Old 05-10-2008, 07:47 PM   #1
BuckLucky
BuckLucky's Avatar
My 72 Blazer w/8inch lift 38.5x14.50 Swampers
I finally got pictures of my Blazer to post. This is the start to my resto project. Had to get the thing up off the ground first, always the most important thing to start with, lift and tires. Next was pulling the heater box , controls and heater core out to clean it up and fix the broken controls. I bought a truck cab just for the doors since my top hinges pulled out of mine and cut them to fit the blazer. Glad it had good heater controls cause mine were broke. Got the heater all put back together now and works great. Next thing to do is to replace the break lines, but I cant get the old ones off, can anyone help me on this. Looks like there is a big not on the back side of the frame where the brake line goes through. I cant get it to come apart. It is a pretty solid blazer but does have plenty of rust to fix.
BuckLucky is offline   Reply With Quote
Old 05-10-2008, 07:58 PM   #2
bigbadchev72
People know me
bigbadchev72's Avatar
Re: My 72 Blazer w/8inch lift 38.5x14.50 Swampers
Nice blazer, I will be buying my new 38s and the beggining of next month. Do you have any straight on shots that show how far the tires stick out from the body?
The state troopers Have been harrassing me with my boggers and dont want to be in the same situation with new tires. Fender flares are out of the question!
What width rims are you running?
As for the brake lines there should be a U shaped clip at the bracket that has to be pulled before the lines come out. vice grips may be needed
1972 k/5 blazer CST 4X4 Crate 350, th350/205, dana44with trac-loc/14 bolt with detroit locker, 4 wheel discs 4.56s, 8" suspension lift using 73-87springs, 1" zerorate custom front crossmember, HAD CV drivelines and driveshaft e-brake, full cage, PRP seats, Full autometer gauges, 38x14.5x16 Toyo M/Ts, 16x10 Polished aluminum rockcrusher wheels
1967 longbox 4x4, Strong 400/400/208, 44/12bolt 4.10s, 6" lift, 35" Toyo M/Ts on corvette rally wheels
bigbadchev72 is offline   Reply With Quote
Old 05-10-2008, 08:25 PM   #3
BuckLucky
BuckLucky's Avatar
I am running 10 inch wheels. I will go take a picture for ya in a few minutes. As for the clip on the brake line, I dont see the clip like my other blazer. Looks like a weird nut jobber on there.
Old 05-10-2008, 08:32 PM   #4
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Looks good. The truck looks pretty solid. Make sure you don't use the doors to help lift you up into it or ya might have the same problem with the replacement doors.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 05-10-2008, 08:37 PM   #5
bigbadchev72
People know me
those pics would be greatly appreciated.
they must be aftermarket lines then? My stainless braided ones use a nut, It is a 7/8 or a 15/16s if i remember right.
Can you get some pics of the problem you are having?
Old 05-10-2008, 08:53 PM   #6
BuckLucky
BuckLucky's Avatar
Here is the pics of the tires for ya. I will try and get pics of the nut . I wonder if they are a replacement tha was on my blazer or something.
Old 05-10-2008, 09:04 PM   #7
bigbadchev72
People know me
Those pics help out a ton! Do you know what backspacing you have on the rims by chance?
Old 05-10-2008, 09:15 PM   #8
Yukon Jack
Yukon Jack's Avatar
Good looking K5! The lift and tires looks real good. Front of the rear fender is kinda close so keep an eye on that.
Is the nut your working with the type that is made out of thin sheet metal rather than a normal nut style? At least one of my trucks had those but they came off pretty easily.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 05-10-2008, 10:30 PM   #9
BuckLucky
BuckLucky's Avatar
Exactly Yukon. Mine are hard to get to with the exhaust but I couldnt get them to budge. I thought maybee there was a retainer clip keeping the nut from turnin too but cant see one. I did hit a little the other day on the front of the rear fender. I have blocks and add-a-leafs right now. I wasnt real sure how I wanted to do the lift in the back.I beleive the block move the rearend forward so there is no driveline modifacations. I was thinking about doing the shackle flip in the rear and going with some 4 inch springs. Not sure what I wana do yet with the back. I dont want to wheel the thing, thats what the samurai is for!
Bigbadchev72. I wana say they are 3 1/2 backspacing. They were purchased for my toyota, I dont know if there is a standard for backspacing on those or not. I can try to measure to see.
Old 05-10-2008, 11:37 PM   #10
Yukon Jack
Yukon Jack's Avatar
I think the stance is about perfect, but you could use a Zerorate block from www.offroaddesign.com to lift the rear 1" and it also gives you the option to move the axle back 1".
Might be a great option for you.
Old 05-11-2008, 12:09 AM   #11
bouncytruck
SKINNY TIRES RULE!
You may have to trim the "fang" on the bottom front of the wheel openings. Zerorates should help prevent needing to do that and, as Yukon mentioned, move the wheel back centering it in the wheel opening.
bouncytruck 1972 K5
Old 05-11-2008, 03:18 AM   #12
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Good looking blazer ya got there...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 05-11-2008, 03:44 AM   #13
Burt4x4
Burt4x4's Avatar
Awesome!
