Old 01-19-2002, 06:29 PM   #1
worldofme
Post couple questions
what are the most common sources of an oil leak? I've got a 77 Blazer and I need to replace the hood. What year of truck/blazer can I take a hood from to replace my current one?
worldofme is offline   Reply With Quote
Old 01-19-2002, 07:23 PM   #2
72chevyLWB
Got 20's????
72chevyLWB's Avatar
Post
The hood will interchange from 73-79. Make sure to buy a brace kit so it doesn't kink though. Oil leaks will be common from the valve cover gaskets. Also front and rear main seals. What area is it leaking from?
72 Chevy C/10
87 Chevy Silverado 4X4
www.geocities.com/chevylwb/chevylwb.html
99 Silverado Ex-Cab 2wd, Bagged&WhippleCharged
02 Sierra Ex-Cab 4wd 2500 HD
The 72 went down the road.
72chevyLWB is offline   Reply With Quote
Old 01-19-2002, 08:54 PM   #3
worldofme
Post
the leak appears to be coming from the rear of the engine and somewhat on the side. I'll be replacing the valve cover gaskets this week to see if that helps any.
thanks for the hood info.
Old 01-19-2002, 11:44 PM   #4
crossy
Oh,you can't buy that new
crossy's Avatar
Post
73-80 hoods will work , the 79&80 only had that little raised area across the front and all the aftermarket ones have it also. watch the latches though as the inside release type were totally differnt latches. DAVE
with all the rocks that I turn over I should be finding more than slugs!
[This message has been edited by crossy (edited 01-19-2002).]
"been there, done that, ruined the T-shirt".
2007 LBZ GMC Sierra, ECSB
2006 LM7 RCSB Silverado
98 Vortec project.
94,3500,6.5L 4L80
81 SWB GMC POS finally gone
73 Pinto, stock, w/CragarSS's-eww
LOTS of Cummins trucks.
crossy is offline   Reply With Quote
Old 01-20-2002, 12:58 PM   #5
misfits
misfits's Avatar
Post
make sure your oil pressure sending unit isn't leaking.
misfits is offline   Reply With Quote
Old 01-21-2002, 11:16 PM   #6
Fast68Chevy
Fast68Chevy's Avatar
Post
misfits has a really good point there, the sneders can leak badly!
A 68 C-10 panel and a 68 dually C-30 dump truck and a couple 71/72 chassis projects.
Randy- Lincoln, IL
r68c30@hotmail.com http://messenger.msn.com <A HREF="http://communities.msn.com/196772ChevroletCSTsforever
" TARGET=_blank>http://communities.msn.com/196772ChevroletCSTsforever
</A>
Fast68Chevy is offline   Reply With Quote
