Old 01-23-2001, 10:43 AM   #1
Jimmy P
Post Window regulators
I have an 84 1/2 ton with the basic crank windows. After replacing the seals on the windows, I'm having a hard time with the glass staying in the 'track'. They both want to go outwards and out of the groove. Is there an adjustment I can make?
Never under any circumstances take a sleeping pill and a laxitive on the same night
Jimmy P is offline   Reply With Quote
Old 01-23-2001, 07:20 PM   #2
4x4k20
Post
yes with door panel off you can move the window track alittle by loosening a small bolt with 7/16 wrench this track is where the window slides up and down on closest to the door handle also check and lube up the roller track with white grease it will help alot
4x4k20 is offline   Reply With Quote
