Old 09-02-2008, 05:15 AM   #1
Wilson_
Wilson_'s Avatar
Brake Master Question
I have a question about my truck I just bought. Its a 67 gmc 2wd shortbed. It has disk brakes in the front and I was told that it did not come equipped with them from the factory. It does not have a booster and the brake master is leaking, can I just buy a brake master for a 67 with out a booster?
Thanks for your help
Wilson_ is offline   Reply With Quote
Old 09-02-2008, 05:20 AM   #2
tommypic
tommypic's Avatar
Re: Brake Master Question
The master cylinders are the same if I remember correct , just go to parts house tell them its for a 67-72 . they will want to know if its got disk . hope this helps
My ZipCode = 29673
2008 Silverado Z71 LTZ Wrecked New Ride SOLD
71-72 Custom A/C Parts Truck < selling parts
67 Chevy ShortStep SOLD
67 GMC SWB Step <-- For Sell
67 Chevy SWB Step <-- working on
2000 Road King <-- SOLD
97 F150 my ride for now
2006 Escape wifes ride
HELP SUPPORT THE BOARD http://67-72chevytrucks.com/vboard/payments.php
Great How To Thread http://67-72chevytrucks.com/vboard/s...d.php?t=157669
Vendor Sites http://67-72chevytrucks.com/links/browselinks.php?c=2
tommypic is offline   Reply With Quote
Old 09-02-2008, 05:29 AM   #3
Wilson_
Wilson_'s Avatar
Thanks for the reply, I guess I worded the question wrong. My truck has disks on the front. Do I have to use the booster? Because It does not have one right now.
Thanks again
Old 09-02-2008, 06:58 AM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Thanks again
No, you don't have to use one.
(here's an idea for your avatar )
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 09-02-2008, 08:10 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
no you do not need a booster, millions of disk brake vehicles have been built without it.
You DO need to figure out what master cylinder you have, becouse a drum/drum master cylinder is NOT the same as a disk/drum master cylinder.
Old 09-02-2008, 09:52 AM   #6
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
Do you have any pics of the setup currently in your truck now?
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 09-02-2008, 10:42 AM   #7
sneakysnake
It's a catastrophic success.
sneakysnake's Avatar
With discs up front I'd lean towards you needing a 71-72 but its possible that it may be newer than that. You should be able to take it to a parts store and match it.
sneakysnake is offline   Reply With Quote
Old 09-02-2008, 10:49 AM   #8
MrBeast
high-Tech Red Neck
MrBeast's Avatar
If I was in your shoes, I would get a BMC for a 72 with front discs, that way you know it is going to work, does your truck have 5 lugs or 6?
"He used to be a pretty nice feller, now he's a welder!"
MrBeast is offline   Reply With Quote
Old 09-02-2008, 03:02 PM   #9
Wilson_
Wilson_'s Avatar
The PO said that the rear end was changed to a 72 (the rear end has leaf springs not coils) so maybe they switched the front end too?
not sure
I will get some asap
LOL the parts stores IE kragen and auto zone do not have the smartest people working there, but thanks I will look around and see what I can find
Is the 72 MC/with booster a bolt on ordeal? It is 5 lug all around
Thanks for all your help guys!!!
Old 09-02-2008, 03:04 PM   #10
Wilson_
Wilson_'s Avatar
s/t
I had that on another forum, and the pic was soo small the mods thought it wass a ballsac
Old 09-02-2008, 03:33 PM   #11
MrBeast
high-Tech Red Neck
MrBeast's Avatar
If it is a 5 lug it has been converted to a 70-72, so the mc will work well with them because it is all OE equipment, 67-69's were 6 lugs in a 2wd.
Old 09-02-2008, 04:58 PM   #12
Wilson_
Wilson_'s Avatar
Sweet, just what I wanted to hear!!!
I will pick one up asap!
Next question, will i need to get a new proportioning valve?
Here are the pics that were asked for
Old 09-03-2008, 06:23 AM   #13
Wilson_
Wilson_'s Avatar
I have another question
in the pic above there are studs going threw to the engine bay side
on the 72 master/w booster it is opposite they go into the cab
how do I go about mounting it? the studs would just hit each other. or do i have the wrong pic?
Old 09-03-2008, 06:43 AM   #14
Wilson_
Wilson_'s Avatar
ok I have been digging around looking at pics and it looks like I need a bracket or spacer of some sort
As seen in this pic
Is this correct??
Old 09-03-2008, 07:21 AM   #15
truckdude239
truckdude239's Avatar
yes you will need that bracket, check out the parts board as that is where everyone sells there stuff. or pay for a 25 buxs membership here which is good for a year and go over to the parts board and post a wtb over there. just remenber guys any selling in this thread will get it locked i hope i helped
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
Old 09-03-2008, 08:13 AM   #16
MrBeast
high-Tech Red Neck
MrBeast's Avatar
That is spot on, you will need that bracket, the best thing you really can do is either find somthing here on the board, or go junkyard hopping and find all the goodies you will need.
Old 09-03-2008, 08:25 AM   #17
tommypic
tommypic's Avatar
Wilson that will be the best 25$ you ever spent . I know I have learned alot on here and its worth that to keep this site up . O yea like truckdude239 you will need the brackets . here is a link to member selling what you need http://67-72chevytrucks.com/vboard/s...oster+brackets
My ZipCode = 29673
Old 09-03-2008, 08:27 AM   #18
msgross
msgross's Avatar
they sell those combo booster/mc at autozone. I think they require a core charge if you don't have a rusty one to turn in. The combo package was only like $10 more than the booster itself. You will need to find the booster bracket with push rod for the pedal too...
gn4u2c2 had some for sale on the parts board...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
1967, booster, brakes, gmc, master
