78 k5 blazer 3/4 ton axle swap
Any help on what I'm going to run into when i do this and does everything bolt up. And I have my choice of a dana 44 front or a 60 front and my choice of a 60 rear or a 14 bolt rear which would be the best to have.
the pollock
Re: 78 k5 blazer 3/4 ton axle swap
d60 front 14 bolt rear
is the 14bolt Fullfloat or Semifloat?
Jack of ALL trades, Master of none.. (but one... procrastination) Army vet 02-08 RIP El Jay! Miss you brother! http://67-72chevytrucks.com/vboard/s...d.php?t=343538 http://67-72chevytrucks.com/vboard/s...d.php?t=386042 |
What he said....
Dana 60 front 14bolt Rear. Tough as nails...and then some.
Matt 91 GMC K-5 Jimmy 350/700R4/241/10boltX2 W/4:56's/locked. 6inch Softride on 35's. Starting to show signs of trail life... 86 Chev K-10 Short 383/350/208/10&12bolt Gonna be the pretty truck... |
the pollock
hell im runnin a 14 bolt SF with the "little ring gear" and im having a hard time messing it up =-)
with the 60 and 14bolt ff youl be able to well.. it'll be able to support mroe weight then the rest of your truck could handle =-) in freaking vincible axels
60s and 14 bolts do have there limits though. People think they cant break. They can and do, but it takes abuse that 99% of the people dont want to put their truck through.
71 swb 4x4, 37" Iroks, t400/205 496 77 CJ-7, Narrowed Dana 60 Lockrite, 14 Bolt Spool, 4.56 gears, 39.5" boggers. 360 t-18/d20 |
What is the intended purpose of the truck?
The blazer is going to be just for fun off road, no street driving, mostly it will see mud. Not sure if the 14bolt is full or semi floating.
the pollock
dpes the hub of the 14 bolt stick out thourg the hole in the center of the rim ... if so its a full float if not its a semi float
Arrived on a Pale Horse
Dont forget to post some pics when you get into it! The axle swap, AND the mud!!!
Jason 87 V30 350TBI/400 White w/Boss V-plow 89 R3500 CC SRW |
The blazer is just stock now and I just bought it about a month ago. Picked it up for $800 bucks. The trans and transfer case were both shot. I picked up a transfer case off of craigslist for 75 bucks and I built a trans for nothing. I put them in on Saturday and got to drive it for the first time. It runs ok but need to do a tune up and see what happens. The reason Im going to do the axle swap is because the dana 44 thats on the front right now is missing all the inners on the left side, and looks like what i need to fix it is going to cost me like 200 bucks. So i can get a set of 3/4 ton axles for $400 from a friend.
