Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > S10 S15 Luv Blazer
Old 01-31-2009, 12:56 PM   #1
silvereagle07
silvereagle07's Avatar
Speedo calibration question...need help!
I'm posting this to help a co-worker. He has a mid 80's s-10 he has put a v8 in. He is trying to get the speedo to work correctly. It has a th350, 3.23 gears , 26 in tall tires, drive gear has 7 teeth and the new driven gear has 22 teeth (gray). The speedo is still 10-12 mph fast. What does he need to do to correct the problem?
Jeramy
'84 GMC project truck
'85 Chevy 4X4 SOLD
'07 Chevy Trailblazer SS
5th Annual SHPHC Car/Truck Show Pics
http://67-72chevytrucks.com/vboard/s...d.php?t=543605 UPDATED PICS! CHECK 'EM OUT
silvereagle07 is offline   Reply With Quote
Old 01-31-2009, 01:32 PM   #2
Arad68
Trucks N Tranzams
Arad68's Avatar
Re: Speedo calibration question...need help!
Try this link. I used it to fix my problems.
http://www.tciauto.com/Products/Tech...eedo_gears.asp
Don
'68 Chevy LB 383 TH400/GV/373 posi
'56 Chevy 4WD SWB
'64 Chevy short stepside
'79 Trans Am 455/TH2004R/12blt/4whldisc
95 Kia (Wifes car)
2002 S-10 extended cab pickup
"God punishes small sins immediately"
Arad68 is offline   Reply With Quote
Old 01-31-2009, 02:45 PM   #3
silvereagle07
I used this link before I posted and came up with 17.12 # of driven teeth. used this equation # Drive Teeth X Axle Ratio X Tire Rev. per Mile = # Driven Teeth
1001
Jeramy
'85 Chevy 4X4 SOLD
Old 01-31-2009, 02:47 PM   #4
silvereagle07
He changed the driven gear from a 19 tooth to a 22 tooth gear. That's what a local trans shop said to do. It was orignally was about 30 to 40 mph fast and now its only 12-15 fast.
Jeramy
'85 Chevy 4X4 SOLD
Old 01-31-2009, 07:58 PM   #5
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
He needs 8 driven and 20 driven gears. Driven ratio = 20.023. The speed will be almost dead accurate if he has a locking torque converter.
10 driven and 25 driven = 25.029
The top combo works the best.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 02-06-2009, 05:39 PM   #6
Myself
I agree with the above. Change the drive gear. It's really easy, only takes about 30 mins.
Myself is offline   Reply With Quote
Old 02-06-2009, 11:31 PM   #7
silvereagle07
Thanks guys!
Jeramy
'85 Chevy 4X4 SOLD
Old 02-09-2009, 10:57 AM   #8
silvereagle07
He has a 7 drive and 21 driven non locking torque convetor th 350. Does he need anything different w nonlocking?
Jeramy
'85 Chevy 4X4 SOLD
Old 02-09-2009, 11:56 PM   #9
gchemist
gchemist's Avatar
No, he'll run ~200-300 RPMs higher to keep the speed indicated. Maybe more depending on the converter slippage.
