06-14-2008, 12:56 AM | #1 |
Chevy's Rock!
How should I rock my ride?
Ok, I may be getting the cart before the horse here, but I thought that I would get a jump start on ideas... *Assuming* that I win the contest, what do you guys suggest for $10K worth of improvements? I realize that in today's world, $10K can get eaten up pretty quickly on a project, so we will have to be careful of what we spend our money on. One thing worth mentioning is that I don't have a clue as to how this will all unfold... I certainly hope that I will have some say in what is done to the truck!
So, would you bag it, slam it down or lift it? It is a 3/4 ton 2WD, so would it look dumb if it was lifted? I realize that the 8-lug rims will present their own set of problems... The Interior is green, so I was thinking about going either Midnight Green or Black with it, assuming that they are willing to put enough hours in the body to get it good enough for a dark color. For starters, sheetmetal work will be a priority as this is in Ohio Truck and many patch panels will need to be sacrificed in the making... Please give me your suggestions on how you would do the truck, even if it is just a minor detail that we should do to it. Post pictures if you have some. If you have no clue as to what I am talking about, follow the link in my sig. Here are some pictures: Thanks,
John '59 NAPCO Pickup '70 K10 Pickup 350 '72 C20 Suburban 350 (MIA) '57 Chieftain 455 '68 Firebird Convertible - 400 '68 Catalina Convertible - 400 '85 Vette |
06-14-2008, 01:51 AM | #2 |
Re: How should I rock my ride?
if i was in your position i would have all the body work done, and i would have what ever of the intirior done after the body and paint are done, the engine would come next. i would leave it all stock but redone in the color u like, imo stock is the best wiht subtle modifications done
good luck i hope u win nader
Trial and Error, its expensive but its a mistake i most likely wont make again 1971 chevy k10 custom deluxe http://67-72chevytrucks.com/vboard/s...d.php?t=341257 1968 chevy k/10 fleet http://67-72chevytrucks.com/vboard/s...d.php?t=334731 1948 desoto custom coupe fluid drive(family heirloom) |
06-14-2008, 08:05 AM | #3 | |
Chevy's Rock!
The 350 runs pretty well in the truck, and the bottom end was gone through about 1000 miles ago. Mostly it is just a little puff of smoke from the valve seals that shows up at startup or when I get on it. The trans is a 4-speed with the granny gear. One option would be to put a set of aftermarket heads, a cam and intake on it to pep it up. As it sits, it only has a 2 Barrel on it. Another option is to drop in the 468 out of my '73 1 ton Crew Cab that is eaten up with rust, but the engine should probably be gone through. Either way, I would like to go with an OD Tran, if it is in the budget. Tempting as it may be, aftermarket wheels and tires could seriously attack the budget and I realize that will have to stay in check. I appreciate the input,
06-14-2008, 10:21 AM | #4 |
SKINNY TIRES RULE!
I think a lot depends on your abilities. Body and paint is probably going to eat up most of that budget and I think those would be top priority. If the engine runs solid, I'd probably get some rims or make sure the interior is livable. After that, I'd look at a drop kit, you can always bag it later and start stock piling the parts for an engine rebuild (or buy a crate).
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
06-19-2008, 12:29 PM | #5 |
Chevy's Rock!
Bump! I think we have to jumpstart this thread... Things are looking pretty good for "The Pickle" right now!
06-19-2008, 02:32 PM | #6 |
Commander Taco Bello
parts for a bag stuff and all new suspension, plus 2 days labor @ $50/hr = $2300
depending on how bad your rust is, figure 5-10 days labor into rust repair and paint prep @ $50/hr = $2000 - $4000 Paint and Supplies = $800 Day Labor to Paint = $400 decent interior work = $1000 O/D Tranny and engine bay clean up = $1500 roughly $10k. you could save a good chunk of $$ if they give you a better rate on labor, or if you could do some of the work your self, along side them. I have a feeling they are going to want to blast their shop logo and the radio station logo all over the side of your truck. Hopefully they'll be fair about that whole thing. |
06-19-2008, 02:48 PM | #7 |
Tot Roddin'
I think Ivel layed that out quite nicely...
If you want to save a little $$$ on lowering it you can always go with an ECE static drop kit. This thing is going to look sick!!!!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 06-19-2008 at 02:48 PM. |
06-19-2008, 02:58 PM | #8 |
i should clarify that the bag stuff includes 4 bags, lines, fittings, valves, compressor, tank, switches, gauges, drop spindles, ball joints, tie rod ends, trailing arm bushings, U bolts, U joints, 4 shocks, bolt in C-notch and a new carrier bearing.
06-19-2008, 03:03 PM | #9 |
Tot Roddin'
Wow... that is a steal for that price!
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
06-19-2008, 03:10 PM | #10 |
The thing is, with "only" $10k it is still definatly a budget minded build.
