09-14-2008, 08:47 PM | #1 |
lifted and needs driveshafts
I got a 6'' lift kit off my brothers 72 k10. Got it on without any problems, but now the driveshafts dont reach. The truck it came off of had stock driveshafts so I assumed I could use the Blazers stock driveshafts. For the front will a k10 driveshaft fit, you think? What about the rear? Any ideas are welcome and appreciated.
09-14-2008, 09:08 PM | #2 |
The LuvShack Garage
Re: lifted and needs driveshafts
From West TN
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Big Piggy: "Goliath" 07 Kodiak C4500 Lil Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
09-14-2008, 09:42 PM | #3 |
Welcome from NC !!!!!!
Sorry I cant help w/ your problem but this is the best place to ask. |
09-14-2008, 10:48 PM | #4 |
Ya, I was hoping this is a good place to ask. Just need some people with experience lifting these to chime in. Also thanks for the welcomes.
09-14-2008, 11:34 PM | #5 |
SKINNY TIRES RULE!
Welcome to the board. Where's LSC? Post some pictures of your rig when you get a chance.
4" lifts are usually safe with the stock and 8" lifts all require drivelines, 6" lifts are the gray area where some require longer drivelines, others don't. Sounds like you'll need to get them lengthened. Find a driveline shop and give them the new measurements. I've heard it should only cost around $100. If you become a subscribing member, you could post a "wanted to buy" and possibly find some drivelines from a board member.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
09-15-2008, 05:39 AM | #6 | |
Take the measurements and either find a set or have some lengthened to the correct dimension's. Use a good drive-line shop that will balance the shafts as part of the process. I paid $60.00 per for a stock set to be stretched. |
09-15-2008, 09:33 AM | #7 |
Well the main problem is that I am a college student with no job. That creates a real small budget for this truck. I should have a front driveshaft that will fit, it will just need new universals. But what I really want to know is if there was a stock shaft on something else that will fit?
Heres how she sat for 9 years after my dad blew the engine and started t as yet another project. Now this is how she looks. Not to different, but I only got about 2 months of work in on this and have spent less then $200 not including the price of the truck, rollbar and rims. location fixxed Last edited by litebulblsc; 09-15-2008 at 09:35 AM. |
09-16-2008, 10:44 AM | #8 |
Well i ws thinking about it last night. I got a truck front driveshaft that should fit. Then with the old front and old rear I could comibe them to have a long enough rear. Since the front has the double universal thing and the rear doesnt.
09-16-2008, 04:38 PM | #9 |
I'm a poor spectator
Just an FYI, a K10 front DS will be the same as your blazer DS, the rear will be different though.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! 1979 Ford F150 4x4 SWB Built Ford Tough!!! 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
09-17-2008, 12:20 AM | #10 | |
Future TOTM Winner
http://67-72chevytrucks.com/vboard/s...d.php?t=289285 To be honest I haven't had a chance to really test it in 4x4 situations, but it bolts up fine and has a decent amount of room to extend.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
09-17-2008, 10:54 AM | #11 | |
What did the shaft come off of with the longer lower portion? Turns out the k10 front ds was longer, but not long enough. |
09-17-2008, 11:56 AM | #12 |
Future TOTM Winner
This was a front and rear set from a 71-72 blazer with a th350/NP205 combo. I took the slip end from the rear drive shaft and put it on the front drive shaft. Added about 1.5 inches.
09-17-2008, 12:31 PM | #13 |
My blazer is a 72 with th350/np205 and my front and rear slip ends are the same length. With what lookd like a stock 2'' block all around the shafts were basically maxxed out.
09-18-2008, 09:52 PM | #14 |
well i got to drive it around in my backyard with ne brakes and just front wheel drive.
