Old 01-09-2009, 12:38 AM   #51
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
thanks 1984, it should be a 6" drop, It has djm 3" spindles and 2" coils but it only turned out to be a 4" drop
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 01-14-2009, 03:46 AM   #52
flamingbig10
6.0 powered square
Re: my 80 build
Yesterday I got the gauges wired up on cluster, would of got the indicator, and dash lights wired up and that would of been done, but my parts from summit came so had to look at them and installed the water pump pulley and the window crank handles would installed the crank pulley but it looks like I have to get shorter belts, and a guy came over to buy a few parts and he admired my truck for about hour,
Aaron
Old 01-24-2009, 02:32 AM   #53
flamingbig10
6.0 powered square
Re: my 80 build
Ive done a few things on my in the past couple of days made some kick panels out of some galvanized steel, wired up a 12 volt outlet and installed three inch drop springs, and the top of the wheel well measures 24 3/4 inches before I started it was about 27 inches, I'll take pics tomorrow
Aaron
Old 01-26-2009, 02:40 PM   #54
flamingbig10
6.0 powered square
Re: my 80 build
before
after
Aaron
Old 01-26-2009, 10:11 PM   #55
CoggedBelt75
CoggedBelt75's Avatar
Re: my 80 build
Looks great flamingbig10!!! Those couple extra inches taken away made a big difference in the stance. Joe
CoggedBelt75 is offline   Reply With Quote
Old 01-26-2009, 10:33 PM   #56
flamingbig10
6.0 powered square
Re: my 80 build
thanks, the coils helped the appearance a bunch, it looked kinda goofy before
Aaron
Old 01-26-2009, 11:32 PM   #57
slugish
Slugish
Re: my 80 build
trucks like yours make us all proud
good work > great looking
slugish is offline   Reply With Quote
Old 01-26-2009, 11:58 PM   #58
flamingbig10
6.0 powered square
Re: my 80 build
thanks slugish
Aaron
Old 02-18-2009, 11:26 PM   #59
flamingbig10
6.0 powered square
Re: my 80 build
Ive done a few things to my truck in past couple of weeks wired up my factory wiper motor to a universal wiper switch only work on low and low might be a loose ground or I need to spray some lubricant on the mechanics, I wired up my heater blows air out good now to decide about how I'm going to route the heater hoses, and took a few pics of what the inside looks of now, and a few more
my dirt cheap seat I got at the junk yard
Aaron
Old 02-19-2009, 01:00 AM   #60
85_prairieboy
85_prairieboy's Avatar
Re: my 80 build
Wow! Only 18! I am 23 and haven't done near as much as you have. Looks good! I especially like your dash. Its similar to what I want to do
85 GMC toy Lowered, newer box swap, 350 .060 over with AFR 195s, forged pistons, TCI TH350
1.83 60' 13.14 @ 100 on motor
1.49 60' 11.52 @ 116 w/150 shot
1952 Chevy truck project
1980 Z28 Camaro
1967 Camaro drag car 10.60@126
85_prairieboy is offline   Reply With Quote
Old 02-19-2009, 01:12 AM   #61
flamingbig10
6.0 powered square
Re: my 80 build
thanks 85, I used the factory pieces as templet, a lot people don't believe that how young I am that I built my truck
Aaron
Old 02-19-2009, 09:23 AM   #62
Alex1
Alex1's Avatar
Re: my 80 build
Truck looks great! keep up the good work!
Alex1 is offline   Reply With Quote
Old 02-19-2009, 04:46 PM   #63
flamingbig10
6.0 powered square
Re: my 80 build
Thanks Alex, today I used Mothers California Gold® Clay Bar System, what A difference it made the finish hasn't looked this good in over two years, now I need to use the 3 step Ultimate Wax System
Aaron
Old 02-19-2009, 04:51 PM   #64
silvereagle07
silvereagle07's Avatar
Re: my 80 build
Nice! I like the interior trim, good job.
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 02-19-2009, 07:37 PM   #65
flamingbig10
6.0 powered square
Re: my 80 build
thanks silvereagle
Aaron
Old 03-03-2009, 12:14 AM   #66
flamingbig10
6.0 powered square
Re: my 80 build
I figured out why my wipers would only work on slow had a bad ground, I was Tired of hiting my knee on my radio so I moved it where the factory a/c controls, then I drove my truck it was a liitle ocword with the shifter lever, so I decided to leave it alone, until I know what I really want. I was given a 89-91 bezel that I used since past owner messed up the metal dash were the radio was since I didn't notice it when my truck was getting body work, I mad a piece of diamond plate that covered up the radio opening just didn't take any pics
this was before it was tightened down
also took a bunch of pics of my heater under the dash
http://store.summitracing.com/partde...5&autoview=sku
Aaron
Old 03-03-2009, 12:28 AM   #67
flamingbig10
6.0 powered square
Re: my 80 build
And some outside pics
Aaron
Old 03-03-2009, 12:37 AM   #68
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 03-03-2009, 12:39 AM   #69
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 03-03-2009, 09:38 PM   #70
flamingbig10
6.0 powered square
Re: my 80 build
I decided how I'm going to use my tax refund, first a front end aliment,
and maybe some of this stuff
http://store.summitracing.com/partde...art=CAL-198195
http://store.summitracing.com/partde...art=SUM-811004
http://store.summitracing.com/partde...part=SUM-G1198
http://store.summitracing.com/partde...part=SUM-G1201
Aaron
Old 03-05-2009, 08:45 AM   #71
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: my 80 build
Awesome work. Would it be possible to update some of the old pics that aren't showing up?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-05-2009, 09:32 AM   #72
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: my 80 build
Nice pics!
Good luck with the upgrades and keep us posted!
tvblazer78 is offline   Reply With Quote
Old 03-05-2009, 12:48 PM   #73
flamingbig10
6.0 powered square
Re: my 80 build
thank's guy's I sure can
Aaron
Old 03-16-2009, 07:41 PM   #74
flamingbig10
6.0 powered square
Re: my 80 build
Over the week end I relocated my battery to bed and installed my amp in my truck, wile I was at it I cleaned the carpet, and ordered a flamed etched mirror from lmc
today, my driver side door panel was finished
Aaron
Old 03-16-2009, 07:57 PM   #75
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: my 80 build
Welcome to the club
That dose look sweet! Good work!! Now how do you like them?
