#151 |
Re: my 48 s10 swap
![]() ![]() ![]() few teaser pics!! |
#152 |
Re: my 48 s10 swap
![]() oh yea..... ![]() ![]() ![]() |
#153 |
Re: my 48 s10 swap
whatever happened to this thread?? is the truck finished? anyone know? I'm very curious to see it all finished!
#154 |
Re: my 48 s10 swap
All finished would be nice. The truck is still in progress. I'm getting the finals details ironed out as far as getting it running. Looks like the brake lines i wanted to order are on backorder. I need to buy some hose clamps and the fuel system is done. I have to buy about 2 feet of ground wire and wire up the battery to starter and ground. Then i will have to figure out the radiator holes, i should take pics and post them up; then radiator hoses and get another fitting for the trans cooler and it should be good to run. Anyone know how big of a trans cooler i should have for a 700R4 paired to a TBI chevy 350?
#155 |
Re: my 48 s10 swap
Glad to hear it's getting closer. I'm looking forward to seeing some more pics.
#156 |
Re: my 48 s10 swap
hey what kind of wiring harness are you using i know you had tbi i just got a fuel injected block and now am thinking of using fuel injection is it s10 or what
#157 |
Re: my 48 s10 swap
been away for a short time but your truck is really taking shape.have a safe holiday
#158 |
![]() ![]() Join Date: Jul 2002
Re: my 48 s10 swap
You have done a lot of great work on this truck. I cannot wait to see it finished.
#159 |
Re: my 48 s10 swap
hey any updates on your build? i'm gonna follow it until we get a video of that first burn out.
#160 |
Re: my 48 s10 swap
#161 |
Re: my 48 s10 swap
cool! we might be watching that "burnout" video soon.
#162 |
Re: my 48 s10 swap
the seats are out of a chevy equinox and has mentioned a few times they are heated and driver side is powered.
what i want to know is where he ordered the gauges from
1969 c-10- daily driver(sold) 1950 chevy 3600 current project http://67-72chevytrucks.com/vboard/s...d.php?t=402562 1955 ford f-100 1968 ford mustang 1966 ford mustang |
#163 |
Re: my 48 s10 swap
has there been any more progress on this build? have I missed something?
#164 |
Re: my 48 s10 swap
lrall nice build thread. What kind of gauges did you use? I can't see any mfg marks on them in the pic. Also what brand wiring harness did you purchase for the cab?
My build thread http://67-72chevytrucks.com/vboard/s...d.php?t=372267 49 4x4 build 51 Willys frame off beer getter. |
#165 | |
Re: my 48 s10 swap
If anyone has any experience with wiring up a Lokar floor shifter into a truck I could use some tips. I am a bit tripped up with that currently. I have the big stuff done but little things like power to the coil and such are holding me back. Its tough because I want it to be so clean and stock looking but I have to add a wire here and there. |
#166 |
Re: my 48 s10 swap
what are you needing to wire up the neutral safety switch and the lights in shifter for nighttime driving?
#167 |
Re: my 48 s10 swap
Doin a damn good job on this truck man!
#168 |
Re: my 48 s10 swap
Back from the dead.....I won't post up pics or vids till its running! I have the truck wired up to run but can't seem to get it to crank. A friend of my grandpas(hotrod wiring guy) is coming to help me clear things up and it *should* be ready to go soon! Then its seats, driveshaft, and brakes!
#169 |
Re: my 48 s10 swap
You are inspiring me to work on my truck some more ! Hope to see you on the road soon. Wave back at the guy in the junky black 72 !
72 Cheyenne Super 350ci 83 GMC Vandura 305ci 94 Buick Regal 3100 V-6 |
#170 |
Re: my 48 s10 swap
glad to see you posted young man! can't wait to see what you have been up to with your truck.
#171 |
Re: my 48 s10 swap
I have run into a bit of a problem...still. There is a neutral SAFETY switch and a park/neutral INDICATOR switch. 12v goes through the neutral safety switch(shifter on the floor) when key is turned to crank in park/neutral. No continuity in other gears(correct). My problem comes when the painless TBI harness wants me to wire the orange/black and black/white wire to the park/neutral indicator switch. I had these wires running to the neutral safety switch and that is WRONG. I hope we didn't fry the PCU :s Any hints/help? I am calling painless now.
#172 |
Re: my 48 s10 swap
Painless part # 60122 Park/Neutral Relay is the solution
#173 |
Re: my 48 s10 swap
The Truck CRANKS!!!!!!!!!!! I do have a question for anyone that may know. I am obviously working on starting the engine. However I don't want to burn up the power steering pump when i start it. Does anyone know if I can loop the power steering lines off the pump? I know one side is high pressure and low pressure. Will the high pressure blow the line off the return or?
#174 |
Re: my 48 s10 swap
I'll keep talking to myself :P The truck was cranking, now I am having an issue with the relay. Relay in, no cranking. Jumper wire, engine cranks. Oil pressure gauge is not working correctly, not sure what the deal is. The truck WAS cranking, but had no injector spray. Going to work with painless and figure out the cranking problem, then the gauge problem. Then the fuel problem. Then i *hope* it starts
#175 |
Re: my 48 s10 swap
One of these days I'll get to that point on mine. Wish I could give you great words of wisdom, but not sure what to check. Keep trotting along with it, your doing a great job.
