Old 07-28-2009, 09:38 PM   #1
kenny_strong
kenny_strong's Avatar
Battery draw?????
I got my 66 shipped in fron CA a few weeks ago and had to put a new alternator on it. It now puts out about 14 volts but the battery is dead after sitting all night.
I charged it up, and let it run for about 2 hours and shut it off. I pulled EVERY fuse and hooked a test light from the neg post to neg cable and its still lit up. I let it sit all night and its dead again.
What do I do next?
What could it be?
kenny_strong is offline   Reply With Quote
Old 07-28-2009, 10:33 PM   #2
protrash64
Resistance is Futile
protrash64's Avatar
Re: Battery draw?????
I've had my '64 for 8 years and it still kills batteries after a week. 1/3rd of a volt draw that I havent found. I'm going to fix it with a new harness....sad thing is I'm an electrician and never tracked it down.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash
64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban
66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852
STRENGTH/DETERMINATION/MERCILESS/FOREVER
.......posted via stationary device
protrash64 is offline   Reply With Quote
Old 07-29-2009, 11:31 AM   #3
Fred T
Cantankerous Geezer
Fred T's Avatar
Try disconnecting the alternator.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 07-29-2009, 06:09 PM   #4
mike73
mike73's Avatar
Parasitic load............... check for voltage @ your switches and the voltage regulator with the ignition in the off position. On my ignition switch my key comes out when its at the acc position.
mike73 is offline   Reply With Quote
Old 07-29-2009, 10:27 PM   #5
Corts60
Just here to tinker
Corts60's Avatar
My Nova stumped me on this for awhile. It turned out I put the horn button in wrong and it was constantly grounding. Of course I had the actual horn out of the car so I couldn't hear it. That alone ended up killing the battery in about a weeks time of sitting.
I fixed the horn button, and the problem was solved! Little stuff like that is enough to make you....
Old 07-29-2009, 10:44 PM   #6
mike73
mike73's Avatar
open circuits even if they are grounding will still consume power no matter how small.... it could be anything its just a matter of probing around when the power is off.......
Old 07-29-2009, 11:07 PM   #7
kenny_strong
I unplugged the plastic plug on the alternator and that fixes it. I have a wiring nightmare from the PO. The main positive cable from the battery goes to the starter and the hot wire from the alt. (10 gauge)goes to the starter. 1 wire goes to the electric choke and they have a few more wires spliced into that. I need to find the right way to wire everything and start over.
Old 07-29-2009, 11:56 PM   #8
mike73
mike73's Avatar
Is your truck stock? or has it had ''some work''? If its stock you should be able to get ahold of a wiring diagram fairly easy. If not......... it may be time for a wiring kit and just redo it all right..... I transplanted a harness from an 84 Suburban into my junk just for the age difference and blade fuses but it took a couple days to get it how I needed deleted alot too though
Old 07-30-2009, 12:17 AM   #9
fixit-p
fixit-p's Avatar
There's the problem. Is this a three wire internal reg alt? If yes check that the plug is wired correctly the #1 terminal should be hot with key on and the #2 (voltage sense) terminal should be hot all the time.
1965 GMC shortwide big window
1969 Chevy C20 long (for now)
2005 Silverado 2500HD Crew Cab
Originally posted by:Abraham Lincoln "The trouble with quotes on the Internet is that it is nearly impossible to discern if they are genuine."
fixit-p is offline   Reply With Quote
