Old 05-01-2008, 06:28 AM   #1
abadsvt
abadsvt's Avatar
Am i loosing my mind?
Hi guys! I was centering my rear end on my frame and after i got it centered i noticed that the pinion center is slightly off centered. It is a little more on the passenger side. It is right around 3/8" give or take towards that side. I measured and measured and measured some more and the rear end is centered but the pinion isn't. Am i loosing my mind and start seeing things? Thanks Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 05-01-2008, 07:10 AM   #2
Hart_Rod
Hart_Rod's Avatar
Re: Am i loosing my mind?
I've never paid much attention to it, but that's probably right. Have you seen the offset of some the ford 9" rearends? Some of those are 6-10" offset.
R
Hart_Rod is offline   Reply With Quote
Old 05-01-2008, 07:19 AM   #3
Shaffer4
Strange Cousin From The West..
Nevermind, after re-reading your post, I see what you are talking about :P
Shaffer4 is offline   Reply With Quote
Old 05-01-2008, 10:05 AM   #4
BigSky71
LAIDOUT
BigSky71's Avatar
R
Yea, my 9" is 3.75" to the passenger side. The local experts say no biggie as long as the pinion angle is kosher.
67 2wd Shorty
Build Pictures
BigSky71 is offline   Reply With Quote
Old 05-01-2008, 04:20 PM   #5
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
Its to keep the needle bearings moving around. If the driveshaft was perfectly straight the needles in the Ujoints would cut gooves from being in the same spot.
sneakysnake is offline   Reply With Quote
Old 05-01-2008, 05:09 PM   #6
steelhorse
steelhorse's Avatar
steelhorse is offline   Reply With Quote
Old 05-01-2008, 06:03 PM   #7
abadsvt
abadsvt's Avatar
Thanks guys! That was exactly what i was looking for. That makes sence with them being slightly off set for the needle bearings. I just wish every thing was lined up straight for cosmetic reasons because now the driveshaft won't be perfectly centered in my tranny tunnel. I know that sounds stupid but I am kind of anal like that. Everything needs to be perfect or i go crazy.. So for a 9" rear end the pinion center is 3.75" off towards one side from center of the rear end? Thats crazy. If i am tripping out because on 3/8" or so can you imagine how crazy i would be if it was almost 4" off. Thanks for the help
Josh
(Project truck)
Old 05-01-2008, 06:09 PM   #8
Hart_Rod
Hart_Rod's Avatar
Josh
You could always move the motor over to the same side the rearend is offset......
Old 05-01-2008, 06:24 PM   #9
BigSky71
LAIDOUT
BigSky71's Avatar
Josh
Well my 9" is from an early Bronco, car models are different. I don't mind the offset, no one but the alignment guy has seen the bottom of my truck .
67 2wd Shorty
Build Pictures
Old 05-02-2008, 03:23 AM   #10
grady5
maybe you should ask luckin fou, on musclecar the challenger motor was offset in the engine bay and they centered it. he told what they did for the offset but i cant remember i think they tilted the axle down but im not sure
grady5 is offline   Reply With Quote
