#101 |
Why does it taste purple?
Re: Killer
Your truck is starting to come along man. Good job
#102 |
Texas Big Wig
Re: Killer
Today I picked up a old dodge motor home thingy, so after I scrap out all the aluminum & stuff, I should have the $$$ for my driveshaft ![]() |
#103 |
Texas Big Wig
Re: Killer
Woo Hoo !!!!
My Tri Pro order just came in ![]() I looked everything over & there are NO dents !!! The only thing I saw that looked like damage was a lil bend on a couple of the rockers corners & they arent bad at all I super excited, I cant wait to install my rockers & get my fender on... I hope they fit as good as they look ![]() ![]() ![]() |
#104 |
Restoration Virgin!
Re: Killer
ahhhh....progress!!!....now stay focused!!LOL....looking good Bomb....keep the pics coming too!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
#105 |
On the fast track to nowhere..
Re: Killer
Did I miss something? Why 3 rockers?
-Mike Owen- Norwood, Houston, Cecilia, Jackson, Monroe and counting |
#106 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
Re: Killer
2 right side rockers are you off your rocker.......
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#107 |
Rusty but Trusty
Re: Killer
Hey guys, one of those rockers is mine. Save on shipping that way. Maybe one day I will actually get to put it on.
Spray-bomb, are they on???? where are the pics????? Dad
72 SWB, 454 / th400... hoping the kids don't get all the parts before it gets built |
#108 |
72 Chevelle Club
Re: Killer
Nice new parts can't wait to see it together!!!! Bob
I Have The Right To Remain Silent,But Lack The Ability 1972 Chevelle ... Mine 2006 Trailblazer... Hers 2002 Buick century ... Kids 2002 K1500 Z-71 EXT CAB ... Daily Driver 2005 Rockwood Roo ... For Camping 1974 Harley-Davidson XLH Sportster 84'' stroker |
#109 |
Texas Big Wig
Re: Killer
I got my drop spindles in today & painted them black
Hopefully I can get some stuff done tomorrow, just been busy lately & havent gotten to work on it much ![]() ![]() ![]() ![]() Last edited by Spray-Bomb; 10-14-2008 at 09:09 PM. |
#110 | |
Re: Killer
nickle and dime |
#112 |
Re: Killer
Man there is nothing like new parts to get you moving on a build. I got a lot done back when I came home with my new fenders and core support. I have been slacking since then though.
http://67-72chevytrucks.com/vboard/s...d.php?t=245203 |
#114 |
Texas Big Wig
Re: Killer
Well guys, I tried to get my front end finished up today but it just didnt happen
![]() First I found that I had the 1" rotors & not the 1-1/4" ones I need for the drop spindles, so I went out back & pulled off the 1-1/4" stuff I needed Then I had to run to the parts store to get some seals, I get back & start put'n it together & it seams that my upper BJs are the wrong ones for these drop spindles ![]() I had some other stuff that I ran into also, but not really worth mentioning ![]() ![]() ![]() Heres the problem ![]() ![]() More pics later Last edited by Spray-Bomb; 10-14-2008 at 09:12 PM. |
#115 |
Rusty but Trusty
Re: Killer
But you did make it out to the shop and you did make progress.
Keep at it and you'll get there. Dad
#116 |
Under Construction
Re: Killer
what am i missing on the upper balljoints. is the spindle hitting the UCA? I just tore down my sons front end over the past weekend and i will need to know..... I also was not aware of the 1" vs. 1 1/4" rotors.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 10-15-2008 at 07:54 AM. |
#117 |
Re: Killer
Problem looks to be that the ball joint isn't threaded enough so the spindle isn't tight against the UCA.
Is it just the wrong ball joint? |
#118 | |
Texas Big Wig
Re: Killer
When I tightened them down the upper A-arm is rubbing the top of the spindle I think the upper BJ is just too small around & isnt seating in the spindle, so Ima go to the parts store & see if the spec a different one for 1-1/4" rotor applications Ima double check on the lower, but it seemed just fine Just FYI, I have all 73-87 front suspension under the front of my truck: 85 lower A-arms, 84 upper A-arms, 84 crossmember, 78 rotors & calipers & CPP 73-87 drop spindles Last edited by Spray-Bomb; 10-15-2008 at 12:03 PM. |
#119 |
Under Construction
Re: Killer
ok, i forgot you were using 73-87.. I just got the 2.5/4 lowering kit with dropped spindles and rear lower springs, and i was concerned, but back on track now. The ball joints seem good on the donor 72 but will replace for good measuer. Keep up the work. its getting closer
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#120 |
Re: Killer
I like progress
#121 |
![]() Join Date: Nov 2004
Re: Killer
Did you buy 73+ drop spindles or 71/72 spindles?
You might want to try 71/72 ball joints? What brand spindles did you buy? They don't look to be ECE, did you get a good deal on them? I'm seriously considering lowerin' the c-10.
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#122 | |
Texas Big Wig
Re: Killer
I bought some new upper BJs for a 73-87, they have the same issue So I went to my local parts store & had him bring out about 8 different BJs ranging from 63-70 to 3/4T stuff The 71-72s were way too long, the 73-87s are too long, but better than the 71-72s, & the 63-70s were too short & had the wrong taper And the 3/4T ones are just way too big So we have called Mario at CPP several times today & dad is sending him some pics of the problem |
#123 |
Re: Killer
So when did they start to re-pop the 67 fenders?
Kevin LFD Inc. |
#124 |
Official Site Guitar Shredder
Re: Killer
I have had my 67 fenders (re-pop) for about 4 years now....And spraybomb its looking good......Keep it up.....
#125 |
Texas Big Wig
Re: Killer
Man I wouldnt even be able to tell you
But I can tell you that my fender is NICE !!! I cant wait to see it on the truck to compare it to stock |