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 05-11-2008, 01:20 PM   #14
vtblazer
vtblazer's Avatar
...38.5's with 6-lug axles.
Looks sweet for sure with the 8" lift & big tires, what's next for it?
Cross-over steering so it drives decent without the bump steer?
One ton master cylinder so you have a better chance of stopping?
Sorry but a big lift and big tires shouldn't be the first mods IMO.
Finish the build and make it safe before hitting the black top...please.
vtblazer is offline   Reply With Quote
Old 05-11-2008, 06:01 PM   #15
BuckLucky
BuckLucky's Avatar
I definately hear ya about the lift and tires not being the first thing to put on but in my case, that is what makes me want to get that thing on the road is seeing it setting there with the lift and tires. Just had to get the lift in place first.
I got a 1 ton rear but need a 60 for the front just dont have 1K to spend right now. And the booster, is that a direct bolt on replacement? What year booster? Mods?
Wasnt sure on the cross over though. Bump steer isnt that bad . Will the cross over eliminate all the bump steer? Who is the best outfit to use for the set up. It isnt interchangeble from a 44 to a 60 is it? I dont think it is. Not real familiar with the 60 front, just know I want one.
Thanks, cant wait to get her on the road.
Old 05-12-2008, 03:51 AM   #16
72BlckButy
Tot Roddin'
72BlckButy's Avatar
That thing is sweet!!!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 05-13-2008, 01:51 PM   #17
vtblazer
vtblazer's Avatar
Yeah, something about getting em lifted...
You might be able to find the D60 for a better price, I just picked up a D60/14BFF for 1K (for the set) out of a CUCV.
You can pick up a 1-ton master/booster for our years, they normally bolt right in. (big improvement in braking)
Cross over works, it's worth the investment.
Old 05-14-2008, 05:38 PM   #18
BuckLucky
BuckLucky's Avatar
Thanks for the info, I will give the parts store a call and see what the damage will be on the booster. Working on selling my 70 pro street elcamino project to help fund the Blazer project. Once that sells I will get the cross over steering.
Old 05-14-2008, 07:24 PM   #19
Burt4x4
Burt4x4's Avatar
Here is the 1Ton Master/Booster I swaped into my 72K5. Take note of the short lines going from the Master to the P-Valve. They are opposite on a 1Ton setup. I got new pre-bent short lines from In-Line Tube dot com, I think I paid 20bucks for the two of them and they worked out great!
The 1Ton Booster is fatter than the 1/2ton one so your setup will be more forward than the 1/2 ton stuff but it is a direct bolt in affair. I did need to extend the lower support bar to make it reach..
Good lUck!
Burt
Old 05-14-2008, 11:38 PM   #20
BuckLucky
BuckLucky's Avatar
Thanks for the picture, good info too.Thanks Burt!
Old 05-15-2008, 06:11 AM   #21
BuckLucky
BuckLucky's Avatar
ANother Question on the 1 ton brake booster, do I need to buy a 1 ton master cylinder also? It is 166.00 for the booster and master cylinder.
Old 05-15-2008, 07:07 PM   #22
Burt4x4
Burt4x4's Avatar
Possiably you do, the plunger inside may be different. By plunger I mean the metal push rod. My 1/2 ton Master had a much longer push rod than the 1Ton did so I had to get a matching master. They look almost identical so I too thought I could get away with using the same master. In my case I could not.
Old 05-15-2008, 10:05 PM   #23
BuckLucky
BuckLucky's Avatar
I figure I will buy them both just for peice of mind anyway.
Old 08-03-2012, 02:30 AM   #24
BuckLucky
BuckLucky's Avatar
Sorry for bringing this back up but I thought Id add my upgrades I have made. Blazer pretty much sat for 2 years after I lifted it . Now Im back to dumping money into the rust bucket. The next thing I upgraded was the steering. I ended up just keeping my stock 12 bolt and dana 44 as I have no plans on wheeling the thing. I purchased the cross over steering kit from Off Road Design. All I can say is wow, best upgrade I have made. Didnt even need to put a steering stabilizer on. Drove dang good with out it but I put one on anyway. Next thing I did was a new performer rpm intake, Holley 4160 vacume secondary carb ( got rid of the junk edelbrock, actually its sitting on my bench lol) , installed a performer rpm cam and lifters, brand new hooker headers, hooker header 2 1/4 mandrel bent exhaust kit and summit racing wanabe flowmaster mufflers. The blazer is running and sounding great . The one thing I havent done yet is to change the booster out for a 1 ton unit, that and 4.56 gears are the next 2 things on my list. I will get some pics up asap. After those 2 things are done I will be putting in new body mounts and start the patch work for the body panels and also get a cage built and tie it into the frame to stiffen the thing up . I was thinking of putting in newer style seat belt system also so I can put car seats in the back. Figured I could tie the shoulder straps into the roll cage.
Old 08-03-2012, 10:43 AM   #25
in deep 72
in deep 72's Avatar
Love the truck man! Glad to see your back pouring $ in it, haha (it seems never ending when you can see what you want in you head). And have to say the stance is about perfect! I think these trucks look the best at that height!
Here you can see why I think that
in deep 72 is offline   Reply With Quote
