03-04-2009, 04:08 PM | #1 |
Sofa King Crazy!!
Help! Wheel and Tire fitment w/bags question
I am running 20X8.5 in front and 22X10 in back with either a 5 or 5.5 b/s on the rims (I will check tonight) will these tuck in front and back? I am retaining the front inner fenders and trying not to cut the bed if I don't have to.
Also, will a 2 or 3 inch c-notch let the diff hit the bottom of the bed, if so, will my "soon to be installed" air bags stop before it does? Running gear > 2.5 inch drop spindles and RE7s in front with cups and plates and RE7 in back on stock trailing arms. Here is a pic of the truck with the actual rims taped to a picture (old skool style not photoshop) Is the pic close to accurate when airred out????
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" Last edited by Slick67; 03-04-2009 at 04:33 PM. Reason: rename |
03-04-2009, 05:04 PM | #2 |
Re: Wheel and Tire fitment with bags question
I think that may be a little low
70 SWB STEPSIDE 70 BLAZER 09 challenger |
03-04-2009, 06:13 PM | #3 |
Your differential will definately hit the bottom of the bed. I have a wood bed and When I dropped mine I did not anticipate that, now I had to install a rubber bump on my rear axle to stop the frame before it bottoms out and the differential cracks the wood. If yours is metal you might have alittle more clearance but minimal like ½ inch or so.
Leo..
Leo70 1970 Chevy Shortbed 1956 Chevy 210 Post 1963 Chevy Impala SS Rag..SOLD! |
03-05-2009, 09:18 AM | #4 |
where did you get thw steelies from i neeeeeed them
03-05-2009, 09:46 AM | #5 |
bbadfred
Factory wheels painted red w/stock caps?
03-05-2009, 02:00 PM | #6 |
Sofa King Crazy!!
The rims were on the truck when I got it. I will be putting them on Craigslist soon!! The rims are actually hugger orange but the pic was taken with my cell and it doesn't do that great.
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" Last edited by Slick67; 03-05-2009 at 02:01 PM. |
03-05-2009, 02:03 PM | #7 | |
Sofa King Crazy!!
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
03-05-2009, 03:35 PM | #8 |
67-72 parts collector,…
I'd run a 5.5" BS front and rear.
BUT please measure yourself before you order. There are two different width rearend for these trucks.
03-05-2009, 05:45 PM | #9 |
Sofa King Crazy!!
I am running a 1971 rearend with drums, I measured and the inside of the drum lip is the same as my 67 rearend. Thanks for your help!
03-05-2009, 05:54 PM | #10 | |
Leo..
03-06-2009, 12:10 PM | #11 |
Sofa King Crazy!!
Did you have to cut the inner fender of the bedside for the rear to tuck with the 22s, if you are running 22s? I'm afraid a mini tub might be in my future!
03-06-2009, 02:21 PM | #12 |
The important measurement would be the wheel mounting surface or outside of drum to outside of drum.
03-06-2009, 02:40 PM | #13 | |
Leo..
03-18-2009, 04:28 PM | #14 | |
Sofa King Crazy!!
I'm raising the bed up this weekend and rolling the frame under it to check out clearance and I will take pics in hopes that it will help others on the board too. I appreciate your help!
Tags |
20s, 22s, bagged, dropped, lowered |
