Old 05-17-2009, 11:49 PM   #1
Cardiac
`05 Colorado
Newbie here. Daughters truck sits in the driveway with 3 of the 6 wheel studs broken off. they're the pressed in type and should be fairly easy to change but I can't get the brake shoes backed off to be able to get the drum off.
Is there an adjuster on these brakes?
Thanks in advance
Cardiac is offline   Reply With Quote
Old 05-18-2009, 06:47 AM   #2
truckdude239
truckdude239's Avatar
Re: `05 Colorado
there should be. stupid question but have you made sure the parking brake is off? the last one i did i just taped the drum off it was on real tight
David fuller
Ase Certified Mechanic
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
truckdude239 is online now   Reply With Quote
Old 05-18-2009, 09:30 AM   #3
Cardiac
Re: `05 Colorado
Yep, the pb is off. That drum is real tight, I can get it to move out maybe
3/8" then it sticks. I've removed a plug at the top of the backing plate but there dosen't seem to be any kind of notched wheel that I can get the brake tool onto.
Damn, I've got a manual ordered for this truck but it won't be here for a week.
Old 05-18-2009, 08:00 PM   #4
truckdude239
Re: `05 Colorado
here is the picture i have foudn i've had to use small screw drivers as the star whell doe not always line up with the whole in the backing plate
David fuller
2000 Tahoe 5.3l 378
Old 05-18-2009, 10:44 PM   #5
bwood
bwood's Avatar
Re: `05 Colorado
There is a tool made that is suppost to help with this. I think it is called a brake spoon. It sounds like you know what you are looking for. Judging by the pic from truckdude, it looks like it might be higher up than the hole. You might spray some brake cleaner inside the hole to help clean it up some. Also when you go to take the studs out, try pressing them out with a c clamp and a large socket or get a tool for pressing them out. THe axle flange isn't that hard to damage.
Here are some pics of the tools I mentioned:
http://store.summitracing.com/partde...5&autoview=sku
http://www.otctools.com/products/detail.php?id=1826
1998 GMC Sierra SLE 1/2 ton 2WD 305 Vortec
-Gibson Stainless Cat Back Swept Side
-SS Wheels
2005 Honda CRF250R
2006 Honda CRF150F
bwood is offline   Reply With Quote
Old 05-18-2009, 11:14 PM   #6
Cardiac
Re: `05 Colorado
Thanks guys, Ive got a couple versions of the brake tool and past experience as well as current info sz a couple ot taps with a hammer should pop the broken ones out. I'll use a drift punch and big hammer carefully.
