01-09-2009, 09:03 AM | #26 | |
Re: New 'lifetime warranty' starter from O'reilly is junk
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
01-09-2009, 11:20 AM | #27 |
I too have fought with starters on these old trucks, being stranded on the side of the road many times. I installed a high torque mini starter and even had a problem with that a few times. Finally I installed a remote starter solenoid and never had any more problems.
If and when I ever have another sbc, that will probably be one of the first things that I install. Good luck! |
01-09-2009, 02:16 PM | #28 |
The Manual I bought at Adavance auto has a whole section on how to rebuild alternators and starters & water pumps. Its either a Haynes or Chiltons..."How to rebuild Chevy Engines book" I use it for reference once in awhile.
Good bathroom reading material. I have had bad luck with lifetime Radiators, Alternators, Brake master cylinders, and several other items. The worst was the master cylinder for my 70' It failed on me in November and I almost crashed the truck on a 4 lane busy highway! It was "remanned autozone junk" I went back and almost threw it at them. They gave me back all of my money for it and I bought the "New" one that looks identical with no core charge either. The "new" one is working for now....But I am still very gun-shy about it! Its said made in China on the box and that spells junk in my vocabulary... I work on Chinese scooters all the time at the Bike shop I work at part time. They have gotten much better with time...But the electrical systems are still junk. Switches and bulbs from China got to be the worst I've ever seen...And if you look at the wire insulation the wrong way....It will fall off the wire. Stuff made in Taiwan is actually much better than China...And Some of the Europe stuff is almost as bad as China...(I got a thing for Scooters) Vespa's are well known for having JUNK electrics. The worst problem I see with the master cylinder made in China is the rubber seals...Seems that the rubber from over there sucks bad. Their valve stems will dryrot in like two months when exposed to the sun....So watch out.
1970 C-10, manual everything converted to automatic trans with a 307 1974 Monte Carlo Turbocharged cast piston 350 on 14# of boost 1975 Monte Carlo-Project not started yet 1969 Pontiac Firebird, 406, 4 speed, 3.91 gear 2002-08 Zuma Scooters 1997 TL1000SV/R Suzuki V-twin Sportbike |
01-09-2009, 07:12 PM | #29 |
I have to agree 100% with that. Any thing rubber I have bought that was made in china rotted and cracked within a year. Be it rubber ties for wagons or wheel barrows, air hoses, o rings, washers and so on.
01-09-2009, 07:19 PM | #30 |
Restoration Desperation
Interesting thread. I have heard the horror stories about crappy starters from discount type auto parts stores. Funny thing, about 30 miles away from me is an old timer that has been re-building starters for 50+ years. Everyone i have talked to here has never had one he rebuilt fail. This is not majic or rocket science folks, but is seems that corporate America could give a rats #$* about it's consumer. We(USA business) can't even be bothered with building our own starters anymore........................sad.
RD |
01-09-2009, 07:26 PM | #31 |
It is going to be hard finding made in USA replacement parts like that anywhere. Get you two starters, alternators, fuel pumps and water pumps and put one on your truck and the other in your tool box.
_______________ Thomas '78 Silverado '74 Monte Carlo '47 Teardrop Trailer East Texas Classics Local Club |
01-09-2009, 07:34 PM | #32 |
Moderator
Starters, alternators, A/C compressors...always have them built by a local shop that does it on the premises. You will not have problems then. When I buy an alternator from autozone, I immediately take it to my local shop and have old Ernie rebuild it and convert it to one wire. Never have problems this way.
01-09-2009, 08:54 PM | #33 |
back to the starter issue. You mentioned heat soak, and I've had some bad luck with that too.
I had a new Kragen starter go bad after a long road trip. It just wouldn't click over until the truck cooled completely. Then it cranked right over. So I returned it for a new one, but this time I got a new plastic cover for the solenoid and wrapped the whole starter with a heat blanket kit. That was 2 years ago and I haven't had any trouble since. But I definitely agree with all the posts about the old time mechanics actually fixing problems, and not just throwing parts at something, crossing your fingers, and hoping the owner sells the car before your installed junk breaks. |
01-09-2009, 09:56 PM | #34 |
We usually rebuild our own starters and alternators also. Sometimes they are too bad to fix, then we have run the cheaper line of NAPA rebuilts. They have several grades, the more expensive line is supposed to be better, but we've had no problems yet, with even the cheaper ones. I don't think NAPA is any worse nor any better that any other parts house.
