Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 07-29-2008, 10:16 PM   #1
85SBC400
how dificult
ok guys, i have a 80's something 4x4 s10, no title. i would liek to make this truck a drag truck only toy and i have just the engine. its a sbc 400 with a th350 behind it.
now my question is, how dificult would it be to turn this 4x4 s10 into a 2wd style drag truck?
worth it? after all, the truck was given to me and the engine and tranny are just sitting in my garage.
thanks guys for your input. i hope this turns out do-able.
85SBC400 is offline   Reply With Quote
Old 07-29-2008, 10:26 PM   #2
BarryB
BarryB's Avatar
Re: how dificult
That all depends, I wouldn't bet on the diffs to handle much more than stock power. The swap isn't much harder than doing it to a 2wd. they make a special oil pan you would need to in order to fit over the front diff. everything else should be the same as for difficulty.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
Old 07-29-2008, 10:32 PM   #3
85SBC400
Re: how dificult
well wouldn't the front diff and all that come out?
and this is going to be a drag truck....the rear dif will end up being a shortned 9" more then likly.
Old 07-30-2008, 12:03 PM   #4
trailwart
trailwart's Avatar
Re: how dificult
8.8 rear out of a leaf rear explorer is a direct bolt in. thtas the rear most swap in as they are real stout.
72 chevy 3\4 ton 4 speed 4x4
84 1\2 ton 4x4 (gone but not forgotten, thanks for the memories)
1999 suburban 4x4
1982 chevrolet S-10 V-8 (Thanks uncle EARL)
trailwart is offline   Reply With Quote
Old 07-31-2008, 10:14 PM   #5
BarryB
BarryB's Avatar
Re: how dificult
Oh since that's the case, And since I didn't read clearly your first post. I would suggest comparing the frame's between a 2wd and 4wd. I think they are different. I remember awhile back I had a 4wd parts S10. And I had looked at doing just the opposite to a 2wd I had. It was going to be more work than I wanted to get into.
Two rules in life.
Old 08-16-2008, 09:55 PM   #6
Myself
Re: how dificult
Yes, front frame sections are different. There was a guy in my town that did one years ago. He cut off the front end and welded a 2wd frame stub back in place. He said it was the best option.
Myself is offline   Reply With Quote
