#26 |
Re: new toy! 79 2wd blazer
Nice blazer!!!!!!! It needs a 4/6 drop bad. What size tires are you going to run on the coys?
Mexican |
#27 |
Happy to be here
![]() Join Date: Mar 2000
I wondered how long it would be before you bolted those on there....
#28 |
its just $$$$$
I finally got time to lower it. I dropped it approximately 4"/4". I was prepared and even had the parts to do the flip on the rear, but decided it would be slightly more than i "really" wanted. I went with a spindle and one coil removed from the stock spring in the front. On the rear i used a 2" shackle and removed the overload leaf and the 1/2" lift block that had been installed somewhere along the way. This yielded about a 4" drop.
The wheels are Coys C5s 22x9" with 5.5" BS on the front with 265/35s the rear are 5" BS with 285/35s. |
#29 |
BK Built
looks good man. makes me wanna static drop mine. then i think to myself "i can still see light underneath" and it reassures me, that ill bag mine
#30 |
its just $$$$$
im gonna go out on a limb here and say that you arent married. THings change a little....you have to do things slowly...make them think its their idea..
I guess what im saying is dont be too suprised to see this one on air in the future.....but not right now ![]() ![]() besides i need to finish the 72 before i go off the deep end on this one. |
#31 |
Happy to be here
Looks good buddy. It's hard to tell, but it looks like you need another .5-1" drop up front.
#32 |
In the Forgotten far North.
![]() Join Date: Jul 2007
One good pothole or missing manhole cover and you can kiss those rims goodbye
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015 1990 chevy suburban V2500 5.7L My cluster Mods-Nov 2007 overhead console Stereo install Round 2 Aug 2009 Heated/turn signal mirror upgrade |
#33 | |
BK Built
![]() as far as your blazer, i really like it. alot. |
#34 |
Low & Fast!
I love it!! Looks very cool.. And I know what your talking about wife and kid slows things down a little..
#35 |
Active Member
Looks great Tracy...very clean. Like the Coys ALOT.
Are you getting any rubbing of the inner fender? I'm just curious since I'm getting BAD rubbing on the inside of the tire towards the engine on both sides....it's already burnt the paint off the fender.....considering just removing them.
D.M.C -FF- |
#36 |
did you have any clearance issues with the rear shackle? I have been thinking of using one and have heard horror stories about rerouting the gas filler ect.
#37 | |
its just $$$$$
#38 |
its just $$$$$
the shackle will fit, it also will rub the fuel filler hose. I have done it a couple of times. You can loosen the clamp that attaches the filler tube to the body and kinda cheat it over a little(if that makes sense). To me the rubbing on the hose is not that big of an issue, as long as it doesnt hinder the flow which it doesnt.
#39 | |
Happy to be here
#40 |
I know the pieces fit
Level! Looks great. Now if I could just reach in my monitor and pull that weed that's touching the bottom edge of the driver's door - driving me crazy...
#41 |
I went by the muffler shop I use and showed him what needed to be done. He said if I'd take it off he'd put a curve in it to clear the shackle. Works for me. If only he were open Saturdays, I'll have to take a day off just for that little detail.
#42 |
how do your wheel and tire fit in the rear i have the same ones except gunmetal finish wondering if a 305/40/22 would fit or would it be to big also thinking about 295/40/22
#43 |
Bagged 74...that rear drip rail on the topper is killin me. When you have the time would you mind takin some pics and posting them?
DW
Doug Wright aka K5NUTT over @coloradok5.com Owner of http://groups.yahoo.com/group/ChevyK5BlazerChalets Certified K5 Nut |
#44 |
its just $$$$$
I did a little buffing last week. It looks alot better.
I will get some pics of that drip rail for ya tomorrow... |
#45 |
freak'n sweet man! i would consider it done! looks too good to be tear'n into!
#46 | |
Workaholic
1979 K-10 Silverado (work in progress) 1991 V1500 Subruban 1999 Suburban LT 4x4 2006 Suburban LTZ (daily driver) |
#47 |
Active Member
Looks NICE tracy, found a gem!
D.M.C -FF- |
#48 |
Looks Good What Size Wheels Are On It?
#49 |
The buffer sure was good to the truck, the paint looks MUCH better.
#50 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Sweet score...
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
