Old 03-16-2009, 11:05 PM   #1
shrunken66stroker
shrunken66stroker's Avatar
Re: Shrunken66Stroker's build thread.
It's a Tremec World Class T-5 out of a 92 firebird. It's counter clocked 17 degrees toward the driver and it's got a short throw shifter for quick shifts. It's only rated to handle around 300 lb/ft of torque so it's perfect for my stock small block with a 4 barrel carb. If you're looking to put power down with slicks this is the wrong transmission. It's a good 5 speed with a .63x1 fifth gear ratio for cruising on the freeway. At 75 mph the the engine is just over 2000 rpms. At 85 mph it's still under 2500 rpm.
Originally Posted by Reyals Bemus View Post
Is your transmission mounted at a rotated angle to the bellhousing? What's the reasoning?
Nice truck, awesome build!
shrunken66stroker is offline   Reply With Quote
1966, bagged, disc, long to short, stroker
