01-04-2009, 12:51 PM | #51 |
Re: 65 Old School Build on a Budget
old school kid... like the ride, and the quote at the bottom of your profile .I'm watching Barret Jackson right now, how in the heck do people buy a car for 150,000 bucks? keep it real...
01-04-2009, 01:04 PM | #52 |
Rottenwood Garage Member..Yes!
Apeking, saw your truck a few weeks back on here, love that color..... Ditto goes for you if you need a hand... I'll keep my out for a crazy guy on a HD on 20... I'll probally be on my Ultra Classic,,,, Stupid Rain!!!
When interests become diversified, not all can be Barrett Jackson. Budgets and Accountants get in the way. My 65 (SOLD) http://67-72chevytrucks.com/vboard/s...d.php?t=317013 My 51 (SOLD) http://67-72chevytrucks.com/vboard/s...80#post3551880 Racetruck III (SOLD) http://67-72chevytrucks.com/vboard/s...72#post4254972 Rottenwood Garage and Speed Shop.....where everything must be racy! Gone to dark side for a while...1966 F100 in the stable |
01-04-2009, 01:06 PM | #53 |
Roger that Dadredwagon! They gotta stop showing that on tv, maybe DVD... Everyone out there thinks their pile of junk is worth a mint..... oh well, old story!
01-04-2009, 07:36 PM | #54 |
Any ideas what other parts I could use from the cruck? Thanks, I don't think I can use anything else, but just want another opinion... Thanks
01-05-2009, 07:28 PM | #55 |
Trailers are for BOATS!
I work in buckhead and blast down 20 to work daily. If the weather isnt too terrible Im on my Ape King.
The Rod Barons
C.C. CSA Last edited by ApeKing; 01-05-2009 at 07:29 PM. |
01-06-2009, 11:59 AM | #56 |
TexasBowhunter
Very nice truck!
Build in progress for son's first truck. |
01-06-2009, 09:07 PM | #57 |
Well I've searched all the forums.. I'm getting ready for my inline 6, 3 on the tree to a v-8 350 turbo set-up. I'm making my list and wanted to see if you guys would mind reviewing it..... Thanks
1. Order- bolt in motor mount bracket kit (tubular) bolt into existing holes in frame? 2.Remove current inline 6 rear motor mount bracket( the whole thing from frame to frame? not just the center portion? slit and pop rivets) 3. Oder-new bolt in tranny crossmember mount... (the truck currently has a brace that goes from frame rail to frame rail that the 3 speed is currentlly going over but not attached... Do I remove? use? or go over it also with t350?) 4. Order-Hedman Mid length headers 69260? I know I know lots of questions.... Just gettin excited and want to start ordering some parts..... Again thanks for reading and any input would be helpful....
01-06-2009, 09:32 PM | #58 |
actually a s/10 cap 89 i believe
01-06-2009, 09:40 PM | #59 |
Resistance is Futile
O/S/K.....if you can fire up that Camino and check the brakes, I would steal the booster and ms/cyl in a second. Put it in your truck and plumb it. If the parts go bad use them as core for new, and you know what they came out of also. ( You know how the parts guys are......bench or bucket seat? Cig lighter and 8-track? 4wd?)
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
01-06-2009, 10:32 PM | #60 | |
1 thing at a time is progress.
Alan
Philippians 2:14-16 |
01-15-2009, 09:25 PM | #61 |
Thnaks Protrash64 and Allan......Getting ready to pull the motor in the El Camino this weekend.. Will be taking the t350, brake booster, master cylinder and a few other odds and ends... Should work out pretty well...
Finally recieved the shocks that I ordered, took about 3 weeks... grrr Anyways very happy, ended up going with a budget Pro-Comp Toxic shock. They were around $30 a piece. I was having trouble waiting and went for a few rides with no shocks at all, yikes! Shocks are installed and work great (compared to nothing at all, really do work well) they will work just fine for my application and the price was right.. While jacking the truck up to install the shocks, I thought that I would try and figure out what rear gears I had. (Inline 6, three on the tree ,open differential) I marked the tire with a piece of tape along with the drive shaft, rotated the tire one full turn and the drive shaft turned just shy of 2 complete turns??? 3 3/4 turns = 3.73, 3 plus a fuzz = 3.08 ??? I was told this was a good rule of thumb, yes or no? What gears do I have? Chased Down fellow forum members truck the other day, thanks again Mike for all the great info...
01-15-2009, 11:28 PM | #62 |
No problem O/S/K. I enjoy looking at the progress and it keeps my dream alive of one day having a DD 60-66. Good luck with your swap.
01-17-2009, 07:23 PM | #63 |
Pulled motor in the El Co today... Found a crack in the block... Not real happy.....
