Old 01-12-2009, 03:07 PM   #51
kcjones
I wish I was a cowboy
kcjones's Avatar
Re: Header Solution
Originally Posted by Jokers69 View Post
Still on sale any takers?
I apologize, but so I know: What is the price (exluding shipping, I assume) of the 1 3/4 primary 3" collector, non-stainless coated headers? And what is the price if I have to wait til mid-March to order? And where are they shipped from? Trying to budget...
-Kris
Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway).
kcjones is offline   Reply With Quote
Old 01-12-2009, 03:16 PM   #52
Re: Header Solution
They will not work on manual transmisson with factory clutch linkage
Counts me out.All they needed was the left rear tube to come straight down,or better yet,angle ever so slightly forward and they`d fit them all.
Old 01-12-2009, 04:20 PM   #53
Slik69
Re: Header Solution
Will they work on a manual that was switched to automatic, but the clutch linkage still in place. I believe I can just remove the linkage, not sure why previous owner left it there.
How much and aren't most headers you guy non stainless. How much for them. I know the price was listed up...
Thanks, these look good. I shy'd away from headers because I didn't want to see them and the pipes (for that matter), from the sides.
Have you guys done any research on flow characteristics/improvements to other products or do you care not too? I ask because I was interested if any tunability is factored into making them. If so, this is a very hot header that can be used for guys more on the high performance side as well.
Slik69 is offline   Reply With Quote
Old 01-13-2009, 01:27 AM   #54
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
The price is $865.00 for them coated. But they are on sale for $75.00 off for a limited time. I don't know at this time for how long. They will be shipping from Kent,Washington. Let me know if you have any other questions.
Jokers69 is offline   Reply With Quote
Old 01-13-2009, 01:39 AM   #55
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
Yes they will work if you remove the clutch linkage. They are $550.00 bare , $865.00 coated and $975.00 stainless and $75.00 off at for a limited time. These header where designed to not hang below the frame rails with big primaries and long tubes. We have not done any testing as of yet.
Old 01-13-2009, 02:01 AM   #56
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
We didn't have access to a manual trans truck when we where building them. I had them custom build for my truck and when they turned out so good I thought I would offer them to the board members with the same setup (or close to the same setup) . It is not the rear tube that is the problem. It's where the #1 tube comes down that will interfere with the clutch linkage.
Keisler Auto sells a Hydraulic clutch setup that will work with our headers. I know that not everyone will want to spend that additional money just to run these headers. But it's just another option.
Old 01-25-2009, 02:22 AM   #57
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: Header Solution
Bump for coolness
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 02-08-2009, 10:53 PM   #58
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
Bump
Old 02-09-2009, 12:24 PM   #59
TCASON
TCASON's Avatar
Re: Header Solution
I have mine, freaking awesome!
Just waiting to put on the new Edelbrock mani and carb, switch out the tranny for the 700r4, with the new lokar linkage and I'm set.
My truck is going to have a heart attack!
TCASON is offline   Reply With Quote
Old 03-08-2009, 04:09 PM   #60
coast2coast
coast2coast's Avatar
Re: Header Solution
Jokers69, I don't mean to hijack your thread, but what motor mounts are you running with the cpp stands?
coast2coast is offline   Reply With Quote
Old 03-08-2009, 06:18 PM   #61
AJs72K5
AJs72K5's Avatar
Re: Header Solution
Any word on big block?
- AJ
Gray Matter Build - 1972 K5 with some stuff
AJs72K5 is offline   Reply With Quote
Old 03-09-2009, 09:20 PM   #62
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
The motor mounts are the poly ones cpp sells. Still working on big block ones. We need a truck with a bb in it local so we can get them made. We got acess to a mock up block but would like to have a real motor in a truck.
Old 03-10-2009, 07:47 AM   #63
FormerMember
Re: Header Solution
Are they doing that same 10% off on the stainless ones?
FormerMember is offline   Reply With Quote
Old 03-11-2009, 12:41 AM   #64
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
They were all on sale. I will check tomorrow and make sure the sale is still on and for how long.
Old 03-12-2009, 06:43 AM   #65
69trk
69trk's Avatar
Re: Header Solution
I'm needing some big block headers also. 2"primary and 3.5" collectors.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388
431 big block times, changed to a 6.0 ls with turbo
1.58- 60'
7.18- 1/8th mile@95.18
11.37- 1/4 @115.81
69trk is offline   Reply With Quote
Old 03-13-2009, 01:20 AM   #66
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
Yes they are still on sale and will be for one more month.
Old 03-15-2009, 02:12 PM   #67
Dynomutt
Dynomutt's Avatar
Re: Header Solution
I'm interested in a BB set as well if you can get some made. Auto and A/C in my truck.
MARQ
Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=446194
Dynomutt is offline   Reply With Quote
Old 03-18-2009, 01:01 PM   #68
kcjones
kcjones's Avatar
Re: Header Solution
I'm so close to buying these, hope the sales continues, if not, what are the chances they'll still be making these 2 months from now? I cannot find anything like these from any normal header company.
-Kris
Old 03-19-2009, 01:05 AM   #69
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
Yes they will still be making them in a couple of months. It's just the sale will end the middle of next month.
Old 03-19-2009, 08:43 AM   #70
FormerMember
Re: Header Solution
As soon as I get some extra funds, I am on it.
Old 03-19-2009, 04:41 PM   #71
lindsey
Re: Header Solution
Looks like a nice product. I will hopefully be ordering a set early next month to get in on the sale. Do these things have any sort of warranty like the Heddman Headers do.
lindsey is offline   Reply With Quote
Old 03-20-2009, 08:16 AM   #72
local13hutch
MEMBER
local13hutch's Avatar
Re: Header Solution
I asked earlier if these will work on angled plug heads and I just want to make it clear that I am talking about factory 07 5.3 engine... I had a problem once with my 71 lt1 with angled plug world sportsman II heads and the headers I used prior to this on the same truck and block but straight plugs worked fine so I overlooked this problem and the only way I could run them was with a 1/4'' spacer wich I wasnt to happy with so I blew 480$ twice.. and my son got a nice set of headers for free any way sorry for hijackin your thread but I am in if you guys can do it... Thank you ...
86 sub 4wd, 1 ton, duallie, big block th475
72 c10 short fleet, pro street
72 K/5 blazer,2x4 almost stock
72 3/4 ton sub 4x4
61 morris minor pickup, chevy 4.3 v6
03 escalade, 24" momo's wifes
96 2wd 2door tahoe
67 2wd suburban
72 4wd k5 99 vortec 14bolt/d60 205/th400- 72 4wd crewcab 1 ton sb cummins allison -2012 2ss camaro black hard top- 8 yamaha quads- 05 4wd one ton duramax dually, family limo.
local13hutch is offline   Reply With Quote
Old 03-21-2009, 12:27 AM   #73
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
Yes, They do come with a warranty I will talk to them a get the details and let you know. They will fit angle plug heads with standard style bolt flanges. As for 07 5.3 I think they run a different flange. I will look into that.
Old 03-21-2009, 12:34 PM   #74
chevysittinsidewayz
Re: Header Solution
can i get a seat made that is more equal length and the collectors not welded on?
whoever thought of "i live my life a quater mile at a time"-vin diesel needs to be ***** slapped. i would have a pretty short life
chevysittinsidewayz is offline   Reply With Quote
Old 03-23-2009, 09:45 PM   #75
Jokers69
Active Member
Jokers69's Avatar
Re: Header Solution
You can get them without the collectors welded on but to get them more equal lenght would be a custom job. Our jig is already made and it would be something you would need to have built for your truck.
