Rear Window Leaking
I have a 99 Silverado that I bought almost a year ago. I bought it from an individual that definitely hid some things from me. Although they are not big deal things, most of them are just small and annoying. Nothing that I can't overcome...because I absolutely love the truck.
The one thing that is driving me crazy is everytime I wash it or it rains...I've got to stretch out a beach towel across the extended cab seat to catch all the water coming in. It is a rear sliding glass, but it's coming through the hard plastic part that goes around the rear glass...not the glass itself. It leaks on the left and right sides at the top. I can see where the plastic is cracked and that's where the water is coming in. Is this piece available to buy by itself? Is it that simple to just take the outer plastic ring off and replace it? I'm dumbfounded on this one and need help. Any help would be very much appreciated. Thanks, Cory
1999 Chevrolet Silverado 1500 extended cab, short bed. 5.3L automatic. |
1972 Shorty Owner
Location: Stationed in Cali , born and raised in PHX Arizona.
Re: Rear Window Leaking
If i were you i would just try to seal it with some silicone or a similar type of sealant. Only reason being is if memory serves me right those windows are a one peice replacement. I dont think the piece you need is a stand alone replacement but i could be wrong. The one i had done was a busted out window so it was all replaced. I would just save some money and seal it yourself and try to keep it clean.
Good luck.
1972 Chevy Shorty C-10- Project In Work http://67-72chevytrucks.com/gallery/...ATT1721941.jpg- New Project |
Ok...I may try that then. I had thought of that before, but I was afraid it wouldn't do the trick and then I'd be stuck with clumpy silicone creating an eyesore.
It would definitely be a cheap fix...so I'll try it. Thanks.
