03-30-2009, 12:23 AM | #1 |
Caliper Leaking
I am wondering if anyone else is having a problem with replacement 4wd calipers.
I have tried 3 calipers now from NAPA and they all have a small leak between the banjo washer and the caliper, they will leak with no pressure other then head pressure from gravity. I am currently using Inline Tube extended brake lines and the hardware that came with the calipers. I have tried stacking some banjo washers to see if I can pick up the imperfection in the caliper surface but I still have a slow leak. Any recommendations on where to find some decent calipers? |
03-30-2009, 06:55 AM | #2 |
Sierra Grande Club
Re: Caliper Leaking
Maybe a little of this on the threads. Just don't put in on the first thread or two so it cant get inside your system.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
03-30-2009, 03:38 PM | #3 |
its all about the +6 inches
Re: Caliper Leaking
moved to the 4X4 section, you may get better feedback over here.
03-30-2009, 06:24 PM | #4 |
Re: Caliper Leaking
Uh-oh, I just bought some from napa. But I haven't put them on yet, so I'll have to wait and see.
03-30-2009, 08:53 PM | #5 |
Re: Caliper Leaking
The threads are not the problem.
The washer seating surface on the caliper is the cause. Sport/Truck if you don't mind let me know the outcome of your calipers, maybe my local store had a bad batch of them. |
