Texas Big Wig
Dropped Cup LCA's
ok guys, here it is
I'm back from see'n my brother & bag'n the front of my truck I took a lot of pics, so I'm not gonna post em all... Here is a link Ima skip the disassembly & start with the good stuff Cut'n the bump stop off ![]() ![]() Bolt the upper plate to the bag & mock it up ![]() ![]() Made the lower cup ![]() ![]() ![]() ![]() ![]() Last edited by augie; 04-06-2011 at 01:46 AM. |
Texas Big Wig
Re: Lower A-arm ???
Mocked up the lower cup & A-arm, so we could trace where to cut
![]() ![]() ![]() Cut'n out ![]() ![]() We leveled the cup to the bottom edge of the A-arm ![]() ![]() ![]() Last edited by augie; 04-06-2011 at 01:47 AM. |
Texas Big Wig
Re: Lower A-arm ???
Drilled a hole it the cross member & put a grommet in for the hose to run through
![]() ![]() Bag installed for good ![]() ![]() ![]() ![]() My temp for airing them up ![]() ![]() Last edited by augie; 04-06-2011 at 01:51 AM. |
Texas Big Wig
Re: Lower A-arm ???
Bolting up the lower A-arm
![]() Putting it all back together ![]() ![]() ![]() ![]() ![]() ![]() Last edited by augie; 04-06-2011 at 01:53 AM. |
Texas Big Wig
Re: Lower A-arm ???
I couldn't get a pic of it aired out on teh ground, because my brothers air compressor didn't have the umph to get my truck up very high
![]() But here it is on the trailer ![]() ![]() It may go a little lower, but it's sitting on the swivel for the winches hook And it's just about to hit the headers & bind the upper ball-joint Here are some more pics of it at ride & dump... No notch in the rear & no drop spindles ![]() ![]() ![]() Last edited by Spray-Bomb; 08-09-2009 at 09:17 PM. |
