#26 |
Re: Roadster Project
You are doing some very nice work from the looks of it. If I can only make one suggestion that would be invest in a gas set up for you welder because I have seen that inner shield come back and bite people in the ARSS after paint because of all the impurity's that get trapped in the puddle. Plus it will make your life alot easier for cleanup. But at this point I would have the metal work media blasted and use a good epoxy primmer/surfacer to seal what has been done.
Also I understand what nuke1 is saying about the windshield being sunk on most but with yours having the welded cowl it will blend right in and look sweet! Are your plans to put the latch in the doors or in the A pillar with only the strike bolt ion the door? Keep the pics coming. Kevin LFD Inc. |
#27 |
![]() Join Date: Dec 2008
Thats some awesome work!
#28 |
Great suggestion on the welder. I will look into that. I was going to lower the windshield but when I placed it in that position when I was mocking-it-up, I didnt like how it appeared to be chopped (I guess the rake plus lowering it). The body looked wide and the windshield looked small, plus I like the sleekness of the transition. To fill some of the transitions my friend it going to lead fill them to keep it all metal. Not too familiar with this method but looks kinda old school. I havent figured the strike as of yet. I'm hoping it will come to me in a vision...
I work on it every day so i will update regularly.
Blazer Project Last edited by gottwake; 05-01-2009 at 10:11 AM. |
#29 |
its just $$$$$
lovin it!!
#30 |
Under Construction
Nice build.....
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#31 |
PROJECT 7DEUCE
![]() Join Date: Dec 2002
B!tchin!!!!!
GO BIG GREEN ![]() MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
#32 |
What I would do since you don't have windows and don't need wires running into your door is mount the latch in the A pillar and the strike on the door it self. This keeps everything real clean and then mount some trick door pulls right under the dash so they are out of site but easy to reach for sleek look. I have seen a few done this way and it would flow well with what you have started. I also like doing body solder (todays lead free lead) and it would be a great way to finish off welded seams if you friend is good with it and knows all the tricks.
Kevin LFD Inc. |
#33 |
chevy only
![]() Join Date: Sep 2006
DUUUUDE VERY COOL, NICE WORK
CHEVY ONLY... Nothin Else ! |
#34 |
NICE Work!!
#35 |
That looks really good
70 SWB STEPSIDE 70 BLAZER 09 challenger |
#36 |
I'm definately going to watch this one. Your project isn't exactly my cup of tea, however your craftsmanship and motivation are phenomenal. Your also posting a lot of pictures which I like...
Keep it up ?? Are you filling on metal or will you epoxy first ? I'm not sure where you live either so that makes a difference. Guess you don't need epoxy first in California... |
#37 |
Some radical wordk but damn nice.
Anybody can restore a classic, takes a man to cut one up..... http://www.arnoldscustoms.com |
#38 |
Roadster Project? Not a very descriptive name? Should be something like: Freak"N"Stein.........
Kick ass. Love to see a guy making a ride his "own!" Nice work. |
#39 |
I like the way you did the windshield too. Going to be a trick ride when you are done. Keep up the good work!!!
#40 |
More work today. I finished filling in the driver fender and frenching-in the attachment pockets. I also finished welding the dash into the cowl. I will need to weld where I removed the rubber attachment strip that goes around the door (that I removed) but i'm gonna wait until I figure what I am going to do with the strikes. Also, I have a lot of work re-building the door posts and door panels.
Blazer Project |
#41 |
Im starting the passanger side now. Today I also, finished molding-in the cowl to the dash and pillar. I also finished welding the dash to the pillar here too.
Blazer Project |
#42 |
VA72C10
![]() Join Date: Mar 2008
Looking awesome...if you ever have to sell it....Look me up
![]() But please, don't sell it...I want to see an awesome project like this finished up...always seem like the coolest projects get sold before completed.
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#43 |
Forgot a couple pics...
Blazer Project |
#44 |
Now working on the pass inner fender. Wont finish it today.
Blazer Project |
#45 |
Heres a few pics of the frame. When we sectioned the cross member we also notched the frame for better clearance.
Blazer Project |
#46 |
A few misc pics...
Blazer Project |
#47 |
![]() Join Date: Apr 2009
Dam It"s Straght SiCk!!!!!!!!!!!!
#48 |
:awesome truck
#49 |
Great progress! How about a full side shot?
Kevin LFD Inc. |
#50 |
Man, my garage is so small! I will clean it out tomorrow and get a good one. These are crappy, but close.
BTW...I am sooo tired of welding.
Blazer Project Last edited by gottwake; 05-03-2009 at 11:54 PM. |
