06-08-2009, 03:41 PM | #1 | |
Re: Tbi swap build thread
2) SBC and BBC harnesses are nearly identical with few exceptions: a) BBC used different IAC motor and connector is different - four wires. b) TPS may be different, early BBC used lever style TPS adjustable, while later used throttle shaft style - similiar to cars. Different connector. c) Some HD BBC did not use knock sensor (KS) and ESC modules - these engines used 1228747 ECM and can be positively identified by broadcast code printed on ECM label (four letter code). 2-1) You'll have to use 454 TBI ECM with your swap to keep things easy. In general 1227747 ECM (when loaded with appropriate BCC EPROM) was used with V6 (4.3L) and 305/350 SBC V8 and some 454 BBC. The 1228747 ECM has identical harness interface minus KS functionality for HD application. You can swap out your SBC 7747 ECM for 8747 when you perform the swap. Other than aforementioned points 2a and 2b SBC harness is good to go. //RF
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) |
06-08-2009, 03:54 PM | #2 | |
Next project: 1970 K10
Thanks for the help!
Bob 1970 Chevy K10 LWB "Goldie" 350/TH350 next project!! 1981 Chevy C10 LWB 355/TH350 - My son's truck LS SWAP FORUM! Tons of LS swap info here! PLEASE CLICK HERE TO SUPPORT THE GREATEST BOARD ON THE NET! CLICK HERE FOR THE FAQ INDEX by KRUE |
06-08-2009, 05:01 PM | #3 | |
The reason being that the BBC TB has 50mm bores and 80 or 90 lb injectors vs. SBC TB 46mm with 40/55/64 lb injectors depending on engine size. You may be able to get 454 started, but the moment you ask that 454 to deliver power it will lean out and fall on its face. IMHO the swapping harness connector ends is straight forward, except for IAC which may require pin swapping. I believe that I have a set of notes related to this issue. To me revamping harness to mach sensors (2x) is not that difficult. Take a look at two TBI (SBC/BBC) setups first before jumping to any conclusions. //RF
06-08-2009, 05:31 PM | #4 |
Thanks for the info! I know getting a little ahead of myself here, as I haven't taken possession of either truck yet. Just trying to refresh my knowledge of these TBI's after not messing with them for 20-some years.
06-08-2009, 07:00 PM | #5 | |
//RF
06-08-2009, 10:17 PM | #6 | |
454 BBC (87-89) OE# 17087021 350 SBC (93-94) OE# 17093030
"The Beast" 1975 Chevrolet C20 longbed 350/700R4! with 3inch body lift Dual Flowmasters Super 40's! TBI retrofit completed (2007-07-29) New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17) Last edited by augie; 04-20-2011 at 12:31 AM. |
