Old 02-07-2009, 08:42 PM   #1
383k5
My new adventure. 64 C10 build
I just got my 64 two days ago, since then I have pulled the front clip, cab, and entire from suspension off. Also have sanded the frame down and painted it up to the drive-shaft loop crossmember.
I'm overly excited about this truck, I recently built a 77k20, and sold it.
So far my plans are to replace the cab corners, fix the passenger rocker, and windshield surround.
I have been reading about disc conversions, I think I'm going to go with a stock height 73-87 set-up, my question is this. I was almost positive that the later 12bolts are the same shafts as 10bolts, if this is true why could I not swap the 6 lug shafts for 5 lug shafts, and then use a 10bolt rear drum system?
I'm going to assume that someone on here has re-wired their truck with a Painless system, but has anyone tried to install a 81-87 column also?
I was taking the factory column out and it seems to be possible, I am considering attempting it for the tilt, and intermittent wipers.
383k5 is offline   Reply With Quote
Old 02-07-2009, 08:48 PM   #2
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Re: My new adventure. 64 C10 build
Good start and welcome from Texas!
Several tilt column threads on here.
I used a column from a 77 K5 and fuse panel and harness from a 79 C10.
Looks like you have the skills to make it happen.
Good luck!
Joey~AP is offline   Reply With Quote
Old 02-07-2009, 08:56 PM   #3
383k5
I sure hope so...not trying to brag but I put my friends jeep wagoneer on 40's, my k20 on 37s, then swapped everything into my K5. Hardest part was making a mechanical clutch pedal work with a hydraulic master cylinder.
I just read your thread about what you're doing for your son's truck...that looks sweet!
Old 02-07-2009, 09:03 PM   #4
Joey~AP
TexasBowhunter
Joey~AP's Avatar
Thanks!
Me and him have been havin fun with it.
He is over ready to cruise Alvin with it and go muddin with his friends.
Old 02-07-2009, 09:16 PM   #5
383k5
He's got the right idea...haha
84383/465/208 D44/14b Detroits, 4 wheels discs, 8" front, 6" rear, 37" Irok Radials
96 ranger 4cylinder with the flowmaster. It's my race truck
64 C10...random pieces strew about.
Old 02-07-2009, 09:53 PM   #6
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
[QUOTE=383k5;3130651]
Welcome From Tennessee!
2 days and you got all that done? I'm impressed!
Keep us updated----We love pictures.
Here's a tilt thread, there's more if you trace this board back a few pages.
http://67-72chevytrucks.com/vboard/s...d.php?t=327531
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 02-07-2009, 09:56 PM   #7
383k5
I'm young...when I"m motivated I get things done quickly.
Old 02-08-2009, 12:53 AM   #8
joe231
joe231's Avatar
rock on man!!!
nice work!
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 02-08-2009, 01:45 AM   #9
protrash64
Resistance is Futile
protrash64's Avatar
Thumbs up Re: My new adventure. 64 C10 build
Welcome from AZ.....
Im not sure exactly what you were meaning with the rear axle thing, but the older rear ends are narrower than the newer type. Swapping axles is not something Ive done, but the width thing is an issue to consider.
My wrist kinda hurts just looking at that pile of parts you've already torn off there.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 02-08-2009, 07:54 PM   #10
383k5
ah...I've done multiple axle builds now. I was talking about just the shafts.
I'll probably take it apart this week and compare with some old 10b shafts I have.
Old 02-08-2009, 08:33 PM   #11
Corts60
Just here to tinker
Corts60's Avatar
Awesome start man! Keep those pics comin!
Oh and WELCOME ABOARD!
Old 02-08-2009, 09:51 PM   #12
TimE
Hey Y'all!!
TimE's Avatar
The later model rears ('71-up) are wider than the one in your '64. I read somewhere about someone using the later model axles in our style rear and then went with the the HD drums(which are slightly wider) to make up the difference for the brake drum width. This still had the axle hanging out a little too far but you couldn't tell from looking at the assembled setup(don't know how well this would work, just throwing it out there for you).
There is also the issue of the '64 having a different spline count than the later('65 up) rearends. You would need to swap out the spider gears to remedy this difference.
Your other options would be to buy aftermarket axles that are the correct length for your year(plus 5 lug drums-or redrill yours to 5 lug), find a 71-72 rear and swap it in or get a 73-up and weld perches on it to fit your truck.
I'm sure you can find all kinds of info if you do a search but maybe this little bit will help.
Good luck!
Just hopin' I live long enough to finish something!!!
TimE is offline   Reply With Quote
Old 02-10-2009, 11:01 PM   #13
LILRED66
LILRED66's Avatar
Welcome to the forums from Kansas City, KS. Nice progress in a short amount of time. Remember to post early and often, especially lots of pictures.
LILRED66 is offline   Reply With Quote
Old 02-11-2009, 09:02 AM   #14
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Man..quick work !!!
Looking good man...
Glad to have you hear...welcome from Cali....
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
