Old 07-19-2008, 01:30 AM   #1
c-mack
c-mack's Avatar
fake white walls.....HELP
hi, while looking for white walls the other day for my 67, a local tire guy said that there are some kind of rings that fit between the rim and tire that make it look like you have white walls. he said that they were really popular in the 60s. they used to call the "spats" does anybody have some? are they worth the money? how much are they? just some info would be great...thanks
colby
1967 chevy truck
350 V8
1973 VW Transporter/Hippy Bus
1964 VW Baja Bug
"When the power of love overcomes the love of power the world will know peace"- Jimi Hendrix
c-mack is offline   Reply With Quote
Old 07-19-2008, 01:57 AM   #2
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: fake white walls.....HELP
colby
They are called portawalls and they are pretty much junk as far as I've been told. The can (and will) fly apart at high speeds. Some people say they weren't designed for radials and will only work well with bia ply tires, but this is all hearsay. I have no experience with them. I think Lucas Tires still sells them.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 07-19-2008, 02:05 AM   #3
bowtieboy93
bowtieboy93's Avatar
heres lucas tire's page or portawalls
http://www.lucasclassictires.com/POR...UIDELINES.html
Travis
travis_moffatt@hotmail.com
1969 Chevrolet C-10 LWB, 350c.i., TH350, In Pieces.
1991 GMC Sonoma, IROCS s10 grill
1963 Ford Galaxie 351/C4
bowtieboy93 is offline   Reply With Quote
Old 07-19-2008, 02:43 AM   #4
HoupPhotography
Wow, thanks for that info man! and thanks for the post c-mack, I was just going o ask the same thing, $60 is much cheaper than $700...
Edit: I just remembered, someone had a "how to" video on how to make your own white walls by using a sanding disc on the black wall, it made a mess but it worked awesome, from the video.
R.I.P. Scott Kalitta
HoupPhotography is offline   Reply With Quote
Old 07-19-2008, 07:00 AM   #5
bad6772
Official Site Guitar Shredder
bad6772's Avatar
Hey Houp......i have seen the (MADE) whitewalls up close..And the way its done today is not like the way it was done years ago......I do not think you would be happy with the way they are done these days........Years ago......Their use to be shops that would (cut them down) almost like running them on a lathe......<that technique always looked good IMO....But the way they are sanded now......I dont think would fit the style and cleanliness your truck has...
just my O.2
bad6772 is offline   Reply With Quote
Old 07-19-2008, 07:45 AM   #6
see ten
WTB this ad
see ten's Avatar
Portawalls are designed for bias ply tires not for radials. Corky Coker no longer deals with them due to the large number of people that have been dissatisfied with em.
see ten is offline   Reply With Quote
Old 07-19-2008, 07:51 AM   #7
67_C-30
67_C-30's Avatar
Yep see ten is right. Lucas Tire says that and the fact thatb need to run tubes on their site.
Please read this before you try Portawalls
Portawalls were originally designed to work on bias ply tires some 50 years ago, not today's radials. Bias tires
have a flat rigid sidewall, and a much higher profile (aspect ratio) than radial tires. There is a lesser likelihood of
them adhering properly to a radial because of the radius and flexibility of it's sidewall. The lower the profile of a
radial, the less likely you will be pleased with the results. Larger radials with a 75 profile seem to work fairly well,
but we do not recommend trying them on many of today's popular 60 profiles and smaller. For radials, we
suggest the narrower widths, so they won't extend beyond the radius of the sidewall.
Installation is critical and the sidewalls have to be extremely clean to increase your success rate. We recommend
a degreasing agent, not a solvent be used to wipe between the tire and the rim to ensure that the area is very
clean. DO NOT use a soapy compound, or the portawalls will slip out during re-inflation. Use an inner tube!
My trucks
Old 07-19-2008, 09:56 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
speedway automotive has them, not sure if they are the same thing as corker had or not.
Old 07-19-2008, 10:10 AM   #9
LockDoc
The Older Generation
LockDoc's Avatar
I had them on my 1940 Pontiac Coupe "Sugar Plum", in 1958.... .. They were the 2" wide ones.
I guess you could say I've been into the cars & trucks for a few years....
LockDoc
Leon
Old 07-19-2008, 10:11 AM   #10
Premium72
Premium72's Avatar
*content deleted*
IV. Pure trolling, either to upset someone or simply for your personal
enjoyment, is strictly prohibited. If you're here to cause trouble, it will be a very short stay. Immediate BAN and you will be reported to your ISP.
XIII. If you are a long time member, act like one. Lead by example and assist other newer members rather then attacking them. We look upon our veteran members to use this opportunity to teach the newer members the appropriate message board usage.
