Old 01-12-2009, 11:44 AM   #51
VA72C10
VA72C10
VA72C10's Avatar
Re: It’s Just A Pickup
As always, nice work...
Old 01-12-2009, 01:05 PM   #52
1LoC10
Insert Title Here
1LoC10's Avatar
lookin good
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 01-12-2009, 02:34 PM   #53
LEEVON
LEEVON's Avatar
What's that they say..."He's got mad skills!"
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
Old 01-12-2009, 03:54 PM   #54
c10addict
c10addict's Avatar
Subscribed... Nice work!
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 01-12-2009, 05:01 PM   #55
noteron
noteron's Avatar
Killer thread...I dig your work OG
noteron is offline   Reply With Quote
Old 01-12-2009, 05:11 PM   #56
see ten
WTB this ad
see ten's Avatar
Good job! Keep it up!
see ten is offline   Reply With Quote
Old 01-12-2009, 07:51 PM   #57
smbrouss70
smbrouss70's Avatar
You have some good ideas, and the skills to pull them off. Good Job!
Steven
"If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers
R.I.P. Oscar
R.I.P. Ratchet
1967 Pontiac GTO - Dad was the Original Owner
1970 Chevy 2wd SWB "Oscar's Truck"
1970 Chevy 2wd Blazer "Ratchet's Blazer"
2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar"
2017 Chevy Suburban "BDB"
2020 Chevy Blazer Premier "Foxy"
Shop Build
smbrouss70 is offline   Reply With Quote
Old 01-12-2009, 08:20 PM   #58
bobshotrodblazer
BigBlockBobby
You have given me alot of ideas on my project. Nice work.
Bob
bobshotrodblazer is offline   Reply With Quote
Old 01-24-2009, 10:34 AM   #59
Bruce88
Bruce88's Avatar
All the little things that take time and effort to do and others will not no about or think of after the project build is complete but definitely make every thing work right and last for years to come.
I picked up some 36-4407 LMC Clear Parking Light Lenses with amber bulbs to rebuild the parking lights. The mounting nut plates for mounting the light assembly where broken replaced them with clip on nut plates. Sandblasted and painted the housing black to fit in with the black powder coated bumper. The stock shoulder screw (see insert pic of screw) would not hold the lens tight to the frame seal replaced them with #8-32 1-1/2 long stainless steel screws and locking nuts to prevent them from backing out.
You will notice an extra wire installed on the back of the light assembly, it’s a grounding wire I installed. With all the powder coating and painting of parts the grounding of electrical parts can be compromised so I’ve found throughout the years that adding a ground wire keeps everything working good for years to come. Also on grounds I install that are exposed to the weather I seal them with Permatex 2 form a gasket sealant to prevent corrosion and failure. The sealant stays sticky for days and is like a tar substance preventing water and air corroding the connection. Note, would not recommend using a silicon/RTV type sealant to seal grounds the sealant has a small amount of acid base that has shown ground failure over time in the aircraft industry.
When I pulled the heater housing the heater core was leaking, the diverter valve was packed with pine needles and debris (probably the cause of the broken lever in the heater control that I replaced) and the fan motor did not sound very good when running.
Parts used in rebuild
32-2525 LMC Heater Core
36-0565 LMC Heater Seal Kit W/O AC
32-2420 LMC Blower Motor
32-2090 LMC Heater Fan
3M 1/4 inch glass Ribbon Sealer (see insert pic of bulk seal)
After disassembly and cleaning painted the housing with VHT Satin Black Epoxy Paint.
Decided to use the glass ribbon sealer instead of the factory clay like seal, it sits in the grove in the housing and holds the rubber seal in place good. Also used the ribbon seal to seal around the heater core hose connections. Now it can be set in storage ready for installation in the future.
Mounted the TCI transmission cooler and fabricated some aluminum tubing on the 32-2932 LMC Radiator 3 Row Cooler. Will have to cut two notches in the radiator support to clear the tubing.
I haven’t finished the taillight concept at this time because I’m waiting for my friends to have some free time to help with the welding. I’m not the best at welding thin metal and like to use a copper backing plate to prevent burn thru and that requires a third hand I don’t have at this time. But I’ve been keeping myself busy with other things that need to be done. Will keep you updated as the taillight concept progress, hopefully in the next post.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=318544
Bruce88 is offline   Reply With Quote
Old 01-24-2009, 11:16 AM   #60
VA72C10
VA72C10
VA72C10's Avatar
As usual, looks good...