We are lucky to have a local electric motor service, that may be the best place to to get something rebuilt if you have one close.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
01-10-2009, 12:36 AM | #35 |
Hey I was made in Mexico.. but I never build any starters!!!!!!!!!!
01-10-2009, 09:28 AM | #36 |
You know, I went through that same circus a few years ago with the "discount" replacement for my truck, (the kid behind the counter insisted it was the right one) and ended up being able to remove and install a starter in 20 minutes or less (I did this 5 times in a 1 year period). You pay a little more for factory, but my current one has been in place for almost 9 years now. One more note, If you have a nose cone that works, never let it out of your sight.chevy:
01-11-2009, 11:50 PM | #37 |
Parts house cheap line starters & alternators are all the same. The only thing that gets replaced is the part that is bad. The premium lines have been completely rebuilt. I like cheap parts as much as the next guy, but Ill spend the extra $10 for the premium line when it comes to starters & alternators.
01-11-2009, 11:54 PM | #38 |
01-13-2009, 12:17 AM | #39 | |
Freedom isn't Free
"but at the end of the day, all you got is a warrantied piece of ****"
Previous rides: (worth mentioning) 67 camaro 70 long fleet, 69 short step (stolen), 72 blazer 62 chrysler imperial (hell yeah) 55 and 56 chevy hdtps 72 monte carlo Daily Driver: 86 S-10 Blazer (drive it til I die) and 71 long fleet Projects: 71 suburban, 72 C-30 Dually, 71 Chevy LWB |
01-13-2009, 12:24 AM | #40 |
HERE.......Somewhere
I got one from napa in 2007 and it went out like in the summer of 2008. all the stuff is foreign for our trucks and you are not going to find one made in america or canada. Only mexijapachin parts for your 67-72 chevy gmc pick up.
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 with a 350 4barrel and 288 horses Classics make it possible! |
01-13-2009, 12:52 AM | #41 |
theres a shop in our town that does starters stuff like that and it's a going rate of $45 for anything unless it's got some special part, go in and all you see is crap everywhere and they pull your starter out of a pile of junk with a tag on it and a fresh coat of paint they never have any problems either
ΜΟΛΩΝ ΛΑΒΕ |
01-13-2009, 01:34 AM | #42 |
Heat soak *may* be your problem. My 67 went through 3 or 4 starters in a couple years time as well as leaving me stuck at gas stations and other places because it was too "hot" to start.
I installed a new starter and heat shield well over a year ago and I haven't had any starter issues yet. They're kinda cheap. This one is metal. http://shop.advanceautoparts.com/Pro...goryCode=3638J
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 01-13-2009 at 01:36 AM. |
01-13-2009, 10:08 AM | #43 |
Lifetime warranty just means they`ll keep throwing jink parts at you until you give up or sell the vehicle.Has nothing to do with quality.I like to take my starters,alternator,and carbs to a trusted benchwork shop.You get your same part back and talk to the guy who`s doing the work.Cheaper,too.In a pinch I go to Napa,pay the core,and keep my part.
01-13-2009, 10:22 PM | #44 |
I too work at O'Reilly's here at home.
If my starter went out I would ship it to a mom and pop place that our store is hooked up with called J&I. They rebuild starters and alternators for our customers all the time and I haven't heard one complaint yet out of a customer. I have an O'Reilly Alternator on the GMC and it's the third, one of them stranded me 100 miles away from home. The sale was registered in our system and I got my replacement though. It's just like was stated earlier, NOTHING is made the way it used to be. The next time that alternator goes out I'm going to say screw it and ship it to J&I too and have them rewind the thing to a higher amperage while they are there. The Off Road Lights I'm going to be ordering this summer really take some power. |
