03-22-2009, 11:47 AM | #1 |
60-66 Nut
Rear Disc Brake Brackets
These brackets are for putting disc brakes on your 10 or 12 bolt pickup rear differential with the 5 on 5 bolt pattern. They are designed to use the '78 and up metric passenger car calipers and Lincoln Mark IV rotors. A list of part numbers will be provided. The brackets are powder coated in gray hammertone and come with grade 8 fasteners. Price is $70.00 shipped to your door in 2 to 3 days. I have 3 sets of these available.
Power Steering Box Adapter Plates For Sale HERE Power Brake Booster Adapter Brackets For Sale '63-'66 HERE and '67-'72 HERE and '60-'62 HERE and "60-'62 with clutch HERE Rear Disc Brake Brackets For Sale. Impala SS calipers HERE Camaro Calipers HERE D52 Calipers HERE 6 Lug HERE Hydroboost Mounting Plates HERE Last edited by Captainfab; 03-22-2009 at 11:49 AM. |
03-22-2009, 11:52 AM | #2 |
Re: Rear Disc Brake Brackets
Pictures of the the complete setup mounted would be cool.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
03-22-2009, 11:59 AM | #3 |
TNT-MOTORSPORTS
I am interested in these also, I would be interested in seeing an assembled picture also
Tommy |
03-22-2009, 12:16 PM | #4 |
60-66 Nut
I'll get some installed pics later today.....thanks for the interest.
03-22-2009, 02:49 PM | #5 |
TNT-MOTORSPORTS
Sounds good
03-22-2009, 10:31 PM | #6 |
very cool John!
I assume you build these? I want some, but ain't ready for 'em yet
CHEVY ONLY |
03-22-2009, 11:10 PM | #7 |
60-66 Nut
Thanks Joe, Yeah I made these about 8 or 10 years ago, they just don't seem to sell around here. I thought I'd try and sell what I have left on here, and if there seems to be continued interest, I'll make some more. Let me know when you're ready and I can set you up with this style or a different one.
03-22-2009, 11:40 PM | #8 |
60-66 Nut
Ok here are some installed pics of the brackets. One thing I forgot to mention in the first post is that when using this setup you will most likely need to have the flanges of your axles machined down to 6.250" OD. This is needed to accomodate the lincoln rotors. If you have aftermarket axles, I would check them first before assuming it needs to be done. If you don't have a way to get them machined in a lathe, this can be done with an angle grinder, a good hard wheel and some patience. Typically you will need to take off .250" (1/4") of the diameter or .125" (1/8") around the circumference.
Upon setting up this assembly to take pictures today, I discovered a small issue with a reman caliper I picked up today. As I have read in the last couple of years, the castings of the reman calipers can vary from mfg to mfg. This became apparent with the newest caliper having 3 bosses that were interfering with the caliper bracket. This was easily taken care of with a flap disc on a grinder, providing a bit of clearance. Back when I originally made these brackets, I had not run into this issue. As a comparison I have included a pic of an OEM 3rd Gen F- body e-brake caliper. Let me know if you have any further questions, or if you need to see something not shown in these pics.
03-22-2009, 11:45 PM | #9 |
60-66 Nut
Here's a pic of the clearancing done on the reman caliper.
03-23-2009, 05:02 AM | #10 |
PIMPING RIDES
i think this is great production from a stand up guy .i have a set on the way .i will post when they arrive .he provides instant tracking number .very professional.thanks captainfab .a nice way to keep our trucks looking the same but driving and feeling better .
1964 CHEVY 1/2 C/10 FLEET 1981 CHEVY 1/2 C/10 FLEET 1995 DODGE 1500 V6 FLEET EAST http://www.flickr.com/photos/bigasspimp/?saved=1 |
03-23-2009, 08:12 AM | #11 |
Cool!!
Thanks John!! so with the these calipers, only one has an e-brake?
CHEVY ONLY |
03-23-2009, 01:06 PM | #12 |
60-66 Nut
No, I was just showing the two different calipers for comparison. You would have either no e-brakes using the front calipers or both calipers having e-brakes when using rear calipers such as the 3rd Gen F-body or the '83-'87 Eldorado, Riviera, Toronado rear calipers.
03-23-2009, 01:19 PM | #13 |
ok, got ya.......
CHEVY ONLY Last edited by joe231; 03-23-2009 at 01:20 PM. |
03-23-2009, 01:19 PM | #14 |
60-66 Nut
Thanks Larry
03-23-2009, 05:23 PM | #15 |
PIMPING RIDES
got them just like promised,thanx
03-23-2009, 11:21 PM | #16 |
60-66 Nut
Post up some pics when you get them on......
03-24-2009, 08:34 PM | #17 |
Yes, please do!!
CHEVY ONLY |
04-03-2009, 11:33 PM | #18 |
60-66 Nut
TTT
04-15-2009, 12:15 PM | #19 |
60-66 Nut
Bump.....
06-29-2009, 03:01 PM | #20 |
BigPimp - Do you have these installed yet?
Captainfab - Are the lincoln rotors the only ones that work, or can you use the actual truck rotors? |
06-29-2009, 05:58 PM | #21 |
the truck front rotors won't work, they have a hub built in.....
CHEVY ONLY |
06-29-2009, 10:21 PM | #22 |
60-66 Nut
BigPimp didn't purchase these brackets, he bought the Implala SS ones that I also sell
Yes these brackets are designed for the Lincoln rotors. And as Joe stated you can't use the pickup front rotors since the hub is part of rhe rotor
07-03-2009, 10:22 AM | #23 |
captain fab do you still have any of these brackets available. I am in need of a set.
07-03-2009, 01:02 PM | #24 |
Hay Team!!
Nice job on those brackets Capt...
1972 Chevrolet Cheyenne LWB "Orange and White" 8) |
07-03-2009, 10:52 PM | #25 | |
60-66 Nut
Thanks Jerry. Your Impala disc brake brackets are on their way. Thanks
