10-26-2008, 10:11 AM | #1 |
1970 C10
700r4 on a stock auto crossmember?
Can a 700R4 bolt on to a stock automatic crossmember or would it better to go with a CPP crossmember?
Thanks! |
10-26-2008, 10:16 AM | #2 |
Re: 700r4 on a stock auto crossmember?
I used the one from CPP it looks a hell of alot better.....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
10-26-2008, 10:18 AM | #3 |
1970 C10
I was looking into getting that one from cpp, how has it been for you?
10-26-2008, 10:23 AM | #4 |
its all about the +6 inches
you can use the stock one. Relocate it and drill holes.
10-26-2008, 10:25 AM | #5 | |
It is perfect so far!!!! I had some tranny issues this past week so I had it in and out three times this past week but finally the tranny is finished.
10-26-2008, 10:42 AM | #6 |
chevy truck fan
i agree with longhorn man i just had to relocate mine & drill 4 new holes. i was able to use 4 existing holes. it was pretty simple. i took my original & had it powder coated, i think it was is cheaper then buying a new one. although i agree that the cpp ones look very good as well.
good luck! |
10-26-2008, 11:16 AM | #7 |
alot cheaper to use stock crossmember//in all the years of having classic vehicle i've found that about 1 in 50,000 people that look at them will actually crawl under them to see what my crossmembers look like
10-26-2008, 11:23 AM | #8 |
Son of a gun
I agree with lhm and cdowns, use your original. Save the coin for something tricker
Bill BEATERS ARE NEATER |
10-26-2008, 12:14 PM | #9 |
1970 C10
Well i originally had a 3 on the three, so either way i need a new one.
i can get a stock style for about $30-40 and the cpp is about $80 |
10-26-2008, 02:09 PM | #10 |
Honestly, I would think that 30 - 40 is too much for a greasey used piece... however, i know for a fact that these suckers are getting hard to find in wrecking yards in this part of the world. (ohio)
10-26-2008, 02:33 PM | #11 |
1970 C10
I was thinking that is pretty pricey, so thats why i looked into CPP, since im starting from scratch i guess i should go ahead and spurge for once!
10-26-2008, 06:05 PM | #12 |
Sisyphus was my mentor!
I JUST was trying to get one of these out at the wrecker on friday & the bolts in there are rusted solid! I couldnt get that x-member out of there to save my life. I had a revelation there under the truck - "Screw this!" The little voice said to me, "...dig out some 2" by 3" tubing, a bit of plate & make your own!" It cant be that hard. I'll post pics when it's done...
passthebuck #5642 -TWO 1967 GMC 910's. One with L6/3-on-the tree and the other with 355 w/435hp & a 700r4. -a 2013 Honda Civic as my "sensible" car Last edited by passthebuck; 10-26-2008 at 06:07 PM. |
10-26-2008, 06:08 PM | #13 |
1970 C10
well i found a new CPP crossmember on ebay for $70 shipped i think thats a good price, so if i can get it for that i think i will. That will get me one step closer to getting this project moving.
and i think (in a while) i will make a build thread of this crazy project that i have learned a lot on. |
10-26-2008, 07:08 PM | #14 |
1970 C10
Also can a 700R4 be used with a stock automatic steering column? i got a nice extra one i would really like to use and not cut my floor to put in a floor shift.
Thanks! |
10-26-2008, 08:26 PM | #15 |
Tot Roddin'
You just need to purchase the correct linkage and a different indicator from what I've read. And you'll be able to keep your stock column.
I'll hopefully be doing this swap to my '72 in the future.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 10-26-2008 at 08:28 PM. |
10-26-2008, 08:34 PM | #16 |
1970 C10
10-26-2008, 08:40 PM | #17 |
Tot Roddin'
A lot of people are using Lokar items... (tv cable and things).
I was just on ECE's (Early Classic Enterpriese) website and they are offering a kit (transmission crossmember and all the linkage and parts needed). I have never used this kit, but these guys know what they are doing. I'm planning on ordering from them in the near future.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 10-26-2008 at 08:40 PM. |
10-26-2008, 08:42 PM | #18 |
Tot Roddin'
ECE's kit includes:
KIT INCLUDES CROSSMEMBER, RUBBER MOUNT, STAINLESS SHIFT LINKAGE, ADJUSTABLE VACUUM SWITCH AND HOSE, LOCKUP SOLENOID, PRESSURE SWITCH, AND ALL NECESSARY WIRING AND HARDWARE All for $299
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
10-26-2008, 10:40 PM | #19 |
I used the stock linkage on a 72 GMC I put a 700 in a few years ago. It worked great. I put it in place of a 400. I'd say just get the indicator the adjust the linkage at the bottom of the column and it will work.
1970 Nova 327/T5 (my 1st car) 1971 K-20 350/350/205 (winter DD) 1953 GMC Suburban 1968 Chevy Bel Air 1976 Chev C-10 1972 Skylark (suncoupe) 1 of 3943 made |
10-27-2008, 03:08 AM | #20 |
Moderator
Go with Kugel Komponents linkage, You can get it for $50 at www.truckandcarshop.com I have a 700 R4 trans coupled to a stock 350 and am using it You can also get the overdrive indicator and this linkage is adjustable so that it will line up correctly. It is VERY easy to install and will save you a TON of headaches. You might be able to get it on Feebay cheaper. It is very similar to Lokar and is made in America.
10-27-2008, 03:13 AM | #21 |
Moderator
Here is what mine looks like
10-27-2008, 03:17 AM | #22 |
Moderator
You will also notice that I have no indicator, as I broke it when I removed the housing to replace the bulb. But, prior to that, it did line up perfectly and I was able to dial it in and shift all the way down into 1st gear
10-27-2008, 08:02 AM | #23 |
Tot Roddin'
Thanks for the pics leddzepp!
10-27-2008, 11:45 AM | #24 |
Moderator
Thank you for your pic! The linkage in the ECE pic you posted IS the Kugel Komponents linkage...or if it is not, it is identical. The slotted arm (very lower right hand corner of your pic) that attaches to the transmission allows you to adjust shift throws and that is why you are able to dial in your shift indicator. It also only has two pivot points, and it will eliminate ALL of the slop you may have in your factory linkage. You will also be able to adjust your neutral safety (backup lights) switch so that it continues to function properly.
Here are some pics of it installed on my truck: Last edited by leddzepp; 10-27-2008 at 12:38 PM. |
10-27-2008, 01:58 PM | #25 |
1970 C10
Thanks for all the info and pics, now i feel alot better going into this process, and feel i can actually get it done, and done right!
just one more question where you get the indicator can it also be ordered through truckandcarshop.com? Last edited by bmrrwolfe; 10-27-2008 at 02:03 PM. |