Old 01-25-2009, 03:44 AM   #61
vk_chevy
vk_chevy's Avatar
I really like the details on your build, it's amazing.
72 Chevy C20 Longhorn
72 Chevy, K20 Custom Camper
67 Chevy, LWB, C20, 350/350, PS, PB,
65 Jag MKII
vk_chevy is offline   Reply With Quote
Old 01-25-2009, 10:18 AM   #62
dfwright
dfwright's Avatar
Thanks for posting the detailed pictures and listing all the part numbers and where you got them -- this is great information for those of us still figuring out what to do!
dfwright is offline   Reply With Quote
Old 01-25-2009, 03:46 PM   #63
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I have to admit that I don't check this forum as often as i should.I however will be doing so in the future.You build thread has served to help me get my momentum back and I appreciate that.As for your spelling,whatever you're doing has worked.I can read and understand all of it.I haven't been to check your work in the FAQ's but can already tell it is a positive contribution.
Your truck has some great ideas and outstanding execution so don't stop with what you have already contributed.Some of the minor things you have shown are things others never think of until they get in the middle of a build.Better planning always results in a better outcome(except militarily).
I think you are building one heck of a nice mild custom styled truck with lots of attention to detail and great worksmanship.Those who know will just know and those who don't will not notice.Keep up the great work.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 01-25-2009, 10:45 PM   #64
Bruce88
Bruce88's Avatar
Thanks to all for the positive and encouraging posts it’s definitely appreciated by me and helps keeping the build progressing even at my slow pace. I also find it enjoyable that some will find inspiration or ideas for their own build, I must be doing something right. I wish I had more time to view the other build threads on this forum, from what I’ve seen there are plenty of good build’s going on with some very talented people performing the builds.
Old 02-09-2009, 07:45 PM   #65
Bruce88
Bruce88's Avatar
The Good, the Bad and the Ugly or from another Clint Eastwood film A man’s got to know his limitations.
Sometimes it seems I spend more time on the road between places to find parts and services that I need accomplished than working on the truck. (Na it just must be me)
I apologize for the pour pictures of the bumpers they really look pretty good. After sandblasting and powder coating I installed the swing up license plate (would not recommend the swing up license plate to any one that just wants a bolt on installation. It took me two days of re-engineering and modifications to get it to work) Decided to try some LED bulbs in the backup lights, I don’t know a lot about the LED bulbs except that the ones in my flash light are pretty bright, if they don’t perform good Ill just change back to the stock bulbs. I did find some stainless steel license plate frames that are powder coated black by Camisasca and with the thin design look and works well. Now I can say that I have a compete rebuild bumper to bumper less a few miner parts. HA HA
The tailgate on the truck had definitely been worked hard in the past and fell in to my category as bad and needing more work than I wanted to put into it. So I picked one up from MAR-K part number 102840 Tailgate “CHEVROLET” Script No Chain Latch. This will be my next area of work to install the Tailgate Link Straps and the Bear Claw Latches. It will definitely give the people in my rear view mirror a nice truck rear end to look at.
Finished welding in the stop light buckets in the fenders and spent half a day removing the tar undercoating in one of the fenders. Was talking to my sandblaster and it was recommended to remove the undercoating I could use a propane torch and a putty knife to remove the majority of it and save on the stripping cost (it worked pretty good not a lot of heat but defiantly a job you want to do outside with the smell and fumes).
I’m going to be installing a side mounted spar tire and wanting the cutout in the fender to look a little better than the lapped over spot welded panel. So I welded the complete seam, it’s kind of ugly but with some bondo with fiber it should blend in with a slight rounded look, hopefully better than the spot welded panel.
Since the truck will be used for hauling things it’s always nice to have places to tie things down to and having used the Track & Tie Down Anchors in the Air Force it was only fitting to install some in my truck. Obtained the Track & Tie Down Anchor Kit and 4 Ring Kit from Discount Ramps.COM. I will be installing the Tracks halfway up the bed sides and the individual mounts in the corners near the top of the bed. I’m lucky to have a good place close to get my fasteners from (Tacoma Screw Products, Inc.) and they usually have just what I need. The tracks will be mounted with Stainless Steel Allen Head Counter Sunk M6 x 20MM fasteners (note American standard fasteners will not sit flat enough in the counter sink for ring to be located over them)
When I was out and about I think that I’ve found a body and paint shop that will work with me where they will take the individual sandblasted panels and take them from miner body work to finished paint and then I will assemble the peaces. So in the next one to two months I expect to hand over all the bed panels to them and see how it works out for just the bed before starting them on the cab and front end. Personally I would like to do the body work and paint myself but with lacking the space and equipment I’ve decided to turn it over to a professional that has all equipment and space. The color has been finalized 505 GM green with black along the bottom just the same as in the starting pictures. Anybody having any ideas or recommendation for the interior color with the grey seats would be appreciated.
