:12 AM   #8
AustinScott
AustinScott's Avatar
nice. I just did this about 45 minutes ago. I used 1/4" ratchet until they where snug, then gave them another 1/4 turn.
NOTE: I changed out the old cork gaskets with the Mr.gasket rubber style, so this info might not work with the cork style.
I over tightened the old cork ones & the passenger front side under the AC compressor blew out, OIL everywhere!!
Luckily I was only about 2 blocks form the house, Damn burn outs! always screwing things up!
AustinScott is offline   Reply With Quote
Old 03-20-2008, 06:17 AM   #9
corn
the rubber gaskets are nice. its all Ill use anymore...
Old 03-20-2008, 06:50 AM   #10
Inklover17
I am using the FEL-PRO rubber type might just get new valve covers so I know there not dimpled.
Old 03-21-2008, 09:53 AM   #11
El Jay
Gone to greener pastures
The first time I replace valve cover gaskets on an engine, I toss the bolts away.
I replace the bolts with 1/4" x 20 studs in the heads.
Then I just set the gaskets over the studs, install the valve covers, & "nut" them.
The gaskets are already lined up, etc.
'69 Chevy 1/2 T LWB Stepper: Daily Beater
'72 GMC 3/4 T Fleet: Another Daily Beater
'72 Plymouth Gran Coupe: ?
"Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche
"Never kick a fresh turd on a hot day." Harry S. Truman
GUN CONTROL: Never having to say, "I missed you."
Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck
El Jay is offline   Reply With Quote
Old 03-22-2008, 03:44 AM   #12
brad_man_72
the boat guy
brad_man_72's Avatar
is their any problems with grinding the casting texture smooth. besides getting a bunch of crap in the engine.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 03-22-2008, 03:54 AM   #13
LONGHAIR
...........and that isn't enough?
LONGHAIR is offline   Reply With Quote
Old 03-22-2008, 04:38 AM   #14
Shane
Shane's Avatar
7 ft. lbs ... use a nut driver and you'll be golden.
Shane is offline   Reply With Quote
Old 03-25-2008, 03:40 AM   #15
brad_man_72
the boat guy
if the heads are off, torn down, and you clean the crap out. then would it be a bad idea?
not van hagar
