Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 01-06-2009, 01:17 AM   #1
70stroker
70stroker's Avatar
bbc s10
how much harder is it to bbc a s10 rather than sbc one? can it be done with out crossmember mods and such?
70stroker is offline   Reply With Quote
Old 01-06-2009, 01:29 AM   #2
87c10slammer
truck addict
Re: bbc s10
i dont think its so much the high but the width... bbc are crazy wide and to get them between the frame rails would need alot of fab skills... but i would love to see it personally.. what gen s10?
87c10slammer is offline   Reply With Quote
Old 01-06-2009, 01:42 AM   #3
70stroker
70stroker's Avatar
Re: bbc s10
1st gen its a 87. i just bought a slammed s10 with a rod knocking v6 and have both a sbc and bbc sittin in my shop i would love to bbc just wondering if it could be done.... has anyone seen this swap...
Old 01-06-2009, 03:03 AM   #4
454_72_4X4
454_72_4X4's Avatar
Re: bbc s10
I've seen one a few years ago. I really never got a chance to look it over good, but I don't think it had any frame mods. Maybe around the starter but otherwise I doubt it.
With the right oil pan, I see no need for frame mods. Most of the width of a BB is above the frame rails. The one I seen had stock cast iron exhaust manifolds, and really didn't seem much more crowded than a SB S10 to look at it.
I mean as far as working on it, it seemed like it'd be about like a SB truck.
Depending on the exhaust ya choose, that area may require some frame massaging, but I couldn't say for sure.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 01-06-2009, 11:30 AM   #5
Dying2Live
Dying2Live's Avatar
Re: bbc s10
I've only done sbc conversions, but there's a guy down the road that had to do extensive firewall work. He finally decided to make it a strip truck because of the hassles he faced. I keep hearing 2 different stories on the bbc conversion. Try this link, it has a wealth of information including part numbers and what not for a clean factory looking BBC in a 1st gen s10
http://www.s10forum.com/forum/f10/1s...lation-223375/
Dying2Live is offline   Reply With Quote
Old 01-06-2009, 11:45 AM   #6
Skirkpat
Skirkpat's Avatar
Re: bbc s10
Small blocks barely fit...Big block is a dream, and definately would involve MAJOR fabrication unless you run your exaust through the hood lik a pulling truck. You can build a small block with as much power, cheaper and still have about a hundred pound weight advantage. my.02
Skirkpat is offline   Reply With Quote
Old 01-06-2009, 02:18 PM   #7
87c10slammer
truck addict
Re: bbc s10
well if its an 87 then you have all the room in the world and it shouldnt take much to fab up some mounts for everything... i was thinkin more along the lines of a early 90s+ blazer for some reason.. maybe im still stuck over at s10forum.com... they might be able to answer you question a little better since they have a 1st gen spacific forum..
Old 01-06-2009, 03:29 PM   #8
Dying2Live
Dying2Live's Avatar
Re: bbc s10
But why build what everyone else has?? I'm all about building what I want to drive... Good luck, and I hope you go thru with the BBC build.
Old 01-06-2009, 04:18 PM   #9
87c10slammer
truck addict
Re: bbc s10
agreed
Old 01-06-2009, 06:49 PM   #10
nvrsatisfied
nvrsatisfied's Avatar
Re: bbc s10
do it. it may take time, you may loose all your hair, your gonna have your ups and downs but when said and done an s10 with a big block will stand before you
here is some inspiration.......get to work
http://www.minitruckinweb.com/featur...zer/index.html
http://rides.webshots.com/album/559709504pmJxMV
http://sporttruck.automotive.com/968...s10/index.html
Lug Nuts Classic Rides. (Bodywork, small fab, and Restorations)
Perry, Ok.
We're just two guys, trying our best.
72 cheyenne super
https://67-72chevytrucks.com/vboard/...d.php?t=811512
55 chevy truck
http://67-72chevytrucks.com/vboard/s...d.php?t=840174
nvrsatisfied is offline   Reply With Quote
Old 01-07-2009, 07:53 PM   #11
70stroker
70stroker's Avatar
Re: bbc s10
as far as bbc weighing more and all that i dont think it matters. ya you can build a same hp and tq sbc as a bbc, but bb are way more fun in my opinion and with the same power its gonna be way more streetable. after i took out a built 383 outta my 70 gmc and put a mildly built bbc in it was still way more fun. ill never do sbc again
Old 01-07-2009, 11:50 PM   #12
blazer72
Freedom isn't Free
blazer72's Avatar
Re: bbc s10
check this site out:
www.s10v8.com
blazer72 is offline   Reply With Quote
