Old 03-28-2003, 09:01 PM   #1
'71k-10
ORD's shackle flip? Good/ bad
Well i noticed that alot of you guys have used Offroad Design so i checked it out. I also have looked at Yukon Jack page and really like the shackle flip they offer. i have one question. I have a 1971 half ton 4x4 and when i crawled underneath the other day i noticed that the frame is not a square tube like most other frames but instead it is half of a square. (hope you get what i mean) like a sideways u. is this normal. does anyone else have this? But i was also wondering if this would affect the installation of the shackle flip setup. any advice is great or any comments on this kit.
Thanks alot
'71k-10
'71k-10 is offline   Reply With Quote
Old 03-28-2003, 11:36 PM   #2
breeh
Recovering 67-72 Addict
breeh's Avatar
The "square tube" frames that you are talking about did not come about until 1988 (I think). For sure, none of the 67-72 trucks had this. They are all the "sideways u" that you mention. So don't worry. The shackle flip will work if that is what you want.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt.
"Friends call me cruzer cuz I like fast cars and fast women"
breeh is offline   Reply With Quote
Old 03-29-2003, 01:16 AM   #3
'71k-10
thanks breeh i was hoping this was standard and not some wild mod. of the previuos owner.
1971 chevy stepside-350 bored 30 over, holley carb, headers,weiland intake, 3 angle valve job-4" tuff country lift with ORD shackle flip, ORD HD front shackles, 33x12.50x15 mastercraft M/T-Th-350 automatic. Primer grey.
Old 03-31-2003, 01:07 PM   #4
Yukon Jack
Yukon Jack's Avatar
Before you go for the flip make sure you don't have any broken leafs. During my install I saw that I did have a broken leaf not a major problem but just something to be aware of. Also the flip appears to move the axle forward a bit - may not matter to you but it does bother some people. Easily correctable with the Zero Rate block offered by ORD as it can be used to offset the axle 1" back or forward.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
