Old 07-17-2009, 05:25 PM   #101
menace121978
menace121978's Avatar
Re: Prepping for a BBC conversion
kenny, awesome build! i'm not sure how i missed it without posting. that big block sounds sick and the paint looks sweet! nice job and cool thread!! Dennis
"Dennis the Menace"
1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E
MY LS SWAP/FRAME OFF BUILD BOOK
2006 TBSS way too much to list
menace121978 is offline   Reply With Quote
Old 07-19-2009, 10:12 PM   #102
87Lowrider
Navy Radioman Veteran
87Lowrider's Avatar
Thanks, and thanks for the props too!!
Gonna do the interior next.
Kenny
87Lowrider is offline   Reply With Quote
Old 07-27-2009, 11:02 AM   #103
grinch4om
dang its hot
grinch4om's Avatar
do you still have that 76 body?
grinch4om is offline   Reply With Quote
Old 07-27-2009, 11:40 AM   #104
ttjordan25
I am working on a 76 body.
ttjordan25 is offline   Reply With Quote
Old 07-27-2009, 12:11 PM   #105
87Lowrider
87Lowrider's Avatar
No, all I have left is the radiator, washfluid container, intake, carb, exh mani, etc... truck was sold for parts by original owner.
Kenny
Old 03-22-2010, 09:49 AM   #106
87Lowrider
87Lowrider's Avatar
Here's the lowrider next to a buddy's '87 4x4 during a car show (her first) last year. Won "Best Truck" out of nearly 200 in the field. Not bad for her maiden voyage.
Old 03-22-2010, 10:00 AM   #107
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Well deserved. Sick truck man. I love the flat black.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 08-31-2010, 03:55 AM   #108
baclay9
Very nice man. I am fixing to start a 454 conversion in my 83 1/2 ton and your thread has been very helpful. I hope you dont mind me picking your brain as I go.
baclay9 is offline   Reply With Quote
Old 08-31-2010, 08:56 AM   #109
87Lowrider
87Lowrider's Avatar
No problem.. This board was a tremendous assistant to me when i was putting it all in the truck. Bunch of great folks here!!
Old 08-31-2010, 09:16 AM   #110
lo72
Truck Junkie
lo72's Avatar
Hey 87Lowrider sweet truck, what type of headers are you using? thanks!
lo72 is offline   Reply With Quote
Old 08-31-2010, 09:23 AM   #111
87Lowrider
87Lowrider's Avatar
Thanks, right now, they're dynomax, but I'm getting ready to switch to hooker or something else (stainless or coated, not sure). They rusted really bad and look terrible in the engine compartment so I'm putting some nice shiny ones in there.
Old 08-31-2010, 03:18 PM   #112
lo72
Truck Junkie
lo72's Avatar
Video of your rat idling is like music...what are the specs on the cam? Baclay9 didn't mean to jack your thread!!
Old 08-31-2010, 03:29 PM   #113
87Lowrider
87Lowrider's Avatar
Check out the link below to my pic gallery.. It's in there.
http://67-72chevytrucks.com/vboard/a...&pictureid=487
Old 08-31-2010, 03:38 PM   #114
baclay9
It's not my thread bud...get after it!!!
Old 09-01-2010, 08:25 AM   #115
baclay9
When you installed the Becool radiator I noticed you said you used the upper mounting hardware from your SB radiator. What about the bottom hardware. Do I need to come up with the BB radiator supports and stuff for the bottom?
Do you think if you would have been running the dual electric fans with the 4 core BB radiator you had originally they would have cured your overheating problem?
Old 09-01-2010, 10:39 AM   #116
87Lowrider
87Lowrider's Avatar
I didn't have to change the bottom support. The radiator fit perfectly.
I didn't try a dual fan on the original radiator so I'm not sure of the results. But, the BeCool keeps the engine temp around 175-185 when driving above 40-50mph. Otherwise, it gets up to around 200-210 in town.
I don't let it do that without having to stop anyways so it's no concern for me. If it gets too hot for my tastes, I either stop or find an open road and cool it off.
Old 09-05-2010, 10:02 AM   #117
baclay9
Hey Kenny, are you still happy with your cam choice? Is it making plenty of vaccum to run your power brakes and such? It is hard to tell from the video but does it have a fairly choppy idle?
