#26 |
Re: Oil filter seal keeps blowing out. HELP!!!
I agree with using an engine flush but i wouldnt just drain it. I would drop the oil pan after the flush that way you can get to the bottom of the oil pump so you can make sure the sludge didnt get to the strainer on the oil pump and you can clean the oil pan!!!! You definitely dont want to loose oil psi!!!! Good luck!!!
Ernest
1968 GMC Rebuilding Stage ![]() 2001 Camaro SS SOLD ![]() |
#27 |
Its always something!
Replaced the oil pump yesterday & it fixed it. I would have never guessed the oil pump was the problem.
79 p10 stepvan 72 Short Fleetside 72 Suburban 67 GMC One Ton Flatbed 64 Short Fleetside 57 Chevy 2DR Hard Top 57 Chevy 2dr wagon 65 f*** short fleet 63 C 60 Flatbed ![]() ![]() Member of the patina club |
#28 |
Awsome !!!!!
#29 |
It happened to my '96 today. Had to tow my '96 K1500 home when my wife took it to an appointment. She said it stopped in an intersection. Found a puddle under it, then more in the driveway. I figure it blew when she started it, then blew the rest of the oil out en route. She said it wouldn't even turn over. I crawled under it at home to find the seal blown out the side of the filterr base. Oil pressure was 40 psi 2 days ago, the last time it was driven. I sent a message to AC Delco about this. I'll be interested if they reply. THIS SUCKS!!
'99 K1500 Tahoe, 2dr, barn doors - 350/ 4L60E, 3.73 '01 K2500HD Silverado Ext Cab - 496/ Allison, 4.10 |
#30 |
Mitch, sorry to hear about your truck. Aren't women observant about listening to motors? (Sarcasm intended). I say this because my wife would have done the same thing. Oh well.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 Last edited by dan42; 01-14-2010 at 12:06 AM. |
#31 |
No offense taken. My wife said the gauges looked ok when she started it. Because of traffic and being in a hurry to get to her appointment, probably didn't notice it again. I don't blame here for not hearing anything other than the ticking of the lifters, since it has been doing that for a while, but oil was ok. I just checked it last week.
I did find a new gm vortec engine with 4-bolt mains locally for $1900 + tx +core. I'm going to check it more tomorrow to determine if I need to get it. If so, I'll try to pick one up on Friday after work. Luckily, I have the ability and friends to get it done. PItA, but maybe a little fun. Gotta try to see the bright side, you know.
#32 |
Allright, It was the wifes fault I have to put a brand new 6 liter in my old truck. Honest honey, you really got to look at the guages more often so I don't have to do this again!
#33 |
Yeah, now I'll have her drive my '85 so I have to install a new HT383. Wonder if she'll go for that?
#34 |
![]() Join Date: Feb 2009
So, as the earlier posts mentioned a check valve, what does a check valve look like? It is buried deep in the block or is it spring loaded, under tension, busting to escape when you convert from canister to spin-on filters? I am converting and I didn't see any check valve fall out, and I don't know if I am missing it. What does it look like?
John in Eugene
Eugene, Oregon Lucy's Limousine 1966 C-10 LWB 283 w/ 2bbl, OE carb and dist. 4 spd (granny 1st) w/ 3.73 rear end |
#35 |
Oops! That second sentence should have the first two words switched, so "Is it" creates the question; I am asking for help here.
