11-21-2008, 02:22 AM | #26 |
Re: Tune-port install
yes i am using that harness for my build. great quality everything brand new and delphi connections...thats what gm uses. great awesome guy to and offers alot ALOT of extra tips and info for your fuel injected engine...very educated. was a software programmer worked alot with the injection system and engine computers....another good point is the price.....plenty of bang for little buck give him a call just if you have questions he there to help not make a big sale....im across the country from him too harness comes in pretty good size box shipping was like 10 bucks or so
11-21-2008, 01:04 PM | #27 | |
I may have got the technicallies wrong. What I meant was there is an easier way. I would look for the Post on another Forum, but I don't remember what I was searching for when I stumbled across it. Last edited by airdale94; 11-21-2008 at 01:07 PM. Reason: add |
11-21-2008, 01:08 PM | #28 |
Location: Sunny, Florida, some might call it South Alabama
Cool, i'll give him a call today
Just sold my C10...sad day... Looking for a 1972 Blazer to hopefully fill the hole in my heart. |
11-21-2008, 01:09 PM | #29 |
I think we are gonna save the LT1 for the 56 Belair lucky
11-21-2008, 03:15 PM | #30 |
Agree!!! When I started my build LT1s still brought $4000.00 so I went the TPI route...
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile |
11-21-2008, 04:27 PM | #31 |
What cost so much?
11-21-2008, 04:31 PM | #32 |
At the time I started my 68 project LT1s were the hot motor... all the new Ls and LSX motors didn't exsist so LT1's brought all the money...
11-21-2008, 05:14 PM | #33 |
TPI's make good truck motors because they produce a decent amount of torque. The L98 in my vette put down close to 300 ft lbs at the wheels when it was stock. If you're going to upgrade beyond the TPI, I would just skip the LTX stuff and straight to the LS series. A 6.0L from a late model truck would make an awesome truck motor. Plus, the aftermarket is packed with parts for the gen III/IV motors.
If you're looking to add some HP's to the TPI start with the intake. The stock one is very restrictive. There are some cheap alternatives though. For starters, check out www.lt1intake.com Or, check out the stealth ram and mini-ram intakes. |
11-21-2008, 05:44 PM | #34 |
Sweet sounds like a cool car (56 Belair)
Yes definitely skip the LTX and go to LSX |
11-21-2008, 05:58 PM | #35 |
If you have an LTI use the manifold off that on the TPI setup it will solve the poor flow problems at higher rpms and won't cost anything (or pick up an extra LT manifold at your local pick a part for $25). Just need to bore a hole for the dizzy and get a remote thermostat housing modify the bolt holes and your good to go.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
11-21-2008, 06:10 PM | #36 |
The TPI that i'm installing first doesn't need to be a power house...my dad just wants something that is unique and is dependable, with some power.
11-21-2008, 06:36 PM | #37 |
I have a radical idea!
That it will be. The 305 TPI won't win many races, but it will have good useable power and will get good fuel mileage.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
11-21-2008, 06:40 PM | #38 |
That's all he is looking for...now once I finish his and feel comfortable with installing the system, I'll start buying the parts to do mine. And it'll be a bit more extreme
11-22-2008, 01:26 AM | #39 |
Grab a harness/computer from a JY. Should be cheap. If your wanting more power, that might be tough without a tear-down (different pistons/heads). Different runners might help a little though! You can coax 325hp out of a 305, but it might get pricey. But hey, not everyone and their brother will have one! I also agree that 3rd gen camaro site is very useful. Good luck!
Jay |
11-22-2008, 02:05 AM | #40 |
Jy?
11-23-2008, 12:06 AM | #41 |
Sorry, junk yard.
Jay |
11-23-2008, 12:22 AM | #42 |
Ok cool...thanks
01-21-2009, 10:43 PM | #43 |
any up dates on this ?
i am going to be doing a 350 vortec tune port in a 91 2wd 4 door blazer what did you use for manifolds? |
01-22-2009, 06:22 PM | #44 | |
Parts and more parts
This engine also has 1.6 to 1 roller rocker arms and 23 LB injectors for a total of 350 HP from the engine. |
01-22-2009, 07:03 PM | #45 |
Old member
I have had this motor running for close 20 years in my 71. It has never let me down except for fuel pumps but that has been solved with the baffeled tank.
I installed this motor back in 89 and Street & Performance was the only company doing this stuff at the time. I got a V-6 Ferrio computer with S&P wiring harness. My factory harness is all there nothing has been removed. All the gauges are as were form factory. The S&P harness was all plug and play with a Hot,ground and fuel relay wire and the rest plug to the motor. I wish there would have been all these choices back when I was doing mine but hey it was fun.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
01-22-2009, 09:42 PM | #46 |
exhaust manifolds
will the camaro ones bolt to the vortec heads? what inline fuel pump did you guys use? Last edited by wannabelow; 01-22-2009 at 09:42 PM. |
01-22-2009, 09:43 PM | #47 | |
what valve covers are those? |
01-23-2009, 12:13 AM | #48 |
The valve covers on that engine are the original titanium colored covers from the 90 Vette that it came out of. They had some stains on them from the brake fluid that spilled onto them when it rolled over, so I sprayed them with a silver color until it came time to do something else. I have a set of chrome covers in storage for it.
The factory GM exhaust components for the cars and trucks should fit the heads. That side is basically the same as a standard GM 350. |
01-23-2009, 12:21 AM | #49 |
thanks
i am really really bad for guessing hp what would you guess be for a stock 98 350 vortec with a tune port out out of a 88 firebird that has been ported? |
01-23-2009, 05:34 PM | #50 |
If you do some engine updates and the computer is bumped up for performance, as well as bigger injectors. you could get to 325 or 350 HP easily. However, the stock engine, with a standard TPI you will get the 265 HP range. Example, this vortec motor from PACE Perf. with a multiport injection and a vortec motor.
http://paceperformance.com/index.asp...D&ProdID=85273 Last edited by piecesparts; 01-23-2009 at 05:34 PM. |
