Old 07-12-2009, 03:56 PM   #1
MI2CHEVYS
MI2CHEVYS's Avatar
Check it out
SO WHAT DO YOU THINK ?
I JUST RECENTLY FINISHED THE 2 LINK, MOUNTED THE 31GAL TANK FOR MORE CLEARENCE, AND ROUGHED IN THE BODY WORK ENOUGH FOR ITS FIRST COAT OF PRIMER.
BEFORE...
AFTER...
ANYONE HAVE ANY IDEAS ON HOW TO GET THE FRONT A LITTLE LOWER?
MY DAD HAD A SAYING " DO IT RIGHT OR GET THE F**K OUTA HERE!"
http://s657.photobucket.com/albums/u...view=slideshow
MI2CHEVYS is offline   Reply With Quote
Old 07-12-2009, 08:58 PM   #2
bagged74
its just $$$$$
bagged74's Avatar
Re: Check it out
Dropmember
bagged74 is offline   Reply With Quote
Old 07-12-2009, 09:27 PM   #3
MI2CHEVYS
MI2CHEVYS's Avatar
Re: Check it out
Yea I know i checked it out but i just got laid off and unemployment doesn't pay that good. I just might have to wait for next years tax returns.
Nice Blazer by the way!
Old 07-12-2009, 09:36 PM   #4
bagged74
its just $$$$$
bagged74's Avatar
Re: Check it out
you could always do a Z
Old 07-12-2009, 09:59 PM   #5
powder2
powder2's Avatar
Re: Check it out
looks good man i would do the crossmember
powder2 is offline   Reply With Quote
Old 07-12-2009, 10:17 PM   #6
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: Check it out
What do you have in front now?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 07-12-2009, 10:59 PM   #7
MI2CHEVYS
MI2CHEVYS's Avatar
Re: Check it out
Thanks Guys
3" DJM spindle w/ Firestone 2600 bags w/ plates up top and cups down below. I was thinking about cutting the cups just a little to maybe get an inch.
Would control arms help?
Old 07-12-2009, 11:07 PM   #8
bagged74
its just $$$$$
bagged74's Avatar
Re: Check it out
oh yeah, cut the cups for sure!
Old 07-12-2009, 11:45 PM   #9
87 dually burb
my short bus
87 dually burb's Avatar
Re: Check it out
remove you cups and cut in some 8" pipe
I used a 2.5" piece lays on crossmember and misses heater box by .5"
I also have 3" belltec spindles with a upper bag plate like your
I'm running 255/70/15 on a 8" rallie
on my burb I went from this
to this
hope this helps cost me $150 for the metal and having it welded in
**90 burb**bagged,shaved**(about done)*********
**91 burb**stock worker for now****************
*********only squares for me******************
87 dually burb is offline   Reply With Quote
Old 07-13-2009, 12:03 AM   #10
MI2CHEVYS
MI2CHEVYS's Avatar
Re: Check it out
How much do you think I should cut off?
Do you know of anyone who has used plates on the lower control arms like these do you think these would help?
Old 07-13-2009, 12:40 AM   #11
MI2CHEVYS
MI2CHEVYS's Avatar
Re: Check it out
to this
Did you have any issues with camber or any other suspension issues by doing this?
I wouldn't have to worry about heater box
Old 07-13-2009, 08:11 AM   #12
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Check it out
Looks good! Cut 1" off, that is what I did but do not cut any more then that you could rub your bags..
tvblazer78 is offline   Reply With Quote
Old 07-13-2009, 06:42 PM   #13
MI2CHEVYS
MI2CHEVYS's Avatar
Re: Check it out
Thanks tvblazer I think i'll try that first.
By the way man love yor blazer mine will also be BLACK, that was the original color but my interior will be RED
Old 07-13-2009, 11:42 PM   #14
87 dually burb
my short bus
Re: Check it out
post a pic to compare
looking good how did the rear sheet metal turn out
how much did you raise the gas tank
Old 07-14-2009, 08:27 AM   #15
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Check it out
Thanks man!
Red and black pops!
Old 07-15-2009, 01:22 AM   #16
MI2CHEVYS
MI2CHEVYS's Avatar
Re: Check it out
I havent finished the floor yet I'm planning on cuting the inside of the bedsides and moving it up to where the tubs are about an inch from the bed rails, that way I can bolt the tubs up just incase i need to remove them in the future for something. I will post pics as soon as I get to that.
I will take som measurement of the tankand let you know, but I did have to remove the crossmember gas tank support just behind the axle and clearenced the tank supportat the rearundr the tailgate. I'll post some pics for u.
Old 07-15-2009, 08:31 AM   #17
babyJay
Arrived on a Pale Horse
babyJay's Avatar
Re: Check it out
Doesn't that diff need a panhard bar? How will it keep from going side to side?
Jason
87 V30 350TBI/400 White w/Boss V-plow
89 R3500 CC SRW
babyJay is offline   Reply With Quote
Old 07-15-2009, 09:42 AM   #18
blazer2007
Re: Check it out
could u post some pics of the 2 link,thanks
blazer2007 is offline   Reply With Quote
Old 07-15-2009, 10:02 PM   #19
Tagg33
Tagg33's Avatar
Re: Check it out
Nice job, I look forward to watching your progress. I'm just about to smooth my firewall, hopefully this weekend.
Ryan
84 SWB, C4 IFS Crossmember, C4 IRS, RE7 bags, WCC 3pc 22"s
My reBuild: http://67-72chevytrucks.com/vboard/s...d.php?t=346328
Tagg33 is offline   Reply With Quote
Old 07-16-2009, 11:45 AM   #20
MI2CHEVYS
MI2CHEVYS's Avatar
Re: Check it out
I need to mock up the motor and trans first to get the pinion angle correct.
Old 07-16-2009, 11:46 AM   #21
MI2CHEVYS
MI2CHEVYS's Avatar
Re: Check it out
It's a lot of work they wernt very straight from the factory to begin with, Good Luck!
Old 07-16-2009, 03:59 PM   #22
MI2CHEVYS
MI2CHEVYS's Avatar
Re: Check it out
made the bars from 1.5"O.D x .25wall DOM (Expensive)
Bag brackets are from suicidedoors
Old 07-16-2009, 09:08 PM   #23
bagged74
its just $$$$$
bagged74's Avatar
Re: Check it out
do those bars have a pivot on each end?
Old 07-17-2009, 12:57 AM   #24
MI2CHEVYS
MI2CHEVYS's Avatar
Re: Check it out
yes in the front of the bar it has urethane replacment bushings, or i could use stock replacement. The rear of the bar has large heim joint, i wanted to be able to adjust it if needed. I still haven't installed the suicidedoors pan hard bar. I tested the system and it travels fine without any binding
Old 07-17-2009, 09:58 AM   #25
tvblazer78
Low & Fast!
tvblazer78's Avatar
Re: Check it out
I like that, looks simple. How are you going to run your shocks?
