Old 08-04-2009, 10:52 PM   #1
67 c10 guy
67 c10 guy's Avatar
Cab question
Did the stock 1967 c-10 custom or any cab for
that matter have a floor shift? just wondering
if the patched hole in my floor is stock or not
67 C10 longbed 350/th350
13 Ford Fusion 2.0T daily
67 lwb build sold
67 c10 guy is offline   Reply With Quote
Old 08-04-2009, 11:49 PM   #2
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
Re: Cab question
mine came with a 4 on the floor, so i assume it was standard. what trans is in it now??
got any pics???
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 08-05-2009, 01:40 AM   #3
67 c10 guy
67 c10 guy's Avatar
Re: Cab question
no pics of the plate but its almoston the edge
of the hump(drivers side) and further back.
curently has a turbo 350
67 lwb build sold
Old 08-05-2009, 01:47 AM   #4
BAGNDRAGIT
BAGNDRAGIT's Avatar
Re: Cab question
that sounds like it might be a 4wd hump, is it a low or high hump?
im pretty sure 4wd is the high hump and 2wd is the low hump. if im wrong someone will correct me....
Previous:
1969 Volkswagen Bug
Old 08-05-2009, 08:58 AM   #5
WorkinLonghorn
WorkinLonghorn's Avatar
Re: Cab question
There was no floor shift on these trucks. That had to have been added by a previous owner.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 08-05-2009, 07:53 PM   #6
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Re: Cab question
I have a factory installed Muncie M-20 floor shift in my 70. I can prove it with my SPID. If the hole is to one side it probably is a High/low range shifter for 4WD.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 08-11-2009, 12:40 AM   #7
67 c10 guy
67 c10 guy's Avatar
Re: Cab question
the truck is definitely a 2wd no doubt. i find no indication of
it being a 4wd. Whats the height diference form
a hi hump to the low hump? How do you look up the spid?
Thanks for all your help!
67 lwb build sold
Old 08-11-2009, 11:05 AM   #8
WorkinLonghorn
Re: Cab question
Well then I stand corrected! That's a new one for me as I've never seen or heard of such an option either in the factory lit. or on any truck. Must be super rare.
Old 08-11-2009, 11:10 AM   #9
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Cab question
Just because you hadn't heard it, doesn't mean this wasn't a common item. IIRC all 4 speed manuals got a floor shift. Most of them (I don't recall the model number) had the Granny first gear so in effect you drove it like a 3 speed. I think you'll find these more common in 3/4 and 1 ton models, since the Granny first was good for pulling a heavy load from a stop.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 08-11-2009, 09:40 PM   #10
unclewatts
unclewatts's Avatar
Re: Cab question
That's right Chevy_mike. My Muncie has a granny low and you start up from a stop in second gear.
Old 08-11-2009, 11:32 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Cab question
The 4 speed was the base mode tranny in all one tons regardless of the year. (67 - 72)
It was pretty common in all 67 - 72 2 wheel drive and 4x4, 1/2 ton and 3/4 ton trucks. Not even rare.
The SPID is the sticker inside the glovebox door that tells you what options the truck had originally
Your TH350 is not original, they werent installed till 69
the high hump floor is bolted in, the low hump is part of the stamped floor. All 4x4 trucks, all 4 speeds, and most every big block/auto got the high hump.
Old 08-12-2009, 09:55 AM   #12
WorkinLonghorn
Re: Cab question
Sorry,I thought we were talking about an AUTOMATIC trans with a floor shift!
I picked a bad week to quit coffee.
Old 08-12-2009, 12:55 PM   #13
BarryB
BarryB's Avatar
Re: Cab question
That was only when you had the infamous "corvette option"
Sorry guys I couldn't resist that one.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box.
* You may be only one person in the world, But you may also be the world to one person.
* Some mistakes are too much fun to only make once.
Two rules in life.
1. Never sweat the small stuff!
2. Everything is small stuff!
BarryB is offline   Reply With Quote
1967, cab, floor shift, floorboard
