99 S10 blazer odometer display
I have a 1999 s10 blazer that recently developed a problem with the odometer and shift indicator display. As I'm driving, the display will sometimes blink on and off and sometimes go out completely. Has anyone had this problem before and if so, how did you diagnose the cause and what was the fix.
Thanks! |
Re: 99 S10 blazer odometer display
Sounds to me you have either a bad ground, or the wire connecting into the back of the cluster, has some slop in it. Only way to really diagnose it is to pull it loose and jiggle the wire to see if you can repeat the problem. Because sometimes just from normal driving, the wires can break inside the insulation and loose contact.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
blood type; Retumbo
bad cluster or as it's correctly called and IPC. welcome to the wonderful world of late model GMs.
Thanks, I sure miss my old 72 c-10!
I started another post with the new maladies the odometer is presenting me. The odometer won't advance and the trip meter numbers change every time I start the truck. Just shoot me. lol |
68c15 is right gm has cluster problems ive seen so many cavaliers at work that come in with these issues. you will need a new cluster
Can you tell me how to get the old cluster out? COuld this problem be related to a transmission code I got when we scanned the truck?
Resistance is Futile
My X used to own my Blazer and she had related these type of things and I have never seen it. Could it be possible you have a bad battery, battery ground corrosion, or your alternator is failing??? Sounds like the others know whats up, but thought Id throw it out there anyway.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device Last edited by protrash64; 04-13-2009 at 10:04 PM. |
if the battery or alt. was bad you would have more problems then just erratic gauges. plus the battery light will come on way before you see any running issues.
and transmission codes will not be part of the ipc. im sure it uses the ecm to monitor the transmission sensors and will set the check engine light. the cluster is held in by the plasic panel around it. take it off and you will see the screws that hold the gauges to the dash.it can be a pain in the ... to get it owt but im sure you wont have to big of a problem |
oh and only the dealer can reset the milage on the odometer if you swap out the ipc we send ours in at work.
