Old 03-15-2008, 06:04 PM   #1
myoldchevytruck
Retired Air Force Veteran
myoldchevytruck's Avatar
In-Line Frame Mount Transmission Cooler
I'm interested in installing an In-Line Frame Mount Transmission Cooler.. Is anyone using one? Is it working for you. What is the difference between the longer and shorter tranny coolers. Also, some coolers have an inlet/outlet on the same side and some have them on opposite sides. Any feedback? Thanks.
Harry
69' SWB Step Side 1/2 Ton w/68' Front Clip
Swap from Leafs to Trailing Arms (Complete)
Swap 6 Lug to 5 Lug (w/ Disk Brakes in Front)
3/6 Drop
Help Support The Board
Click Here For Information On How To Subscribe
Krue's FAQ Page
Vendors
myoldchevytruck is offline   Reply With Quote
Old 03-15-2008, 06:19 PM   #2
67ChevyRedneck
67ChevyRedneck's Avatar
Re: In-Line Frame Mount Transmission Cooler
You mean like this?
I don't have a tranny temp gauge, but I'm sure it's doing its job. This is mounted on the front crossmember. It's the shorter one with the lines going in on the same side.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-15-2008, 06:26 PM   #3
c10addict
c10addict's Avatar
I run one on my Nova.... You can see it under the front bumper in this pic... It works well and trust me the tranny takes some abuse!
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08
67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast.
64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten..
54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread...
07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind..
http://67-72chevytrucks.com/vboard/s...d.php?t=339340
See pics of my trucks in my profile
c10addict is offline   Reply With Quote
Old 03-15-2008, 06:30 PM   #4
myoldchevytruck
Exactly what I wanted to here. Are both of you guys running steel braded lines?
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 03-15-2008, 06:31 PM   #5
67ChevyRedneck
I'd rather not talk about what I used.....
Jesse James
Project "On a Dime"
Old 03-15-2008, 06:32 PM   #6
myoldchevytruck
Whatever it is, I'm sure it works
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 03-15-2008, 06:35 PM   #7
myoldchevytruck
I seen an 18" cooler at a show this weekend for $45.00. I should have bought it.
Harry
3/6 Drop
Krue's FAQ Page
Vendors
Old 03-15-2008, 07:09 PM   #8
cdowns
cdowns's Avatar
they're good coolers/ the ones with both fittings on the same end are double pass meaning the fluid goes thro the length of the cooler twice as the ones with fittings on each end the fluid goes thru once
Old 03-15-2008, 07:28 PM   #9
c10addict
c10addict's Avatar
Thats how mine is set up... I hard lined mine..
Old 03-15-2008, 07:48 PM   #10
SactoJim
SactoJim's Avatar
Here's mine (24") mounted on the frame rail on passenger side. I used "push-on" style fittings to plumb it. Hasn't seen alot of road time yet, so I don't know how well it works.
Another nice thing about having inlet/outlet on same side is it's easier to plumb.
Also.....I don't think one is better than the other in regards to cooling (dbl pass vs. single). When I looked inside mine it looked like one big chamber and even if there was a divider down the middle to get "dbl pass" you're still only using half the cooler on each pass.......just can't see it making much of a difference. It's all about surface area of the cooling fins.
I would just get the longest one that will fit your application.
72 Cheyenne SWB Fleet
Nut & bolt frame off in progress...99.9999%
- supercharged 383
- 4 wheel discs
- relocated fuel tank
My Build Thread
SactoJim is offline   Reply With Quote
Old 03-15-2008, 08:10 PM   #11
jayharrell
Gettin By on Gettin By
jayharrell's Avatar
Are you guys running those inline cooler only, or in addition to a raditor wil tranny cooling built in??
jayharrell is offline   Reply With Quote
Old 03-15-2008, 09:18 PM   #12
67ChevyRedneck
Originally Posted by jayharrell View Post
Are you guys running those inline cooler only, or in addition to a radiator with tranny cooling built in??
That's the only "proper" way to go IMO.
Jesse James
Project "On a Dime"
Old 03-15-2008, 09:19 PM   #13
SactoJim
SactoJim's Avatar
Mine's not run is series with my radiator, but I do have a derale pan that has cooling tubes in it.
When I start driving it more, I may route through radiator if I need (I have a tranny temp gauge hooked up)
- supercharged 383
- 4 wheel discs
My Build Thread
Old 03-16-2008, 09:30 AM   #14
kelsfine69
18 Till I Die
kelsfine69's Avatar
Any more pics of that install???
2011 GMC Acadia
1969 GMC BBC LS7
2007 GMC Crew Duramax
1987 Camaro Iroc 350 Tuned Port Injection
42000Km
1987 Chevrolet Silverado 350 TBI
1987 Chevrolet Silverado 350 TBI(yes 2)
Take me drunk, I'm too home...
kelsfine69 is offline   Reply With Quote
Old 07-24-2009, 07:22 AM   #15
Stinger 99
Stinger 99's Avatar
I've used several over the years and have found that the extra price for the two pass filters is a little deceiving. Most filters I have been able to look in to had a single chamber inside. Doesn't seem like there is any, or if any at all, value there for the extra money spent. If I'm concerned about oil temp I would normally use two single line, cheaper units, and hook them up on the same run. I put a temp gauge on the out side of the second one to determine operational temp.
If you are really curious as to the effectiveness of the unit, use a laser temp gauge and check the line going into the first unit, and then about a foot or so behind the second one. If there is no Delta, you wasted your money and time
1966 Chev C10 Custom LB
Built 327ci, 700R4 Stage II, Mezier Elec Water Pump, Vintage Air, CPP Disks w/ABS, 22" Billets w/ Goodyear Eagle Low Pro's, Rear Pan, Hidden Hitch, Bagged
Stinger 99 is offline   Reply With Quote
Old 07-24-2009, 09:36 AM   #16
chevyguy_72
Vintage Evil
chevyguy_72's Avatar
I wonder if they would get enough airflow mounted inside of a side frame rail to do any good. Like on the one pic. I can see the others that are up front doing just fine.
chevyguy_72 is offline   Reply With Quote
Old 07-24-2009, 12:29 PM   #17
fastom
That's right, it's Copper!!
fastom's Avatar
Here's mine, it works great!
Tom:
1968 Chevy SWB
ZZ383 W/700R4
Gen-II Compact Vintage Air System
PPG paint, Mandarin Copper and Vanilla Shake.
http://www.hubgarage.com/mygarage/fastom
Stupid should hurt and eventually become fatal!
fastom is offline   Reply With Quote
Old 07-24-2009, 12:37 PM   #18
mclairmo
I have never used one of these frame rail mounted coolers but I would be afraid of puncturing it or damaging it while driving and maybe losing all my trans fluid. However, I plan to take my truck out to the desert. Also, you need good airflow around the cooler to take away the heat. Also, I believe the fluid should go through the radiator first and then through the added on cooler for even more cooling of the fluid.
mclairmo is offline   Reply With Quote
Old 07-24-2009, 11:23 PM   #19
rodstored-72
chevy truck fan
rodstored-72's Avatar
i was going to run the summit rectangular one in the same location that the others have (under the front bumper), but i got talked out of it by a friend of mine who thought that the location would get alot of road debris abuse. i was also looking into getting the inline frame one but did not for the same reason. i am currently running mine to the radiator cooler on the side. it is a 383 motor & a 700r4 tranny. what is the opinions of you guys that are running these types of coolers in relation to road debris & such????
rodstored-72 is offline   Reply With Quote