Premium72 is offline   Reply With Quote
Old 07-19-2008, 10:33 AM   #11
BACKYARD88
On the fast track to nowhere..
BACKYARD88's Avatar
LockDoc
That's a cool Pic Leon, you've been around forever
Originally Posted by Premium72 View Post
Edited
Thanks Andy
-Mike Owen-
Norwood, Houston, Cecilia, Jackson, Monroe and counting
BACKYARD88 is offline   Reply With Quote
Old 07-19-2008, 11:24 AM   #12
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
For my birthday, in '64, I asked for a set of "Double Eagle" portawalls for my '54 Ford. When I got 'em, I went to a local station that had an outdoor, drive-on lift. Breaking them down was done without any air tools....manual bead breaker, etc. Put them on, it looked good (bias ply recap tires) and I was a happy high school senior!
Member Nr. 2770
Old 07-19-2008, 12:27 PM   #13
70' GMC
HERE.......Somewhere
70' GMC's Avatar
I think I seen someone sanding down the side of the tire to get the white wall look it was on you tube or another website. It looked dangerous sanding up that tire like they did.
Found it
Current rides: 2013 Hyundai elantra gt DD
1995 camaro my first crush lmao
Was: 1970 with a 350 4barrel and 288 horses
Classics make it possible!
70' GMC is offline   Reply With Quote
Old 07-19-2008, 12:32 PM   #14
ratpackv8sonly
ratpackv8sonly's Avatar
Mooneyes has them. Again not for radials though. mooneyesusa.com
ratpackv8sonly is offline   Reply With Quote
Old 07-19-2008, 03:14 PM   #15
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Back in the day, when a car wasn't dressed if it didn't have whitewalls, there were people who made a living going to car lots and "creating" whitewalls. Originally, they were painted onto the tires, and later the process evolved into actually cutting the outer surface to reveal the white rubber that may have formerly been a white lettered tire.
Didja know that there is alumina (refined bauxite) in the white rubber compound? Where I was employed, we had several rubber company customers who bought a specific product that went into the making of the white rubber. Titanium dioxide is another chemical compound that helps to create the white rubber.
Member Nr. 2770
Old 07-19-2008, 03:17 PM   #16
mbgmike
Actually the first tires wire all white being the color of natural rubber they did not know how to make a black one
mbgmike is offline   Reply With Quote
Old 07-19-2008, 05:56 PM   #17
Sinister
Between Trucks...
Sinister's Avatar
There's a member on here who just painted his whitewalls on. The guy who lowered his C-20. They looked pretty good in the photos.
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 07-19-2008, 05:56 PM   #18
LockDoc
LockDoc's Avatar
Thanks Mike... I think...
LockDoc
Leon
Old 07-19-2008, 08:36 PM   #19
c-mack
c-mack's Avatar
...can you still buy bias tires?? where? how much?
1967 chevy truck
350 V8
1964 VW Baja Bug
Old 07-19-2008, 11:02 PM   #20
Longhorn Man
I saw 3/4 ton truck (LT) tires at sears about 8 years ago... they were 16.5 tall by skinny booooooooring tires though.
Old 07-19-2008, 11:47 PM   #21
c-mack
c-mack's Avatar
8 years ago?.....those are probably dry rotted by now!
1967 chevy truck
350 V8
1964 VW Baja Bug
Old 07-20-2008, 12:20 AM   #22
**grumpy**
**grumpy**'s Avatar
I've had port-a-walls on several cars/trucks (on radials).
Now granted, they aren't a 10yr solution, but for a cheap fix for a cruise season, they're fine.
And on my 59 chevy wagon with a EFI350/4L60, they stayed put at 90mph regularly.
I just recently had them on a 62 short fleet.
It's all in the install.
And trust me. I've bought, maybe, 10-12 sets of $700 radial wide whitewalls from Coker and Diamondback in the past 10 yrs. Shhhh, I have a bad habit of trading/selling cars....haha
But being laid-off now, I gotta go ghetto style. So they do me fine.
Road Hounds
**grumpy** is offline   Reply With Quote
Old 07-20-2008, 12:36 AM   #23
c-mack
c-mack's Avatar
around how long do they noramaly last you on the radials? o and BTW, AWESOME wagon. i love station wagons.
1967 chevy truck
350 V8
1964 VW Baja Bug
Old 07-20-2008, 12:41 AM   #24
Sinister
Between Trucks...
Sinister's Avatar
Here's a link to that lowered C-20 with the painted whitewalls.
http://67-72chevytrucks.com/vboard/s...=286975&page=2
Beat it to fit,
Old 07-20-2008, 12:42 AM   #25
HoupPhotography
Wow, those are port-a-walls... They look great. I'm gonna give 'em a try and see how I like 'em, if I get some cruise time on 'em then it was worth the $60