You must be a subscribing member to post WTB questions.
When interests become diversified, not all can be Barrett Jackson. Budgets and Accountants get in the way. My 65 (SOLD) http://67-72chevytrucks.com/vboard/s...d.php?t=317013 My 51 (SOLD) http://67-72chevytrucks.com/vboard/s...80#post3551880 Racetruck III (SOLD) http://67-72chevytrucks.com/vboard/s...72#post4254972 Rottenwood Garage and Speed Shop.....where everything must be racy! Gone to dark side for a while...1966 F100 in the stable Last edited by LONGHAIR; 01-19-2009 at 08:04 PM. |
01-19-2009, 10:36 AM | #64 | |
01-19-2009, 11:31 PM | #65 |
Have you ever heard of marking the tire, rotating and counting the drive shaft turns? One wheel turn = almost 2 drive shart tuns?
01-20-2009, 11:39 AM | #66 |
I have heard of rotating the tire and counting driveshaft revolutions, but less than 2 turns of shaft for every turn of wheel doesn't sound right, I don't think.
01-20-2009, 09:02 PM | #67 |
Thats what I thought, It turned 1 7/8... I did it about 10 different times... Wonder if someone in the past changed it with plans of taking it to the autobahn....
01-22-2009, 09:11 PM | #68 |
Correct me if I am wrong but the method you are using to figure the gears is different based on posi/non posi. For posi you will have exact turns of the yoke you count while it will double if it is a non posi. So your 1 7/8 would tell me you are closer to 4.. 3.73 probably.. If it was a posi rear then you would have had almost 4 full turns on your yoke.
Skez Last edited by 72bigred; 01-22-2009 at 09:15 PM. |
01-22-2009, 10:08 PM | #69 |
The sure fire method is to pull the pumkin cover and divide the number of teeth on the ring gear by the number of teeth on the pinion gear, this will give you an accurate gear ratio.
01-25-2009, 10:09 AM | #70 |
Thanks 72 Bigred, That makes more sense....
Thanks Also Lilred66, I will definatley do that when I pull the cover... Slow but sure, one step at a time.....
01-25-2009, 10:19 AM | #71 |
The number of both teeth should be stamped on the ring gear. It might be something like 43 14. 43 teeth on the ring gear and 14 on pinion.
Alan
01-26-2009, 04:41 AM | #72 |
1964-66 chevy trucks came standard with the3:73 rear axle.on the g.m. spec. book that i have.3:07 and 4:11 were optional.the 1964 and 1965 trucks optionally had a package called economy package with the 230 i-6,standard 3-speed tranny,and the 3:07 rear axle.i have not seen this package on the 1966's in the g.m. book.best to take the other guys advice pull it off and start counting teeth.also i discovered on the 64's i've owned that on the rear axle tube from viewing from the rear on passenger side they have a code stamped in them,never saw the code stamped on 65,or 66.my 2 cents worth.
02-08-2009, 08:25 PM | #73 |
Thanks guys, I will pull the cover sometime in the near future to install a new seal and will use the true method of counting the teeth... I'm thinking 3.73 (no stamps on the axle)
Well the motor build process continues. Just getting all my ducks in a row and trying to determine the biggest bang for my buck. The other day when I took the Hell Camino to the junk yard, my truck gurue buddy spotted a step bed. I 've always been a fan of the fleetsides on these trucks but the current bed was falling apart and had a steel plate in the bottom. Robbing HP from the weak inline 6. The bed had no tailgate but is in great condition. $80 dollars later we left with the bed and a rear chrome bumper... Now I just have to find a set of brakets... Already have a line on a tailgate... All in all very happy with the find.. Mounted it today, couple coats of Krylon satin, flush mounted the fleetside tail lights ( thanks to bird7263, hope you don't mind ) looks great. Here is a picture just before it got dark. Lights were just taped on for motivation, once I took a look I pulled out the saw..
When interests become diversified, not all can be Barrett Jackson. Budgets and Accountants get in the way. My 65 (SOLD) http://67-72chevytrucks.com/vboard/s...d.php?t=317013 My 51 (SOLD) http://67-72chevytrucks.com/vboard/s...80#post3551880 Racetruck III (SOLD) http://67-72chevytrucks.com/vboard/s...72#post4254972 Rottenwood Garage and Speed Shop.....where everything must be racy! Gone to dark side for a while...1966 F100 in the stable Last edited by Old School Kid; 02-08-2009 at 08:26 PM. |
02-08-2009, 08:54 PM | #74 |
Nice score! It's lookin' good
Alan
02-08-2009, 09:57 PM | #75 |
Hey Y'all!!
Just hopin' I live long enough to finish something!!! |
