Old 03-09-2016, 01:09 PM   #376
forestb
forestb's Avatar
Re: Post Pics of your Static Drops!!
In the front what is the first thing that makes contact so that it will not go any lower?
Originally Posted by 60chevyjim View Post
this is a true static drop .
I took out all the springs and bump stops so it's sitting bottomed out .
there is no driveshaft in it . the engine runs real good , im not shore what year it is
the valve cover don't have Chevrolet embossed on it
and it has a vent hose on the left front side of the valve cover.
the engine compartment wiring and dash wiring is totally trashed
so it won't even yard drive yet .
I just wanted it to look cool until I get a chance to start on it.
I picked up a complete 79 front 5 lug cross member and the 5 lug rear with highway gears. I got 2 eight inch 5 lug truck rallys for the back ,
now I want to find 2 seven inch 5 lug truck rallys for the front
I need to pancake the 79 cross member before I put it in and get some C notches
before I put some springs in it.
forestb is offline   Reply With Quote
Old 03-09-2016, 04:44 PM   #377
60chevyjim
60chevyjim's Avatar
forestb
the bump stops are the first thing that hits with no front springs in it.
so I removed them now the lower a arms are sitting tight against the cross member.
it has stock spindles on it and the cross member is about a inch or 2 off the ground now.
in the back the stock un cut frame rails are laying on the rear axel housing .
I need to pan cake the front cross member 2 inches and put C notches in the back
so I can put some short springs in it to get some working suspension .
its going to be a 6cyl 5spd .
60chevyjim is offline   Reply With Quote
Old 03-26-2016, 12:24 PM   #378
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
A sheet of diamond plate steel and tired springs in the back. Lowered torsion bars in the front.
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 03-28-2016, 11:43 AM   #379
forestb
forestb's Avatar
That is interesting I figured that the cross member hitting the ground would be the first thing to bottom out (excluding the bump stops of course). Would using tubular lower A-arms keep them from bottoming out first and allow you to go lower so that the front cross member makes contact with the ground?
forestb
Old 04-21-2016, 01:49 PM   #380
polarisman340
polarisman340's Avatar
Before & afters. 5.5"-7" drop. Front is '83 Suburban k-member with 2.5" drop spindles & 3" drop springs. Rear is 5" drop springs, made my own drop plates for another 2", c-notched frame. Rims are 18x8, 245/45/R18 front, 255/55/R18 rear.
polarisman340 is offline   Reply With Quote
Old 04-23-2016, 04:36 PM   #381
50bomb
50bomb's Avatar
Update. lowered my truck up front 2" more. 4/6 drop now.
Stovebolt-It is painted
50bomb is offline   Reply With Quote
Old 04-24-2016, 02:11 PM   #382
Conrad63
Conrad63's Avatar
mines in the shop now, getting CCP grand slam skit 5/6 drop and brakes on 6 bolt rotors. putting white GM transport wheels on it.....
I will post more when its done.Name:  IMG_1223.jpg
Conrad63 is offline   Reply With Quote
Old 06-20-2016, 11:40 PM   #383
Dutch Checkers
2" drop springs in front. One round cut out.
4" rear springs.
22" wheels
Dutch Checkers is offline   Reply With Quote
Old 06-21-2016, 09:02 AM   #384
robber grin
Front Belltech 2 1/2 spindles and 3" coils / 4" coils and 2" blocks out back
robber grin is offline   Reply With Quote
Old 06-21-2016, 09:42 AM   #385
IHutch5R
CPP 2.5" drop spindles with 3" springs in front and 5" Springs with 2" blocks out back. Tires are 275/50 I think all around but switching to a 255/60 or so in the front. So that should bring it down a tiny bit more.
IHutch5R is offline   Reply With Quote
Old 06-22-2016, 06:03 PM   #386
mahanian
C10 addict
mahanian's Avatar
Do you have any rubbing issues in the front when turning?
