5.3 Litre LS Conversion to a carb?
Ok I am totally green at this stuff and am looking for opinions.
I recently purchased a 47 pick up and a buddy of mine has a motor (free) that I can have. It is a 2002 5.3L LS 1 that came out of his Avalanche. He is also giving me the transmission which is an L60E w/ a stage 2 shift kit. He wants to put that in my truck and convert it to a carb. I know absolutely nothing about motors but had this conversation with another friend who says it will be costly to convert it and a computer is still needed. Now the guy giving me the motor and tranny will be doing the install but at my expense. No labour, just parts. I realize I don't need a shift kit but it's already in the tranny. So opnions please good? Bad? Expensive conversion? He is a licensed mechanic who owns his own garage with about 5 employees. Is this the direction I should be going? I also have an option for a 350 motor instead. Last edited by 4DSEVEN; 01-19-2009 at 08:56 PM. |
Insert Title Here
Re: 5.3 Litre LS Conversion to a carb?
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
Right on the line, baby!
Sounds like a good friend. Nice motor. Welcome to the board-
-Todd
83 GMC 406 th400/3.73 Eaton Truetrac posi, headers, x pipe, & racePros. Tubular control arms, lowering rear springs, caltracs. Still ugly, but getting built right, although slowly Click and scroll down for site vendors! Subscribe here! |
![]() Join Date: Jul 2006
Common consensus over on LS1tech is that the Edelbrock box with the "timing pills" has way too much timing. Most of the carb conversions are running the Victor or GMPP intake with the MSD 6010 controller. The wiring is simple.
'20 Silverado Trail Boss ~ '17 Tahoe ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '71 Cheyenne swb ~ '55 Pontiac Safari ~'50 3100 bagged ~ '80 Wife ~ Late model kids
its all about the +6 inches
and if you ditch the 4l60e for a 700R4, then you won't need the computer for the tranny... just the ignition controller already mentioned.
Just make sure the tranny is up for the power/punishment you plan on giving it |
![]() Join Date: Nov 2008
The newer 5.3 will bolt up to a 700r-4 tranny?
On a budget like Fred Sanford
Yes, with an adapter flexplate.
'85 Silverado swb: 383 stroker, 10.5:1, vortec heads, 232/238 roller cam, RPM air gap, performer 750 carb, stainless longtubes, 3" duals/super 44's, T56/4.11 383ci build / exterior refresh thread '98 Camaro z28: 370ci twin turbo 370ci build '01 Tahoe LT 4x4: 5.3, longtubes/ory, magnaflow duals, custom tune....wife's DD |
You can also use a spacer made by Hughes, Summit p/n HP3795. It's only $43.95, much cheaper than a flexplate. The 5.3L flexplates fit, some others do not though. You can also run a stock speedo with the 700R4 if it's cable driven.
If it has all the injection stuff on it still (manifold, fuel rail/injectors, etc) it will be cheaper, and in my opinion, easier to leave it alone and forget the carb idea. Not sure if cost is a factor or not. Either way, cool project!
1971 Suburban 4x4, LQ4 6.0L, 4L80E, etc. Last edited by boostat4500; 01-28-2009 at 11:27 PM. |
Professional Grade
Big step backwards going carbed, the EFI has a lot to offer, and is not that tough to retrofit.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap) |
Technology wise, I agree. EFI is far superior...but it all depends on what he wants out of the truck. If he's already got a carb then the price would be comparable. If I had a '47 I would stick with the EFI for the novelty of it. They're becoming commonplace in 67-72's though which is why I'm putting together a carb 5.3L for my truck. I like 'em both.
I have been thinking of doing this exact same thing in my 82 Crew Cab Short Bed w/ a 454 BBC & 700R4 Tranny w/ Shift Kit. It has a Painless wiring harness throughout the entire truck. IMO it is an easier/cleaner swap going with the Carbed setup. I have compiled everything I think I will need to do this. Anyone please chime in and let me know what you think or if I have some parts wrong. I am looking to probably buy the engine start going through it by September. I just want to have everything lined out so once I start, I can breeze through the swap.
Thanks, Justin ![]() |
Registered Cruiser
Any updates here? I'm thinkin of going the Carb'd route as well. Yes, the gas mileage won't be there but I'm not going to be driving it every day... at least after the first few months lol
77' Chevy SB Dropmembered Front and Rear 5.3/4l60e combo |
Truck and auto performance nut
Oh no....more carb'd LSx naysayers. I wonder how many have done it?
Anyway.....here's my as they would say... "mistake". ![]() '09 LY6 6.0L with VVT delete, a cam, and headers. Thats a GMPP dual plane LSX intake and Holley Street HP 750cfm carb ![]() that said...I do need to disclose that I have someone that I'm doing some trading with. He is providing the hardware and software to change my motor to efi because that's what he knows, and what I can get the best value out of my trade vs something else or cash. I don't need to use it all but will because of my problems with the 200-4r and desire to replace it with a 6L80 or 90e...I'm changing. I will be going to a carb looking efi setup using a carb intake, fuel rails, and 1000cfm throttle body, as soon as financially able.
Kurt - '68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy '72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close '06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD '18 Kia Sorento - wife's econo-driver '95 Chevy S10 - reg cab shortbed, LS, 4.3, auto... my '68's powertrain and chassis build -links broken A surprise phase - carb to efi -links broken |
#15 |
A guy with a truck
Cool. Using the stock ECM?
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
#16 |
If you go FI you will also have to add the cost of changing your fuel system...tank, pump, filter, etc...
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
#17 |
It'll be an e38 ecm...which I heard was one of the latest and greatest, and will run about any trans including a 6L80e or 6L90e...so most likely? No reason couldn't do a speed density tune with that setup? Unless the TB has MAF, IAT, etc. sensors built in?
I'm not against going aftermarket tho. and no reason to change fuel tank....an inline pump can be placed outside the tank. Same thing FAST and MSD use with their carb style efi. That's my plan.
#18 |
I ended up going with a 383 stroker in the end.
#19 |
was running a old skool 383 before the 6.0L. It made good power...but nothing like this carb'd 6.0 makes.
#20 |
Anyone got numbers on what kinda power a 5.3 puts out with a carb on it? My buddy runs inventory at a local junkyard and recently informed me that they're letting great shape 5.3's go for 400-500 bucks, with the needed stuff to go to a carb I'm looking at about what I was going to spend building another gen 1. Would be throwing it in in front of a Th350, figure a 600-650 carb (which my 350 is getting shortly so that would just be carried over). Not doing it for fuel economy or trick factor, just looking at my options for cheap speed, can always put a 383 together.
#21 |
check this out....http://www.carcraft.com/techarticles...e/viewall.html
my build threads '86 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415628 '67 C10 http://67-72chevytrucks.com/vboard/s...d.php?t=635078 '63 GMC http://67-72chevytrucks.com/vboard/s...d.php?t=674682 |
#22 |
Registered Cruiser
Great article MooseKnuck!!!!
#23 |
no prob man...that should give you some ideas....
#24 |
#25 |
Where did you source it from? I'm looking at getting the one of these to start with...it has 440hp/tq
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
