Re: Post Pics of your Static Drops!!
this is a true static drop .
I took out all the springs and bump stops so it's sitting bottomed out . there is no driveshaft in it . the engine runs real good , im not shore what year it is the valve cover don't have Chevrolet embossed on it and it has a vent hose on the left front side of the valve cover. the engine compartment wiring and dash wiring is totally trashed so it won't even yard drive yet . I just wanted it to look cool until I get a chance to start on it. I picked up a complete 79 front 5 lug cross member and the 5 lug rear with highway gears. I got 2 eight inch 5 lug truck rallys for the back , now I want to find 2 seven inch 5 lug truck rallys for the front I need to pancake the 79 cross member before I put it in and get some C notches before I put some springs in it. |
#2 | |
In the front what is the first thing that makes contact so that it will not go any lower?
I took measurements on my truck today. As far as I know it hasn't been dropped at all. It's a 1966 GMC with rear leaf springs. Front from middle of rim to fender front was 19 inch and the rear was 22 inches.
forestb
the bump stops are the first thing that hits with no front springs in it. so I removed them now the lower a arms are sitting tight against the cross member. it has stock spindles on it and the cross member is about a inch or 2 off the ground now. in the back the stock un cut frame rails are laying on the rear axel housing . I need to pan cake the front cross member 2 inches and put C notches in the back so I can put some short springs in it to get some working suspension . its going to be a 6cyl 5spd . Last edited by 60chevyjim; 03-09-2016 at 04:50 PM. |
#5 | |
That is interesting I figured that the cross member hitting the ground would be the first thing to bottom out (excluding the bump stops of course). Would using tubular lower A-arms keep them from bottoming out first and allow you to go lower so that the front cross member makes contact with the ground?
Before & afters. 5.5"-7" drop. Front is '83 Suburban k-member with 2.5" drop spindles & 3" drop springs. Rear is 5" drop springs, made my own drop plates for another 2", c-notched frame. Rims are 18x8, 245/45/R18 front, 255/55/R18 rear.
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
A sheet of diamond plate steel and tired springs in the back. Lowered torsion bars in the front.
Update. lowered my truck up front 2" more. 4/6 drop now.
Stovebolt-It is painted |
mines in the shop now, getting CCP grand slam skit 5/6 drop and brakes on 6 bolt rotors. putting white GM transport wheels on it.....
I will post more when its done. |
#10 | |
1957 Chevy swb 1964 Chevy swb panel |
Transports are a 22" stealie/smoothy made by gm. They can be ordered with the same bolt pattern as the stock 15" wheels. Commonly used on vehicles that are "slammed".
Nik...................____ 62 lwb c10 step-side 261 5 spd .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ my build thread. Sending unit solution |
CPP 2.5" drop spindles with 3" springs in front and 5" Springs with 2" blocks out back. Tires are 275/50 I think all around but switching to a 255/60 or so in the front. So that should bring it down a tiny bit more.
C10 addict
Do you have any rubbing issues in the front when turning?
Jared 67 C10 CST Short Fleet Big Window 65 C10 Custom Short Fleet Big Window 67 Camaro RS |
#15 |
#16 | |
![]() Join Date: May 2014
How does it drive? Are you running a c-notch, shock relocator, flip kit, or anything of that nature?
Mike OIF 2003-2004 Veteran (US Army) I support the Wounded Warrior Project ![]() "Gotta work on the nut behind the wheel before you start fixing bolts on the car"– Author Unknown My 1965 Chevy C10 LWB build thread |
#17 |
It rides really good. I was surprised. No C notch but I am running front and rear shock relocators. The Hotchkis springs are really nice and I'm sure the ride tech shocks help out a lot too
#18 |
Perfect!
84 GMC One ton 4x4 454 4 speed 62 Chevy C10 short fleet plus about 13 previous gm trucks from 1960 to 2000 |
#19 |
I'm just glad to be here!
Bumwine - love the look of your '65!
Karl ![]() 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
#20 |
#21 |
4.5 / 5 drop , 5 inch coils in the rear 2 inch coils and 2.5 drop spindles in the front
#22 |
Zack - Nice truck. I dig that shop truck theme!
#23 |
Primed the hood this weekend. It was blue. 5"/7" CPP drop.
#24 |
Finally got mine dropped. 2.5 spindles 3 inch springs you coil cut. Axle flip and c notched the rear. 235/70 15 rear 215/70 15 front. All 8 inch wide.
![]() . [IMG] ![]() Last edited by JYSaint; 08-26-2016 at 09:45 PM. |
#25 |
that's a nice looking truck , great color too.
