Best way to Lower a suburban?
Hey guys, I'm looking for best opinions and pictures on lowered (non airbagged slammed) suburbans. would like to go lower then the 2/2 that LMC offers. I have a 91 2wd 1500.
thanks in advance for your posts |
Low & Fast!
Re: Best way to Lower a suburban?
Here is one place to look DJM. 2" shackles and 2" springs.
http://www.djmsuspension.com/product...c%20table.html Can anyone help out on what you did on your?
I know where to buy lowering components, I'm just looking for some advice maybe from the blazer guys. Why is a 2/2 drop my only option. Can I do a 3/5. Withought any issues?
6.0 powered square
here's a few
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
6.0 powered square
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 08-06-2009 at 07:18 PM. |
Low & Fast!
If you did a flip kit you would get about 6" out of that. But you can do the 2" and take 2 leafs out. I don't think they make lowering leafs for burbs that year.
Can anyone tell us what they did?
Thanks for the pictures and replys. The first pic you uploaded above used a cut coil spring from an 04silverado. There aren't too many suburbans so thats why i figure the blazer guys can help. I will keep searching.
my short bus
you can 4" drop hanger in the rear
3" bell tech spindles with 2" springs them pull a leaf or 2 if not level
**90 burb**bagged,shaved**(about done)********* **91 burb**stock worker for now**************** *********only squares for me****************** |
Thanks duallyburb, your suburban is coming together nicely. How well does it drive?
my short bus
better than stock much smoother now just have to weld in all shock tabs and finish rear floor
got 400 mile rode trip end of month ![]()
Here is a pic of my old squareburb. I used 3" spindles and the $40 ebay flip kit. I really miss this truck.
That's the perfect stance I was looking for. Thank you for letting me know what you used.
67-72 parts collector,…
![]() Join Date: Nov 2002
This is my old '91 'burb.
3" drop spindles and 2" drop springs up front. The rear was a set of 4" drop leaf springs. (Chisholm Suspension,... which is no longer in business,... I think)
I don't think these pills work
the back is 2" belltech drop shackles and the front is 1 full coil cut off the springs
SQUARE84 ![]() 90 SUBURBAN |
#15 |
yep thats mine like they said i cut some 04 coils cut 1 coil and took 2 leafs out of the back.
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