I think body work, maybe some nicely painted stock style wheels or some cheaper aftermarket wheels would be a good start, see what you can do with the interior, and go with the OD transmission. After they're done with it, then you can swap in your 468 yourself when the funds become available to rebuild it. I'd hate to be in your predicament |
06-19-2008, 03:32 PM | #11 |
To me it would all depend on who was doing the body and paint work... I would rather have it look like it does now that getting something back with bad body and paint work... I would allow them to do things like the suspension, wheels, brake upgrade and interior.... If it comes back wavey with tons of orange peel will you really be happy??? I know I wouldn't...
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
06-19-2008, 04:25 PM | #12 |
I would say after the bodywork and paint has been done, get the OD tranny. Then decide what else. If it's then in the budget to do something else, maybe raise it. It is a 3/4 ton. I'm kinda partial to the Pre-Runner look for a 2wd.
As for rims, I think that those Hummer rims would look good on there, with the accents painted the body color. By the way, do you have any more pics of the interior, and engine?
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ Last edited by nightmare; 06-19-2008 at 04:26 PM. |
06-19-2008, 04:49 PM | #13 |
I'm kinda with the majority here. Body work, paint (I like the darker green and if it were mine I'd go one solid color instead of the white roof), freshen the engine/engine bay, and a static drop to start. Then if money allows OD tranny and maybe wheels/tires.
1978 Chevrolet Silverado 3/4 ton 400 small block. 2000 F-250 Powerstroke 2002 GMC Yukon Denali XL |
06-19-2008, 05:26 PM | #14 |
Oh, BTW, you can get airbags for a few hundred dollars, just without the compressor and tanks. Probably just about as cheap as a static drop.
06-20-2008, 02:10 PM | #15 |
What I would do is see what they have in mind for it. I'm sure the exterior is going to be redone. Then some interior upgrades...But let them know that with gas prices so high, that you really need some better MPG upgrades such as O/D Tranny, fuel injection ect.....Being in the greater Cincinnati area there are a lot of places to find a drive train upgrade for a good price. I'm starting on a transplant for my 69 with a '99 suburban (350 FI w/ 4speed auto) upgrade. Look around for a 3/4 ton 354 rear end for it and cruise into some much better MPG.
Congrads!!!!! Glad we could help you out!!! Oh!!!! It must have a '67-72chevytrucks.com' logo somewhere on it!!! |
06-20-2008, 02:43 PM | #16 |
Tot Roddin'
I would go with body and paint... the rest is pretty easy, and a lot less expensive!
06-20-2008, 04:30 PM | #17 |
Barrito Loco Diablo
Yeah, everyone's got a good idea. Since your motor is strong and it seems the rest of your drivetrain is solid. I'd focus on body and suspension. You should easily be able to bag it and get some panels replaced with a nice paint job for 10k.
I'd assume you could help out with "some" of the work being that it's your truck. I'm just glad that you get to pick what gets done. Whatever you choose to do, just be sure it's what "you" want done to it. Don't give em an inch. Good Luck. |
06-21-2008, 12:17 AM | #18 |
Happy Camper
I am not a Sub expert by any means, but is it going to be as easy as some say to drop it since it is a 3/4 ton? I would say its a no brainer if it was a 1/2 ton. Just curious.
Other than my above sidebar, I would make it as pretty as possible on the outside, the rest of the rig is a lot cheaper and easier to mod up.
RIP El Jay! Love you brother! |
06-21-2008, 01:16 AM | #19 |
Green club
I say body/paint for sure, this get very pricy very quickly and if your skill levels are not up to par here this will be money well spent. Rust repair is expensive, paint is expensive let someone else flip the bill on this.
Suspension/engine/wheels etc is all bolt on/parts gathering (to me anyway) so that can be done on a more spread out schedule as time and money permits. Just my $.02
71 short/fleet ECE 4/6 drop, LQ4/700r4/3.42 gears 70 SS396 Chevelle 427/200-4R/3.73posi 61 Lincoln Continental, black on black Son you are going to drive me to drinkin if you don't stop drivin that hot rod lincoln |
06-21-2008, 07:56 AM | #20 |
Official Site Guitar Shredder
Looks as if you won..............SO now get to work..............And congrats............
06-22-2008, 11:40 AM | #21 |
Gettin By on Gettin By
Cant wait.
69 CST10 LWB 455 Buick 00 S10 2.2 Vin5 76 GL1000 Naked 1bl VW carb "Adios to all the concrete; Gonna get me some dirt road back streets" |
07-01-2008, 02:45 PM | #22 |
Registered 71 GMC Owner
You should turn it into a Short Wheel Base Tahoe.... check out Frizzle Fry's!
http://67-72chevytrucks.com/vboard/s...d.php?t=239896 |
07-01-2008, 02:49 PM | #23 |
We need some updates??? DId you win??? Or did they hit you with the old fine print??
07-02-2008, 10:09 PM | #24 | |
Chevy's Rock!
07-02-2008, 10:12 PM | #25 |
Did they give you an idea of when it will be finished?
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs. |