Jared
67 C10 CST Short Fleet Big Window
65 C10 Custom Short Fleet Big Window
67 Camaro RS
mahanian is offline   Reply With Quote
Old 06-22-2016, 11:26 PM   #387
bumwine
bumwine's Avatar
6/6 drop. Hotchkis 6" rear springs and Hotchkis 4" front springs with cpp 2" drop spindles and ride tech shocks. Cragar 17x8 in the front and 17x9 in the rear. 225/55/17 tires for now.
bumwine is offline   Reply With Quote
Old 06-22-2016, 11:39 PM   #388
63-73stepside
nice truck
63-73stepside is offline   Reply With Quote
Old 06-23-2016, 09:19 AM   #389
aggie91
I'm just glad to be here!
aggie91's Avatar
Bumwine - love the look of your '65!
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 06-23-2016, 11:04 AM   #390
bumwine
bumwine's Avatar
Thanks!
Old 06-24-2016, 04:50 AM   #391
63-73stepside
4.5 / 5 drop , 5 inch coils in the rear 2 inch coils and 2.5 drop spindles in the front
Old 06-24-2016, 08:08 PM   #392
mr57
mr57's Avatar
I will post more when its done.Attachment 1526044
Attachment 1526045
Attachment 1526046
Attachment 1526047
Forgive my dumb question but what are transport wheels?? I am assuming the wheels that high end vehicles have on them when in transport? Can they be used on a daily driver? They DO look awesome.
1957 Chevy swb
1964 Chevy swb panel
mr57 is offline   Reply With Quote
Old 06-24-2016, 08:43 PM   #393
62stepside longbox
62stepside longbox's Avatar
Transports are a 22" stealie/smoothy made by gm. They can be ordered with the same bolt pattern as the stock 15" wheels. Commonly used on vehicles that are "slammed".
Nik...................____ 62 lwb c10 step-side 261 5 spd
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
my build thread. Sending unit solution
62stepside longbox is offline   Reply With Quote
Old 06-24-2016, 09:45 PM   #394
robber grin
FLOP hood in place finally!!!
Old 06-24-2016, 10:14 PM   #395
Dutch Checkers
C-10 blue devil. '66, 6 cylinder.
Getting there....
Old 06-25-2016, 01:16 PM   #396
zach_carver
zach_carver's Avatar
Here is my 65 C10 5/7" drop. spindles, UCAs, springs, and rear blocks. Tires are P215/70R15 all around.
1965 C10 LS2/4l70, WHITE, 5/7 DROP
LINK TO SUPER SNOOPY C10 BUILD---> http://67-72chevytrucks.com/vboard/s...d.php?t=689283
1977 C10 SILVERADO HAWAIIAN BLUE, 5/5" DROP, LS6/4L80E
1976 CHEVY K5, 350/350, YUBA GOLD/SADDLE
zach_carver is offline   Reply With Quote
Old 06-27-2016, 08:51 AM   #397
aggie91
aggie91's Avatar
Zack - Nice truck. I dig that shop truck theme!
Karl
The LST Challenge:
Old 06-27-2016, 12:43 PM   #398
Fla Grown
Fla Grown's Avatar
Primed the hood this weekend. It was blue. 5"/7" CPP drop.
Fla Grown is offline   Reply With Quote
Old 07-09-2016, 11:37 AM   #399
Mike's Classic '65
Mike's Classic '65's Avatar
Nice set up!
How does it drive? Are you running a c-notch, shock relocator, flip kit, or anything of that nature?
Mike
OIF 2003-2004 Veteran (US Army)
I support the Wounded Warrior Project
"Gotta work on the nut behind the wheel before you start fixing bolts on the car"– Author Unknown
My 1965 Chevy C10 LWB build thread
Mike's Classic '65 is offline   Reply With Quote
Old 07-09-2016, 11:53 AM   #400
Eric15chevys
Eric15chevys's Avatar
Perfect!
84 GMC One ton 4x4 454 4 speed
62 Chevy C10 short fleet
plus about 13 previous gm trucks
from 1960 to 2000
Eric15chevys is offline   Reply With Quote
