Old 03-30-2009, 12:01 AM   #101
86Hoopty
86Hoopty's Avatar
Re: my 80 build
aww man, im only 17 haha, i need to do some **** to my truck, your build is really inspiring me to get to work hahaha, I NEED MONEY!!! lol, how do you get so much freakin money???? lol, nice truck man
86Hoopty is offline   Reply With Quote
Old 03-30-2009, 01:53 AM   #102
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: my 80 build
Thanks Hoopty, Oh I'm a broke redneck, The way me and my dad did it was being at the wright place at the wright time, like becoming goods friends with a paint and body shop owner and helping build a fence and retaing wall, for the paint and body, me and my dad took the truck all apart at his shop, we did most of sanding and a little body, we just had to buy the materials and a little labor cost, also the motor, transmission and hood we got cheap buying through the owner, also my neighbor Dad owned a body shop/ wrecking yard I bought a lot parts 1/3 of the price cost at a regular wrecking yard.The way we did it was we took the truck down to the cab sitting on the frame and left every thing that was still good intact the brake system and rear suspension the we replace the bad body panels and ,motor with good used one, and replaced all the front and cab bushing, and worn steering components, wile the body work was taken place the front suspension put back in place then nice coat of black paint was coated on the chassis and engine compartment then the engine was back in, then all then all the body work was done then primer then white pearl paint inside the cab, fenders, doors, and door jams, then it was put back together, and I was able to drive it then a month later then it back to paint shop, then it was home for good, Then it was my chance make it look good, started off with the stuff that made the truck replaced the junkie bumper and missing grille trim with reproduction, and seats then after that I would get parts a little at a time, but almost 3 years I've been working on my close to being done which never will be but close to be looking complete, but something I would never do is try to build something that going to take 10 + years of working on it and not drive until it been finished, because there's been a bunch of people that do it that way and never get to enjoy it because there out money and have to sell, I hope my advice helps you on your truck
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 03-30-2009, 01:54 AM   #103
flamingbig10
6.0 powered square
Re: my 80 build
my dad made me a wood trim piece out of some left over wood flooring
Aaron
Old 03-30-2009, 12:34 PM   #104
factory2wdblazer's
factory2wdblazer's's Avatar
Re: my 80 build
shoot some clear coat on that wood it will really make it stand out, give it a wet glossy look, it bring's wood life out of the wood.
factory2wdblazer's is offline   Reply With Quote
Old 04-07-2009, 11:39 PM   #105
flamingbig10
6.0 powered square
Re: my 80 build
I shot a couple coats of clear on the wood, looks a lot better, but I might go a way with the wood and use a factory non a/c piece
Aaron
Old 04-08-2009, 03:58 PM   #106
flamingbig10
6.0 powered square
Re: my 80 build
I finally got some good news on my seats the upholster finally got a chance to work on them so I should be getting them later today
Aaron
Old 04-08-2009, 09:34 PM   #107
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 04-09-2009, 11:41 AM   #108
menace121978
menace121978's Avatar
Re: my 80 build
looking good... a different bezel is gonna set the interior off nicely. well done man!
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 04-09-2009, 10:38 PM   #109
flamingbig10
6.0 powered square
Re: my 80 build
thanks, I decided I'm going to try a piece of sheet metal for the dash bezel for now, until I get some one to show me how to fiber glass the right way, and also the radio is going back to the factory spot
Aaron
Old 04-11-2009, 09:20 PM   #110
flamingbig10
6.0 powered square
Re: my 80 build
I finished up the dash bezel for gauges, and I started on the cover for the radio and headlight switch
Aaron
Old 04-11-2009, 09:50 PM   #111
factory2wdblazer's
Re: my 80 build
that look's good, your interior is coming along nice to keep up the good work.....
Old 04-12-2009, 12:08 AM   #112
flamingbig10
6.0 powered square
Re: my 80 build
thanks Factory
Aaron
Old 04-12-2009, 12:15 AM   #113
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 04-12-2009, 11:24 PM   #114
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 04-22-2009, 01:42 AM   #115
flamingbig10
6.0 powered square
Re: my 80 build
I started back working under the hood since looks fine to me for now
also relocated the hood release
I shot a quick coat of rattle can gloss black on the fender, to see what it looks like until I get is a spray gun with better paint
Aaron
Old 04-22-2009, 11:47 PM   #116
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 04-22-2009, 11:56 PM   #117
flamingbig10
6.0 powered square
Re: my 80 build
Today I finished up the temporary firewall peaces and added dynamat behind to keep it from radeling maybe the pieces will stay and I will use some pop rivets instead of the screws, painted the fenders, and made a cover for the windshield washer outlet tubes, and tomorrow I will temporary fix the inner fenders with a little massage, and prime and paint them, and then I'll add a hood liner, the under will be done for now
Aaron
Old 04-23-2009, 12:06 AM   #118
86Hoopty
86Hoopty's Avatar
Re: my 80 build
do you have alot of time to work on your truck? i want to do so much to mine but im always working or my old lady wants to hang out hahaha. is that a 350 you have in there? is it a lumpier cam?
Old 04-23-2009, 12:31 AM   #119
flamingbig10
6.0 powered square
Re: my 80 build
Yes, I'm unemployed at the moment, but I do a little old jobs, it 350 bored to a 355, with a mild r/v cam
Aaron
Old 04-23-2009, 01:09 AM   #120
86Hoopty
86Hoopty's Avatar
Re: my 80 build
oh awesome, yeah im trying to rebuild a 350 at the moment and put an r/v cam in it lol, I'm also thinking of putting a crank out of a 400 into it? the one thing i like about my truck is that its a longbed and not very many ppl do up longbeds haha, but your truck does look sweet by the way, maybe one day i can take a pic of all of my dads trucks haha, he has a 75 chevy 3500 freshly restored, a 77 Gmc c10 shortbed tubbed out and slammed (race truck) got an 87 chevy tubbed out and slammed, then my truck which is an 86 gmc wrangler edition thats just lowered with a 305 and exhaust lol
Old 04-23-2009, 01:37 AM   #121
flamingbig10
6.0 powered square
Re: my 80 build
thats good that your going to fix up a long bed, and thanks, your dad one nice collection
Aaron
Old 04-23-2009, 11:14 AM   #122
86Hoopty
86Hoopty's Avatar
Re: my 80 build
yeah, i wish it were mine :'(
Old 04-23-2009, 11:30 PM   #123
flamingbig10
6.0 powered square
Re: my 80 build
Aaron
Old 04-26-2009, 11:10 PM   #124
flamingbig10
6.0 powered square
Re: my 80 build
Today me and my dad made a sub box it fits stung in between seat belts and the center of the box is going to be for storage, but the box needs a little trimming, then it will maybe be covered in blue Naugahyde
Aaron
Old 04-27-2009, 03:24 PM   #125
warpig98
Re: my 80 build
with those bucket seats, you should build a center counsil style box like i'm going to be starting on this week.
THANK YOU SOLDIERS!!!!!
VISIT MY 78 BUILD THREAD
http://67-72chevytrucks.com/vboard/s...d.php?t=334884
warpig98 is offline   Reply With Quote