With the tight confines of my work shop I tripped over some stuff and fell the other day, no broken bones but some very pretty purple and soar bruises, so I will be taking a week off from working on the truck for recovery (age doesn’t work in your benefit in regards to recovery). Everybody stay safe out there in their small shops for things will jump out and get in your way.
Old 02-09-2009, 08:21 PM   #66
texanidiot25
Eat My Rust
texanidiot25's Avatar
Looks excellent. Love all the hidden and hindging tricks with the lights and plates.
texanidiot25 is offline   Reply With Quote
Old 02-09-2009, 11:05 PM   #67
VA72C10
VA72C10
VA72C10's Avatar
Great work!
Sorry to hear about the fall....Glad it wasn't worse...Hope you're back up and out in the shop soon providing more great pictures and writeups.
Old 02-11-2009, 05:37 PM   #68
Otsa580
I Love Rusty Chevys
Otsa580's Avatar
Great looking build and all the best on a speedy recovery!
Otsa580 is offline   Reply With Quote
Old 02-22-2009, 05:26 PM   #69
Bruce88
Bruce88's Avatar
The concept evolves, where function and aesthetics work out a compromise.
With using the small bear claw latches to hold the tailgate closed I decided they needed to be covered so that the majority of the latch just doesn’t hang out on the side visible to all. Went through a number of concept thoughts of how to accomplish this and think I found one that works for me (let me know what you think)
I took a lot of pictures as I progressed thru this modification and rather than have a wall of text to describe all the pictures I decided to incorporate some of the text into the pictures. Not that this is a “How To” just wanted to share my thoughts and work that went into this modification and a little self pride in this accomplishment HA HA.
What I started with and working in the concept with mockup’s
I saw on another web site about building up a weld on the edge of the metal and thought I could use this idea. I’ve never done this before and with my less than steady hand decided to use a wood template my neighbor made for me as a guide.
Fabricating the end plate’s
Welding, grinding, drilling and cutting (O-MY)
More welding and finish work is required but I think you can see how the finished area will look
My next area of work is welding up the stake pockets, finishing up the welding on the end covers and approximately 18 other holes in each of the bed top surfaces and sides (I think this truck has had more than one cover installed on it over time with all the drilled mounting holes)
Another couple of weeks have been written into the books and the progress is moving on no mater how slowly
Old 02-22-2009, 06:01 PM   #70
texanidiot25
Eat My Rust
Excellent work man, diggin' the details
Old 02-22-2009, 06:02 PM   #71
VA72C10
VA72C10
VA72C10's Avatar
Awesome writeup...If I ever get a stepside, I will definitely be doing this...
Old 02-22-2009, 09:34 PM   #72
Very Nice!!
Palf70Step is online now   Reply With Quote
Old 02-23-2009, 12:02 AM   #73
allen123
It'll buff out
allen123's Avatar
nice build
subscribed
1972 Chevy c10 swb
2008 CBR600RR Grafitti edition
My Build
Cody Allen
allen123 is offline   Reply With Quote
Old 02-23-2009, 12:49 PM   #74
glimmertwin01
glimmertwin01's Avatar
Good show!!!!
67/68 K/20 "The BEAST"
68 K15 V6 LWB.
73 K20 GMC Burb "The Bomber"
74 K/5
74 K20 Custom Deluxe
86 K10 Shorty
92 K2500 Burb
95 K2500 GMC
Life is what you make it Live each day like it was your last
Old GM Trucks never go out of style
glimmertwin01 is offline   Reply With Quote
Old 02-23-2009, 03:21 PM   #75
my67chevytruck
Under Construction
my67chevytruck's Avatar
very good work. Keep at it.....
Heath
subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php
http://67-72chevytrucks.com/vboard/s...d.php?t=157669
FAQ how to's
1956 Chevy Apache
1967 C10 SWB FleetSide (under construction)
1969 K10 SWB FleetSide (Future Build)
1972 C10 SWB Stepside (Future Build)
56 chevy truck :
http://www.cardomain.com/ride/2955823/1
67 truck build:
http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1
69 k10:
http://67-72chevytrucks.com/vboard/s...d.php?t=389470
my67chevytruck is offline   Reply With Quote
