Old 07-11-2009, 03:38 PM   #326
joe231
joe231's Avatar
Re: Daverods project 66
Originally Posted by daverod View Post
Been out burning around in the new 64. Going alittle further each time. Can't seem to get mt fuel gage working right. When I turn it on it pegs to full. When I turn it off it reads about 1/4. I know it has gas because I just put $20 in it. I'm thinking maybe my sending unit is off? It seems to be wired right.
check your wire first, sounds like it is either shorted or open...sorry I can never remember which is pegged full
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 07-11-2009, 05:14 PM   #327
daverod
SSN 706
daverod's Avatar
Thanks Joe I'll check it tonight. I think you 're right. The 1/4 when turned off was messing with me. Checked the wires with an ohm meter. There not shorted. Ran one wire from the sending unit to the gage and another from the fuse box to the gage; same thing peged. Hooked up the wires to a old dash/gage from my 66; same thing peged. I wishing I still had my 66 gas tank. Never throw anything away. I do like the dash of the 66 better. It has gages insted of lights. Going to see if I can find a sending unit on a old deserted truck I know about.
daverod is offline   Reply With Quote
Old 07-12-2009, 10:19 AM   #328
daverod
SSN 706
daverod's Avatar
Decided to pull my sending unit before going out to the old truck to look for a new one . Look what I found. Just not sure how to fix it? Looks to small to weld. I guess it's copper. I've never braised anything and have no idea how. Anyone? What about jb weld?
Old 07-12-2009, 11:04 AM   #329
ruffrida2005
Member of the longbed union.
ruffrida2005's Avatar
JB weld would work, but it's getto. If not cleaned up right you could have it fall off and get stuck. How much is a new sending unit?
Paul
88 GMC Crew Cab dually, 454/T400
64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it!
92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759
ruffrida2005 is offline   Reply With Quote
Old 07-12-2009, 11:22 AM   #330
joe231
joe231's Avatar
I think that is pretty common.
you could probably braze it with a propane torch.
CHEVY ONLY
Old 07-12-2009, 12:16 PM   #331
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
the dropmember looks good
Gage
1967 C10 Shortbed Stepside
jgh64pkup is offline   Reply With Quote
Old 07-12-2009, 12:41 PM   #332
daverod
SSN 706
daverod's Avatar
Checked it out. It is getto, but I'm kinda getto. Trying to clean up my act. It does'nt conduct electrons. New unit is $50 plus shipping. $50 saved.
Old 07-12-2009, 12:45 PM   #333
daverod
SSN 706
daverod's Avatar
I did'nt understand what brazen was all about. I have soldered copper pipes before. Cleaned it up and soldered it back together. Works good now still have to mess with bending the rod to get it read right. Thanks Joe. I think it's within a 1/4 or so. Time to go burn some gas.
Old 07-12-2009, 12:56 PM   #334
daverod
SSN 706
daverod's Avatar
I'm going to change this out and put in the 66 dash. I think I can even get a tech for it. Somthing to do when I get bored, I'm kinda bored now.
Old 07-12-2009, 03:19 PM   #335
joe231
joe231's Avatar
cool man, brazing and soldering are pretty much the same idea, typically when you solder you use an iron and solder, brazing you use a torch and some type of filler rod.
CHEVY ONLY
Old 07-12-2009, 04:29 PM   #336
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
i have one thats brand new you can have but you have to take the gas tank also
Gage
Old 07-12-2009, 04:37 PM   #337
daverod
SSN 706
daverod's Avatar
I had a tank and threw it away. It's fixed now so I guess it does'nt matter. Untill my tank starts leaking.
Old 07-12-2009, 04:38 PM   #338
daverod
SSN 706
daverod's Avatar
Thanks It was easy to do.
Old 07-12-2009, 04:47 PM   #339
daverod
SSN 706
daverod's Avatar
My green temp light comes on when I start up then it goes out after a couple minutes. Is this normal? I'm thinking that maybe it's overheating and the red bulb is burnt out. It doesn't seem hot. Went to swap bulbs did'nt even have a red bulb wrecked the green one getting it out. Guess I'm off to get some bulbs.
Old 07-12-2009, 04:51 PM   #340
jgh64pkup
Sunburst C10!!!
jgh64pkup's Avatar
so you fixed the sending unit
i was joking about the tank
Gage
Old 07-12-2009, 05:53 PM   #341
daverod
SSN 706
daverod's Avatar
Ya I soldered it back together works good so far.
Old 07-13-2009, 12:56 AM   #342
protrash64
Resistance is Futile
protrash64's Avatar
Thats the COLD lite!!! The original sender had 2 readings. Cold when you start and then operating temp. If it overheats it turns red.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 07-13-2009, 09:10 AM   #343
daverod
SSN 706
daverod's Avatar
I was worried because it goes out after awhile but I guess thats normal. Good thing I checked because it did'nt have a bulb in the red light.
Old 07-13-2009, 05:42 PM   #344
daverod
SSN 706
daverod's Avatar
Cleaned 50 years of crap off my A arms and cross member. Lowered the arms down and cut 1 1/2 coils off. Putting on some new pads and lines while I'm at it. Can't wait to put the wheels back on. Put a new bulb in my red and green warning light now nothing works. Have to mess with it some more. Habor freight jack stands $19 for 2. There going fast get some now. My truck looks like a stink bug.
Old 07-13-2009, 09:19 PM   #345
daverod
SSN 706
daverod's Avatar
Messed with my temp lights some more. If I take the red light bulb out then the green light works. If I put the red bulb in nothing works. There all new bulbs. Maybe a short? Maybe a bad temp senser? Now I know why it did'nt have a red bulb.http://picasaweb.google.com/normanme...eat=directlink I think I need the next page.
Old 07-13-2009, 10:08 PM   #346
ruffrida2005
sounds like you have a bad ground on the lights.
Paul
Old 07-13-2009, 10:17 PM   #347
daverod
SSN 706
daverod's Avatar
Well, the green light works? Except when the red bulb is pluged in. If I take the red bulb out the green works. Turned out the Temp. sending unit? going into the radiator hose is messed up. When I move the wires going into things change ( one light, no lights, both lights). Can't seem to find one in LMC.
Old 07-14-2009, 09:19 AM   #348
daverod
SSN 706
daverod's Avatar
Anybody know what the thing with the wires going into it is called and where I can get a new one? It goes to the temp. warning lights on a 64.
Old 07-15-2009, 12:36 AM   #349
Captainfab
60-66 Nut
Ordinarily a temperature sending unit has only one wire. Looks like that one has 2 or 3 wires? I don't know what else it would be being it is in the coolant.
Old 07-15-2009, 08:52 AM   #350
daverod
SSN 706
daverod's Avatar
It has 2 wires and it looks like it goes in the coolant. When I wiggle it it makes my temp warning lights (green/red) blink on and off. I think it's bad and I need a new one.