I ended up scoring a set of 781's and I think I am going to go ahead and have them opened up to 2.19/1.88 as you did. If you had it to do over again would you have some porting work done or are you happy with the performance as is?
If your setup is working well for you I would like to copy cat it so I will more or less know what to expect when I fire it up the first time. LOL
Also, are you running a hydrualic flat tappet cam?
I can't remember if you said or not but what stall are you running with that setup?
Sorry for all the questions. Thanks man!!!
Old 09-05-2010, 11:34 PM   #118
Gordonr1973
Home Built '87
Gordonr1973's Avatar
subscribed!
Gordon
1998 White Chev ext cab 2WD (Summer Project) http://67-72chevytrucks.com/vboard/s...d.php?t=408424
1987 Chev Silverado SWB (Winter Project Rebuild) http://67-72chevytrucks.com/vboard/s...d.php?t=424833
Truck Club http://67-72chevytrucks.com/vboard/s...d.php?t=466969
Gordonr1973 is offline   Reply With Quote
Old 09-07-2010, 09:20 AM   #119
87Lowrider
87Lowrider's Avatar
No problem.
The cam is pretty "choppy", people comment about it every time I take it out, which is a couple times a week. I've noticed a few times that the brakes are a bit hard to press on but it's only in the morning when I back it down the driveway. Once I get it warmed up, it's fine.
Several of us around here have a running joke about the cam... "I've got to get that miss fixed"
Since this is my first "hot rod", I don't have anything to compare it against. The heads came with the motor so I was lucky to get what I got. I'm sure I'll do something different when I get the '57 done. But, this motor has all the power I need. The Cam is like a Big German Shepard. Even the ponies stay away!!
The Cam is a hydraulic flat tappet. Somewhere on here should be all the part numbers I used when i ordered the top end for this motor which is (was) all new. The bottom end was sound so a rebuild of the heads was the only other thing I needed.
Valve train is a bit noisy but some say that's normal. I've got about 6000 miles on it now.
Here's some more vids from my youtube page;
Here's a link to a local thread with new paint on the truck back in the spring.
http://67-72chevytrucks.com/vboard/s...d.php?t=402574
Good Luck!
Ken
Old 09-07-2010, 09:30 AM   #120
87Lowrider
87Lowrider's Avatar
Originally Posted by Gordonr1973 View Post
subscribed!
Thanks!
Old 09-08-2010, 11:42 AM   #121
baclay9
Do you happen to know what stall you are running. I called Comp and they reccomended the same came you have. Which isn't suprising I guess considering our setups will be similiar.
Where did you order your valves from? Did they come from PBM directly? When it shows the price of the valves is that for a set of 8?
Old 09-08-2010, 12:03 PM   #122
87Lowrider
87Lowrider's Avatar
I don't know if the stall is on the cam card or not. My guess it would be in the 2500 range though. My brother is a machinist and works just outside of Lousiville, KY. PBM is local for him and is where he gets alot of parts from. Yes, believe they sell valves in boxes of 8.
Old 09-08-2010, 12:22 PM   #123
baclay9
The guy at comp told me I would be alright with a 2000 to 2200. If you happen to find out what yours is for sure could you please let me know
Old 09-21-2010, 12:43 AM   #124
baclay9
From the looks of it you went with a mechanical advance distributor over a vacuum advance. Could you tell me why. There is a guy on CL here that has the same dist. you have, a MSD-6AL ignition box, and a blaster 2 coil for $340. I just wanted to make sure I shouldn't be running a vacuum advance befor I dropped the dough on it.
Old 09-21-2010, 09:28 AM   #125
87Lowrider
87Lowrider's Avatar
I talked to several racers who recommended the various setups. The only thing I'd like to do is change out the springs in the distributor and see how that helps/hurts. The Digital 6 handles the rest.
So, I trusted what they said and so far it's been a great decision for my application which is a driver to and from work occasionally, and out on the weekends cruising around. It's got about 5000 miles on it now but it's never been HAMMERED and ragged on yet. The most it's seen is about 4250 and that was fun!
Not a bad price.
