Old 06-17-2008, 02:43 PM   #101
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Re: ojoe's crewcab shortbed build
You can shorten it without converting. Just take a section out of the existing frame and weld it back together. If I keep mine I plan to do it that way.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 06-17-2008, 03:49 PM   #102
bcubed
bcubed's Avatar
Originally Posted by rhenson1 View Post
I have been reading this thread with interest since I just purchased a 88 V30 4x4. My question is can you shorten a 1 ton frame and not use the half ton rear section like you are doing or is using the 1/2 ton the only way to go. I havent had my truck long but a 4x4 crew cab short bed would be the bomb.
This thread here is the one you need .. it shows how to shorten a frame.
http://67-72chevytrucks.com/vboard/s...d.php?t=123624
2000 Bagged Silverado
1978 Chevy Malibu
1955 Apache Stepside (someday)
bcubed is offline   Reply With Quote
Old 06-17-2008, 07:32 PM   #103
Captkaos
Captkaos's Avatar
You can see a members truck that just did this. It is a Regular Cab Longbed to shortbed. Same concept.
http://forum.73-87chevytrucks.com/sm...p?topic=7334.0
There is also an article on it here by another member:
http://www.73-87chevytrucks.com/lwb_to_swb.htm
This subject has come up A LOT. I would follow the forum method of cutting the frame though.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 06-24-2008, 02:44 PM   #104
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
What was the Cost of Getting your Driveshaft Shortened for the Truck, I was Given a Quote of $250.00- $300.00 for this? Is that The Going Rate, We only have one Location nearby, I Just Thought that was kinda High to Shorten one? Any Suggestions on where i might look?
Thanks, Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
toomanytoyz is offline   Reply With Quote
Old 06-24-2008, 02:52 PM   #105
djracer
djracer's Avatar
Thanks, Rick
That's high!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 06-24-2008, 07:40 PM   #106
N2TRUX
Happy to be here
N2TRUX's Avatar
For 250-300 they should be building you a completely new shaft, not just re-tubing it.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 06-24-2008, 07:59 PM   #107
OJOE
Crew Cut
OJOE's Avatar
Thanks, Rick
total cost 80.00
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 06-24-2008, 09:49 PM   #108
SCOTI
SCOTI's Avatar
Thanks, Rick
Lengthening it maybe. Shortening it for that price? No way.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-24-2008, 10:39 PM   #109
toomanytoyz
Luv the Crewcabs
Thanks for the Input, I Thought that seemed High.................
I Think i will go looking at the Junkyard..............
Rick
55 Nomad
52 Willys Truck
67 Stepper
67 Fleet
68 Wrecker
68 Suburban
76 Crewcab
79 Gmc Dumptruck
84 Blazer
86 Crewcab Stepside
87 Iroc
89 GMC Plow Truck
91 Camaro Vert
96 Z71 Stepsde
Old 07-29-2008, 05:51 AM   #110
mike nutt
69fatmotor
mike nutt's Avatar
here's a few pics of the truck . it's getting ready to go off for paint. we swapped out two of the doors and got the bed ready . the gas door has been relocated . the next time you see the truck it should be red. the truck ride and drives great and the air is cold.
mike nutt is offline   Reply With Quote
Old 07-29-2008, 05:53 AM   #111
mike nutt
69fatmotor
mike nutt's Avatar
also the tailgate handle was relocated.
Old 07-29-2008, 06:31 AM   #112
djracer
djracer's Avatar
sweet! Can't wait to ride in it!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 07-29-2008, 06:33 AM   #113
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
looks good.. cant wait to see it in paint
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 07-29-2008, 02:27 PM   #114
Captkaos
Captkaos's Avatar
Sweet! Can't wait to see it.
Rod Doors said the rear door panels are still about 4 weeks of being completed for test fitting...
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 07-29-2008, 07:04 PM   #115
OJOE
Crew Cut
OJOE's Avatar
the truck is at the body shop now. was told i would have it back in 2-4 weeks. (hope not body shop weeks) paint will be torch red.
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 07-29-2008, 08:04 PM   #116
68Timber
I know the pieces fit
68Timber's Avatar
I hope to see that truck at Flip's cruise in when it's done. I love the crew cabs.
Old 07-30-2008, 03:49 PM   #117
bcubed
bcubed's Avatar
Then the upholstery shop?
1978 Chevy Malibu
Old 07-30-2008, 07:24 PM   #118
OJOE
Crew Cut
OJOE's Avatar
yes and maybe the rear Rod door panels will be in by then.
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 07-30-2008, 07:29 PM   #119
OJOE
Crew Cut
OJOE's Avatar
we will be there. are you from montgomery? mysel and my buddy mike nutt go there some. i take my 30 model A hot rod and mike takes his orange 69 chev p/u.
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 07-30-2008, 09:59 PM   #120
f.monroe
f.monroe's Avatar
This may have been answered already but what size are the tires you have mounted . Also what are the specs on the wheels as far as backspacing goes ? I like the sidewall on them . I wonder how that much sidewall would look on a reg cab short bed ?
Frank
Born and proudly residing in a Red State !
f.monroe is offline   Reply With Quote
Old 07-30-2008, 10:29 PM   #121
pcmcobra
pcmcobra's Avatar
ojoe, looking good.
If you ever get time, can you get some more pics of the filler routing? I like the new fuel door.
Wheels: rear 20x10 5.5" bs
front 20x8.5 5.25"bs (I think)
1986 C10 SWB 6.0/6l90e
Miami...Flee it like a native
pcmcobra is offline   Reply With Quote
Old 07-31-2008, 05:48 PM   #122
68Timber
68Timber's Avatar
I'm in Montgomery. I'm usually at Flip's and make other shows if I hear about them. Post some pics of your car and Mike's truck, I'll look for you next show.
Old 07-31-2008, 06:48 PM   #123
68Timber
68Timber's Avatar
Who are you planning to use for the interior work? I'd been using Lucky, the guy who had a shop on 231 just south of Taylor Road. But he closed up shop, I heard he's working at home and only doing high-end work now. I'm not sure recovering my Blazer seats and installing a carpet kit would interest him.
Old 07-31-2008, 07:37 PM   #124
OJOE
Crew Cut
OJOE's Avatar
dont know who to use on this project. i have been looking at some after market seats but dont know. i have a 87 burb that i may use the front buckets and console and a bench in rear. i have a buddy that used some one in north al a few months back that does good clean work but i would like to get some one local.
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
Old 07-31-2008, 07:48 PM   #125
OJOE
Crew Cut
OJOE's Avatar
Originally Posted by pcmcobra View Post
ojoe, looking good.
thanks for the wheel specs
i will try to get more pics at the body shop. they are taking the bed back off for paint. i did turn the filler tube to the rear of the truck about 2" or maybe from 6 o clock to about 8 o clock and just used a rubber hose to connect the tank to filler end. the hose was hard to find that can be used with gas
85 CHEV SWB/TPI
30 MODEL A HOT ROD
09 STREET GLIDE
