Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 04-02-2008, 04:54 AM   #1
DieselEater
DieselEater's Avatar
Which SWB frame is better for Drag racing?
I've got two 67 SWB 2WD's, and was wondering which frame would be better to start a Drag Racing build upon. Trailing arms or leafs??????????
Please add why, and possibly what will be needed on the chosen frame for best results. I want to stay streetable, so 11's should be the fastest I want to run.
Thanks,
A.........
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
http://profile.myspace.com/index.cfm...ndid=127691959
DieselEater is offline   Reply With Quote
Old 04-02-2008, 07:28 AM   #2
djracer
djracer's Avatar
Re: Which SWB frame is better for Drag racing?
I would vote for trailing arms! I have been 5.81 in the 1/8 with trailing arms! I have an antiroll bar and coilovers with stock frame rails front to back.
I also used to have a street truck with just coilovers that hooked pretty well on m/t sportsman pro's!
I also have a pretty fast 468 short block I would make you a deal on!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 04-02-2008, 07:32 AM   #3
bigjimzlll
bigjimzlll's Avatar
trailing arm...nascar runs them...djracer goes in the 8s with them...pretty simple and hard to screw up...also no wheel hop problems
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 04-02-2008, 09:11 AM   #4
chevy72blu
chevy72blu's Avatar
Agree... Trailing arms. I'll be swapping from leafs to them soon, and Ive done a ton of research on the subject.
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 04-03-2008, 07:40 AM   #5
70rs/ss
70rs/ss's Avatar
If you can find a set off of a 3/4 ton truck as they are plated and reinforced so no flex. Trailing arm all the way. I am working the set-up on a 2wd Blazer, I plan to scare folks with a bit of a 500ci BBC and a 5-speed. Good luck!
70rs/ss is offline   Reply With Quote
Old 04-04-2008, 03:12 AM   #6
DieselEater
Cool......I just happen to have a 3/4 ton 2wd longbed. The arms will work right? This project will go slow, but it has definitely started!!!!
Thanks for all the feedback,
A........
69' 3/4 4X4
470ci BBC
700 HP....
D60/14bolt
205/465
Old 04-04-2008, 05:00 AM   #7
1970chevy
Hey djracer how much are you asking for 468 short block
1970chevy is offline   Reply With Quote
Old 04-04-2008, 08:20 AM   #8
djracer
djracer's Avatar
I'd like to get 2500 but might entertain an offer! Its a 4 bolt block with steel crank, Lunati Pro Mod Rods, Wise co Dome pistons, Ls7 oil pan, Dampener balancer and an Sufi Fly Wheel. No timing set or camshaft. The cam is borrowed and the Timing set cost almost a grand!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 04-06-2008, 12:20 AM   #9
70rs/ss
70rs/ss's Avatar
Yeah, the trailing arms are the same from late 60's through 72 for 1/2 ton and 3/4's. I am in the process of gathering the stuff to put my 2wd Blazer on kill, 3/4 ton trailing arms, 3:73 posi, NV4500 5-speed, 469-505 stroked and poked BBC. Should be FUN to drive!!
